Old 08-19-2013, 01:31 PM   #2045
ildylan
rolling over my sidewall
ildylan's Avatar
Drives: 15 FRS
Originally Posted by Scooby South View Post
As for the Catted Header.. It was a Prototype.. not going to happen as far as I know. Jason can correct me..
I was under the impression to maintain STX you have to have a cat within 6" of its OE location. Perhaps I'm missing something though -- it is Monday.
ildylan is offline   Reply With Quote
Old 08-19-2013, 02:02 PM   #2046
xjohnx
Grip>Slip
xjohnx's Avatar
It allows for the removal of 1 cat as long as you still have 1 cat in the car. the 1 cat remaining has to be within x number of inches of its original location.
i'm sure i'm missing some key verbiage in there, but that's the gist of it, if i recall correctly.
Scooby South (08-19-2013)
Old 08-19-2013, 02:02 PM   #2047
Wepeel
Drives: '13 BRZ Ltd
That is true, but there is a cat in the front pipe as well - so you could run a catless header with a catted front pipe and remain legal. Or a catted header with a catless front pipe.
Wepeel is offline   Reply With Quote
The Following User Says Thank You to Wepeel For This Useful Post:
Old 08-19-2013, 02:04 PM   #2048
Stevo22
Stevo22's Avatar
Drives: GR86
That rule applies to the cat furthest back in the exhaust system. Since this car has two (1 in the header and 1 in the mid pipe) you can get rid of the one in the header and have a high flow in the mid pipe.
Wepeel beat me!!!
Stevo22 is offline   Reply With Quote
The Following User Says Thank You to Stevo22 For This Useful Post:
Old 08-19-2013, 02:05 PM   #2049
Ranatsu
Cone basher
Drives: 2017 Subaru BRZ Series.Yellow
You just have to have 1 cat within x inches.. I don't think it lists a specific number of cats that you can remove, because some cars have more than 2.. IE 02-05 wrx has 3, and i'm pretty sure you can remove all of them but 1.
edit: actual rule
E. Catalytic converters: Any catalytic converters are allowed, but must
attach within 6” of the original unit. Multiple catalytic converters may
be replaced by a single unit. The inlet of the single replacement converter
may be located no further downstream than 6” (152.4mm)
along the piping flow path from the original exit of the final OE converter.
The extents of an OE converter are defined by the expansion
chamber in which the catalyst is contained, regardless of placement
within larger exhaust sections. Replacement converters must have
a minimum catalyst density of 100 cells per inch and minimum substrate length of 3” (76.2mm).
Ranatsu is offline   Reply With Quote
Old 08-19-2013, 02:09 PM   #2050
xjohnx
Grip>Slip
xjohnx's Avatar
Yep, you're right. At least I had the general idea right.
Old 08-19-2013, 02:14 PM   #2051
Scooby South
Conedancer
Scooby South's Avatar
Drives: 2013 Subaru BRZ SWP
The Actual Rule:
Scooby South is offline   Reply With Quote
Old 08-19-2013, 02:29 PM   #2052
Scooby South
Conedancer
^^^ Which is why Nameless will make 2 versions of headers... one with the fan Replacement...one thats 'STX' Legal and no fan replacement..
Old 08-19-2013, 02:37 PM   #2053
OrbitalEllipses
Drives: Attitude
The difference in price and performance between the two is what'll do it for me. I don't want to cut up shrouds and stuff in the interest of returning to stock...but I'm not going to leave 20hp on the table.
The Following 2 Users Say Thank You to OrbitalEllipses For This Useful Post:
chanomatik (08-19-2013), StormTrooper (08-19-2013)
Old 08-19-2013, 04:37 PM   #2054
xjohnx
Grip>Slip
xjohnx's Avatar
If i were you, i'd run the non-legal one just to tempt the protest weenies.
wparsons (08-19-2013)
Old 08-19-2013, 07:39 PM   #2055
StormTrooper
StormTrooper's Avatar
Drives: Pavement MT GR86
Exactly.
I highly doubt it'll be over a 10hp difference. That being said, I don't have plans to leave the region for autoX. And therefore care very little about the class my car ends up in.
GR86 MT premium
StormTrooper is offline   Reply With Quote
Old 08-19-2013, 09:33 PM   #2056
Boofneenee
Go-Kart Enthusiast
Boofneenee's Avatar
Drives: Toyota Scion FRS
I am a bit late to the thread... and I have not read all 94 pages.. tbh, I am a bit new to cars but my new FRS is turning me into a car enthusiast.
I have been shopping around for mods that will grant me more power without voiding my warranty so... a turbo/supercharger is out.
therefore, I am stuck with intake/exhaust/weight loss and other trivial stuff.. I cannot, for the life of me, find much out there for aftermarket headers.. not even Perrin sells a header. This dude does.
Can someone answer my questions?
Why, if adding on an aftermarket header, do so few companies not make headers if they can add a great deal of power?
Are aftermarket headers legal? Will I pass emissions in Mass with them?
I dont believe it will void my warranty if I get one..
Last question.. where the blazes can I get one that meets the demands I listed above?!
Boofneenee is offline   Reply With Quote
Old 08-19-2013, 10:16 PM   #2057
Jidonsu
Drives: Scion FR-S | 6MT | Ultramarine
Can't freaking wait! This is going to be awesome.
Jidonsu is offline   Reply With Quote
Old 08-20-2013, 01:17 AM   #2058
Jive Turkey
the tuna, no crust.
Jive Turkey's Avatar
Drives: 2014 Hachiroku of the year
Originally Posted by Calum View Post
A little high, little low
Any way the wind blows doesn't really matter to me...TO MEEEEEE..
Jive Turkey is offline   Reply With Quote
The Following User Says Thank You to Jive Turkey For This Useful Post:
roddy (08-20-2013)
21 months no dyno, 22 months no vendor dyno, 22months4rattles&leakssmh, amazing warped qualiy, y u no tag
Nameless Performance BRZ Axleback Exhaust ESBjiujitsu Engine, Exhaust, Transmission 1377 04-21-2020 02:23 AM
Nameless Performance Axleback is available for pre-order. Nameless Performance Inc. Engine, Exhaust, Bolt-Ons 114 07-23-2012 10:38 PM
Nameless Performance Downpipe is available for pre-order. Nameless Performance Inc. Engine, Exhaust, Bolt-Ons 4 07-12-2012 04:57 PM
We are Nameless Performance. John@Nameless Announcements, Contests, Giveaways 22 06-18-2012 11:32 PM
Nameless Performance is here. Nameless Performance Inc. Engine, Exhaust, Bolt-Ons 16 06-06-2012 04:32 AM
