Old 08-19-2013, 07:19 PM   #57
ftc~brz
Done
Drives: WRB BRZ
Did you join just to post that?
yes, yes I did.
Please don't hate me for my bad jokes, I have enough haters for that already =)~
ftc~brz is offline   Reply With Quote
The Following User Says Thank You to ftc~brz For This Useful Post:
Anthony (09-30-2013)
Old 08-19-2013, 09:47 PM   #58
slates74
Drives: 13 SWP BRZ LTD 6MT
Originally Posted by 8686 View Post
@slates74 any news on AT fitment?
Still need a local with an AT car to step up to the plate!
slates74 is offline   Reply With Quote
The Following 2 Users Say Thank You to slates74 For This Useful Post:
whataboutbob (08-19-2013), xjohnx (08-19-2013)
Old 08-19-2013, 10:17 PM   #59
JimmyMac
JimmyMac's Avatar
Drives: 2013 FR-S, 2016 Miata Club
We'll see how long it takes them to send one out. I'll take pics of the install and give my feedback. I doubt I'll hear any whining if there is any. I'm running a full exhaust. Looking forward to it!
JimmyMac is offline   Reply With Quote
The Following User Says Thank You to JimmyMac For This Useful Post:
number1Tango (08-21-2013)
Old 08-19-2013, 10:23 PM   #60
xjohnx
Grip>Slip
xjohnx's Avatar
any plans to make axles/cv's?
Old 08-21-2013, 03:35 AM   #61
JimmyMac
JimmyMac's Avatar
I'm just curious, are these built to order?
Old 08-21-2013, 12:15 PM   #62
stockysnail
Just the tip
stockysnail's Avatar
I ordered mine Friday night. They made one Monday and shipped it Tuesday so should have it end of this week hopefully.
The Following User Says Thank You to stockysnail For This Useful Post:
JimmyMac (08-21-2013)
Old 08-21-2013, 12:21 PM   #63
37
degrees
37's Avatar
Drives: 6MT BRZ
If you have the means to do so, measure your 0-60 times before and after. It would be good to know what kind of improvement this makes.
37 is offline   Reply With Quote
The Following User Says Thank You to 37 For This Useful Post:
8686 (08-21-2013)
Old 08-22-2013, 09:21 PM   #64
Dephective
Drives: '13 Whiteout FRS
BTW, Aluminum is corrosion resistant. That's one of the desirable attributes of aluminum. For example, marine companies like to use it instead of steel, not only because of the weight, but it takes much higher quality steels to meet the same corrosion resistance of aluminum.
Salt shouldn't be your worry. OEM shaft is more likely to corrode. I'd be more worried about the shaft vaulting me in the instance of a failure. 1 pieces tend to do that.
Previous:
'01 Accord-daily
'93 Rx7-fire breathing track monster 545hp 397tq 2300lb.
'06 Mazdaspeed6 one helluva love-hate relationship
Dephective is offline   Reply With Quote
Old 08-24-2013, 02:28 AM   #65
JimmyMac
JimmyMac's Avatar
Mannnnn, no package this week.... I've been shafted!!!
The Following 2 Users Say Thank You to JimmyMac For This Useful Post:
CajunFRS (09-20-2013), GTB/ZR-1 (08-24-2013)
Old 08-24-2013, 12:26 PM   #66
Anaxilus
Drives: They have four wheels
Can you find out what aluminum they use for the yokes and shaft? Also what tolerances they balance to? TIA.
Anaxilus is offline   Reply With Quote
Old 08-25-2013, 09:32 PM   #67
Wrist20
Drives: 2012 GLI
The aluminum used is Alcoa certified 6061. Tolerance for straightness is between .000-.003 and the balance is between .000-.001. Check out Wrist20 on IG to see a video showing the quality or click on the link.
http://instagram.com/p/dVDiLaAqZz/
Wrist20 is offline   Reply With Quote
The Following 4 Users Say Thank You to Wrist20 For This Useful Post:
37 (08-27-2013), Anaxilus (08-26-2013), ProjectD (08-27-2013), slates74 (08-26-2013)
Old 08-25-2013, 11:27 PM   #68
JimmyMac
JimmyMac's Avatar
What he said. They also said the ends are forged aluminum and the joints are hd spicer.
Old 08-27-2013, 05:54 PM   #69
JimmyMac
JimmyMac's Avatar
Look what brown just dropped off. I wonder what it could be?
I'll give you a hint...
37 (08-27-2013), FastLane1000 (08-27-2013)
Old 08-27-2013, 06:31 PM   #70
37
degrees
37's Avatar
Drives: 6MT BRZ
holy crap... IT'S BIGGER THAN YOUR CAR!!!
The Following 3 Users Say Thank You to 37 For This Useful Post:
GTB/ZR-1 (08-27-2013), Mr.Jay (09-17-2013), sierra (09-01-2013)
DIY: Driveshaft Shop (DSS) Carbon Fibre Driveshaft F1point4 DIY (Do-It-Yourself) Guides 67 04-17-2021 05:21 PM
PST vs Driveshaft Shop CF Driveshaft? RehabJeff86 Engine, Exhaust, Transmission 4 08-26-2013 12:39 AM
DriveShaft's and Axle's Driveshaft Shop Engine, Exhaust, Transmission 34 08-21-2013 05:17 PM
Driveshaft Shop CF Driveshaft installed. Hawaiian Engine, Exhaust, Transmission 5 08-13-2013 02:04 PM
GFB 3-Piece lightweight aluminum pulley kit Touge Factory Engine, Exhaust, Transmission 60 06-03-2013 01:52 PM
