Old 07-12-2013, 12:23 AM   #295
sprintertrueno86
sprintertrueno86's Avatar
Drives: 2018 BMW M2
Originally Posted by F1point4 View Post
Inline racing Turbo Twins
20130706-CarsAndCoffeeJuly-010 by VictorN07, on Flickr
OH JESUS
sprintertrueno86 is offline   Reply With Quote
Old 07-12-2013, 12:37 AM   #296
RIPTRD71
RIPTRD71's Avatar
Drives: Raven FR-S 6MT
I wish I had the skill of photography that you have!
Originally Posted by wootwoot View Post
She's stiff as a goose. I tried yanking out the motor too, that was pretty stiff as well. So.. i'll try the flux capacitor next.
RIPTRD71 is offline   Reply With Quote
The Following User Says Thank You to RIPTRD71 For This Useful Post:
F1point4 (07-12-2013)
Old 07-13-2013, 06:53 PM   #297
F1point4
Photo Specialist
F1point4's Avatar
Drives: 2013 Toyota 86 DGM 6MT
Oil Cooler Dreams
Guided @brillo through his Homebrew Oil Cooler Install. Check it out
http://www.ft86club.com/forums/showp...6&postcount=66
Love this picture
20130713-ADOilCoolerInstall-049 by VictorN07, on Flickr
F1point4 is offline   Reply With Quote
Old 08-18-2013, 01:11 AM   #298
F1point4
Photo Specialist
F1point4's Avatar
It's been a while
I'm just going to throw a bunch of things in here that happened recently.
++Turn-in Concepts steering rack bushing
installed by DD Performance Research. This made a noticeable difference in steering feel. (No picture)
++ Turns out I installed my control arms incorrectly.
The way I did it works but it was impossible to adjust camber without dropping the arm at the subframe. This wouldn't be bad, but adjusting camber also changes your toe and vice versa. The two locknuts and one turnbuckle were impossible to adjust with conventional wrenches. DD Performance Research grounded two three combination wrenches so they are thin enough to use. The Cusco Arm requires 27mm, 29mm, and 1.25" wrenches
Before
20130815-DDPR_Day2-004 by VictorN07, on Flickr
After
20130815-DDPR_Day2-006 by VictorN07, on Flickr
++Got an Custom Alignment.
done by DD Performance Research. Fixed my steering alignment issue (cocked to the left to track straight). To get the rear camber and toe correct, you need to have two dudes doing the job. One to adjust the camber and the other to change toe at the same time.
20130815-DDPR_Alignment-001 by VictorN07, on Flickr
++DD Performance Research created a custom bracket
for me for a top mount oil cooler. Fixed the sag in the black plastic tray which caused my bumper not to fit properly. The brackets were riveted into the crash beam and mounted to the side of the Vortech intercooler. Creates some peace of mind with re-enforcement.
20130815-DDPR_Day2-013 by VictorN07, on Flickr
20130815-DDPR_Day2-014 by VictorN07, on Flickr
20130815-DDPR_Day2-017 by VictorN07, on Flickr
++My Borla header
cracked before the merge collector. While working on the above, we found a crack in my Borla Header. I found the root cause of my rattling resonance on ignition, and why my boost gauge was showing lean. Since this crack was before the primary O2, that sensor reads lean and makes my car run rich.
Time for a different header.
20130815-DDPR_Day2-007 by VictorN07, on Flickr
++Impromtu shoot
20130806-PianoShoot-001 by VictorN07, on Flickr
20130806-PianoShoot-002-Edit by VictorN07, on Flickr
20130806-PianoShoot-014-Edit by VictorN07, on Flickr
20130806-PianoShoot-021 by VictorN07, on Flickr
The Following User Says Thank You to F1point4 For This Useful Post:
Sportsguy83 (08-19-2013)
Old 08-18-2013, 08:35 AM   #299
DarkCard
Drives: Asphalt Scion Frs 6MT
So glad I got rid of that header. Curious, what are the oil temps now and also before the cooler install?
Sent from: Outerspace
DarkCard is offline   Reply With Quote
Old 08-18-2013, 10:26 AM   #300
F1point4
Photo Specialist
F1point4's Avatar
Daily driving my oil temp rarely goes about 200F according to Torque. Monitoring temps before the install and comparing similar conditions it was about a 40 degree drop for me.
Old 08-19-2013, 11:36 PM   #301
F1point4
Photo Specialist
F1point4's Avatar
Carwash
Sad to say, but it's been a few months since I washed my car. Blame work. One of my mates, @firestormriot, and I washed our cars. Ended up doing a little shoot afterwards
Feels so good to have a clean car.
Chemical Guys Pink Foam Soak
20130810-CarwashDay-001-Edit by VictorN07, on Flickr
Macro
20130810-CarwashDay-003 by VictorN07, on Flickr
20130810-CarwashDay-009 by VictorN07, on Flickr
20130810-CarwashDay-096-Edit by VictorN07, on Flickr
20130810-CarwashDay-125-Edit by VictorN07, on Flickr
20130810-CarwashDay-136 by VictorN07, on Flickr
20130810-CarwashDay-141-Edit by VictorN07, on Flickr
20130810-CarwashDay-144 by VictorN07, on Flickr
20130810-CarwashDay-163-Edit by VictorN07, on Flickr
20130810-CarwashDay-194-Edit by VictorN07, on Flickr
20130810-CarwashDay-288-Edit by VictorN07, on Flickr
20130810-CarwashDay-298 by VictorN07, on Flickr
20130810-CarwashDay-304 by VictorN07, on Flickr
20130810-CarwashDay-111-Edit by VictorN07, on Flickr
More on my flickr!
Old 08-19-2013, 11:38 PM   #302
F1point4
Photo Specialist
F1point4's Avatar
Borla Boxer Rattle?
I mentioned in the Borla Headers Update post that I found the source of my rattling when I start the car. Turns out it was indeed the borla header. We pressed on the pipe at the shop and we could hear it make the distinct noise.
As i mention in the video, this is purely for awareness for other owners. I'm sure Borla will take care of me. I started the process. I will keep everyone up to date.
http://www.ft86club.com/forums/showt...headers+update
[ame="http://www.youtube.com/watch?v=clM96uY452M"]Borla UEL Header Rattle Resonance - YouTube[/ame]
Old 08-20-2013, 11:16 AM   #303
F1point4
Photo Specialist
F1point4's Avatar
Borla Warranty Update
I contacted Borla directly for my warranty process. They told me a replacement will ship by the end of this week. I confirmed I do not need to ship mine back at all.
Awesome service!
Sportsguy83 (08-20-2013)
Old 08-20-2013, 11:18 AM   #304
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Borla Boxer Rattle?
That shit sounds so annoying!! Glad they are being proactive about your replacement!
Old 08-20-2013, 11:37 AM   #305
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Awesome service!
That is the same story @chadstyle told me when he contacted Borla. They sent him a new one and let him keep the original. Reminds me when I got an expensive "carbon fiber" front lip for my 350Z that didn't fit for shit. The company made me take pictures of the damage to my front bumper from installing it and the horrible fit first. Then they said they would send me a new one after I took pictures of the original one broken in half, haha. I enjoyed breaking the shit out of it to get a new one sent. The new one didn't fit any better, but I accepted it at that point.
chadstyle (08-20-2013)
Old 08-20-2013, 12:25 PM   #306
DarkCard
Wow that sounds terrible! That would drive me nuts
Old 08-20-2013, 12:46 PM   #307
chadstyle
chadstyle's Avatar
Drives: 2013 Subaru BR-Z Limited
Let me guess.....
Seibon??
chadstyle is offline   Reply With Quote
Old 08-20-2013, 01:04 PM   #308
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Originally Posted by chadstyle View Post
Let me guess.....
Seibon??
Nope. Veilside Version 1. Replaced it with a better fitting knock off eventually.
Asphalt Scion FR-S aznsensazian FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 21 03-17-2014 01:13 PM
Asphalt FR-S pics Rob_g CANADA 24 09-03-2012 05:01 AM
Asphalt in the snow Double4Free Scion FR-S / Toyota 86 GT86 General Forum 5 06-10-2012 01:56 PM
Asphalt 6MT FR-S Symbiont Southern California 22 06-06-2012 07:47 AM
ant08 Asphalt MT ant08 Member's Car Journals 3 06-04-2012 04:16 PM
