Old 08-19-2013, 03:57 PM   #15
m.wood0213
Driving Enthusiast
m.wood0213's Avatar
Drives: 2013 BRZ Limited
My chirps seem to be intermittent when using Lucas fuel injector cleaner. Try that. Before using it they were constant.
“This isn’t a supercar, it’s a sports car. It sacrifices rear seats yes but it just feels alive. Pure, direct, immediate. The other two are going to get all the admiring looks yes, that’s my point. I’m not driving around in this for other people’s benefit. I’m driving around in this BECAUSE I LOVE DRIVING IT. END!”
-Richard Hammond, Top Gear, USA Supercar Road Trip, 2011 Porsche GT3 RS.
My BRZ
m.wood0213 is offline   Reply With Quote
Old 08-19-2013, 03:57 PM   #16
coredump4
Drives: 2013 BRZ Limited MT, 2006 Spec.B
Originally Posted by TheseColorsDontRun View Post
Anybody know of any cases of a failed HPFP? And what the residual damage would be?
I'm coming from a Golf TDI that also had HPFP issues. In those cars, when the pump goes, it grenades it self into millions of pieces and wipes out the whole fuel system. $8,000 repair bill.
Ahhh, that's the context everyone needed to understand why you were so concerned about the HPFP!
An $8k repair would really ruin my day. What generation Golf TDI has that issue? My friend bought a 2013 as his commute car last year. He's over 40k miles already with zero issues.
coredump4 is offline   Reply With Quote
Old 08-19-2013, 04:14 PM   #17
BlueDubbinTDI
BlueDubbinTDI's Avatar
Drives: 2013 FR-S, 2012 MCS
I just filled up at Shell and I don't think I have crickets this particular tank of gas so far. Will keep an ear out and try again on my next tank too. Could just be fuel quality
Old 08-19-2013, 04:15 PM   #18
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
My HPFP was on the verge of failing. Just letting you guys know.
Old 08-19-2013, 04:16 PM   #19
BlueDubbinTDI
I have a TDI as well I'm not keeping past warrenty for that exact issue. It started in 2009 and has gotten less and less common as the generation progressed, which ends at the 2013 model. MK7s release next summer iifc
Mine is certified until Aug 2015 at which time I will get a 2015 GTI.
Old 08-19-2013, 04:16 PM   #20
boredom.is.me
Custom User Title
Here is my thread.
http://www.ft86club.com/forums/showt...ght=woodpecker
Old 08-19-2013, 04:20 PM   #21
TheseColorsDontRun
Keep calm and drive on
TheseColorsDontRun's Avatar
Drives: 2013 WRB BRZ Limited 6M
This is an issue with all Common Rail VW diesel engines. The 2009+ Jetta SportWagen, 2010+ Golf, 2010+ Jetta sedan, 2012+ Passat.
I put 91k miles on mine before trading it for the BRZ. With the TDI HPFP for the most part it's luck. The failure rate based on data collected at www.tdiclub.com is hovering near 1%. Not that bad, but considering the cost associated with the failure, that's a big risk once mileage starts piling up and the car depreciates enough.
This is scary: http://www.ft86club.com/forums/showp...&postcount=158
Most of our cars don't see the type of abuse that the Ring cars are subjected to, but still.
TheseColorsDontRun is offline   Reply With Quote
Old 08-19-2013, 04:59 PM   #22
coredump4
How'd you know? Did it eventually throw a CEL, or the chirps got worse, etc.? Or did the tech just tell you so?
Old 08-19-2013, 05:57 PM   #23
boredom.is.me
Custom User Title
It was doing way more than just chirping. The tech didn't know what was wrong, but he said it wasn't going to last much longer. This wasn't one of the trained monkeys either.
See here: http://www.ft86club.com/forums/showt...ght=woodpecker
Old 09-18-2013, 02:59 PM   #24
soulstice
Drives: SWP BRZ LTD
So i've developed the chirps as well now.
Is it correct that if you want this fixed under warranty it can only be done by a subaru dealership?
soulstice is offline   Reply With Quote
Old 09-18-2013, 03:38 PM   #25
boredom.is.me
Custom User Title
There is no point in getting it "fixed".
Old 09-18-2013, 10:38 PM   #26
VoiD
Drives: 13 WRB BRZ
Mine started as well.. after getting gas at a local shell station..
will try sunoco next time and see if gas has anything to do with this..
VoiD is offline   Reply With Quote
Old 09-18-2013, 11:36 PM   #27
TheseColorsDontRun
@thejevans
Please update with your situation.
Random Chirp while moving. NOT idle chirp. Stephens Issues | Warranty | Recalls / TSB 18 08-14-2013 12:02 PM
Chirp Gone Nothing Replaced Employee CANADA 6 08-04-2013 12:25 PM
Help me ID this chirp nix Issues | Warranty | Recalls / TSB 3 02-07-2013 08:00 AM
Chirp at 70mph markitect Issues | Warranty | Recalls / TSB 15 12-05-2012 08:30 PM
Those running e85...do you have idle chirp? jeebus Engine, Exhaust, Transmission 6 09-22-2012 10:39 PM
