Old 08-06-2013, 04:06 PM   #267
TrogDor the Burninator
TrogDor the Burninator's Avatar
Drives: 2013 Hot Lava FR-S 6 MT
I have the Tarmac 2 Clubsports, and have noticed some slipping in the ride height on my front right coilover. The locking nut on the plastic collar apparently isn't holding any longer. I was more than careful in the torque applied to the locking screw, but it appears that it's no longer going to hold.
My question is, are replacement collars available? Also, is it possible to fit a dual locking set of metal collars to this KW strut instead of relying on the plastic collar and lock screw? These are wonderful coilover - I absolutely love them - but this one piece seems to be an achilles heel in an otherwise amazing product from RCE ....
@Racecomp Engineering
2013 Scion FR-S Hot Lava 6MT Current Mods: KW V3 Coilovers - Raceseng CasCam Plates - Volk TE37SL Black Edition 18x9 +45 - Dunlop Direzza ZIIs 255/35 - Tomei Expreme Ti 60S - FT86 SpeedFactory UEL Catted Header
TrogDor the Burninator is offline   Reply With Quote
Old 08-06-2013, 05:24 PM   #268
Interesting, we haven't seen that before on BRZ or our Impreza sets. We do have replacements, so please give us a call as soon as you can.
- Andy
TrogDor the Burninator (08-06-2013)
Old 08-06-2013, 05:31 PM   #269
- Andy
Do you have a dual locking metal collars available for the Tarmac 2s?
Old 08-06-2013, 05:48 PM   #270
Asphaltfrs1
Asphaltfrs1's Avatar
Drives: 2013 asphalt fr-s
My FRS on Tarmac 0s w/ rpf1s on 255/35 bf Goodrich tires
Asphaltfrs1 is offline   Reply With Quote
The Following 9 Users Say Thank You to Asphaltfrs1 For This Useful Post:
ATL BRZ (08-19-2013), Cesium Rainbow (08-19-2013), chanomatik (08-06-2013), Chee-Hu (08-07-2013), Jay2420 (11-20-2013), mfbmike (08-25-2013), Overland'n'5thGEN (08-06-2013), Racecomp Engineering (08-06-2013), Sportsguy83 (08-06-2013)
Old 08-06-2013, 09:17 PM   #271
We can do an extra locking plastic perch, but we don't have metal ones. We've done that combo before and it works well. Call us tomorrow.
- Andy
Old 08-19-2013, 07:57 AM   #272
FR-S Matt
So I installed my Tarmac 0's this past weekend. Love the way they look and the ride is very nice. Only problem I am running into is my car veers off to the right when I brake and the brakes feel different. I have to push the pedal much harder than before.
Hoping I didn't damage any of the lines, but I don't see how I could have. The bolt that holds the line in the back left wheel didn't fit and it stripped the stock bolt. I had to use a different bolt and a nut just to hold it there.
Any advice? I'm going to get an alignment today if that may be my issue.
Old 08-19-2013, 10:35 AM   #273
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
First, before driving anywhere else, check your brake fluid level in the reservoir and shine a light at your brakes all around and inspect them best you can. Look for fluid drips everywhere and especially at the brake line fittings.
Are you certain that your ride height settings are consistent side to side? I'm not sure but maybe one side is slightly higher than the other and possibly contributing to the car being off balance under braking? Number of threads used/remaining on the strut collar are a good reference point to check ride height side to side.
ATL BRZ is online now   Reply With Quote
Old 08-19-2013, 10:50 AM   #274
Very odd on the brake pedal. Call us.
- andy
FR-S Matt (08-19-2013)
Old 08-19-2013, 12:08 PM   #275
FR-S Matt
Originally Posted by ATL BRZ View Post
First, before driving anywhere else, check your brake fluid level in the reservoir and shine a light at your brakes all around and inspect them best you can. Look for fluid drips everywhere and at especially at the brake line fittings.
Each side measured from center cap to fender measures 14". I did my turns on ride height based on the locking pin.
Old 08-19-2013, 12:15 PM   #276
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
What I measured for height adjustment was the length of thread left below the strut collar, from bottom to the collar. Good luck with everything!
I believe your method of measurement is accurate, but check that threads left too.
The Following User Says Thank You to Sportsguy83 For This Useful Post:
Old 08-19-2013, 12:21 PM   #277
FR-S Matt
Thanks! Yeah, I think the brakes might need to be bled. Might have gotten an air bubble in one of the lines. The fact that the car veers to the right makes it feel like the back left brake might have something going on. I'm having the alignment shop check them today while I get it. The car rides amazing otherwise and I can corner like crazy with the 4.5 inches of clearance I have up front now!
I'll check the threads on each coil when I get home.
The Following 2 Users Say Thank You to FR-S Matt For This Useful Post:
Racecomp Engineering (08-19-2013), Sportsguy83 (08-19-2013)
Old 08-19-2013, 12:50 PM   #278
There's a good chance the alignment will help a lot. Check the brakes though.
- Andy
Old 08-19-2013, 12:54 PM   #279
Gopherboy6956
Gopherboy6956's Avatar
Drives: 13 BRZ Limited WRB
Did you disconnect the brake lines when you installed the Coils?
I plan to live forever. So far, so good.
My Build - http://www.ft86club.com/forums/showthread.php?t=31925
Gopherboy6956 is offline   Reply With Quote
Old 08-19-2013, 01:48 PM   #280
FR-S Matt
No.
Racecomp Tarmac II Clubsport coilover JoeBoxer Suspension | Chassis | Brakes -- Sponsored by 949 Racing 47 11-16-2013 11:02 PM
Tarmac Zero Coilovers Specs? tintumz22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 18 06-13-2013 11:26 PM
KW CLUBSPORT COILOVERS W/ FREE SHIPPING FOR THE SCION FR-S/SUBARU BRZ!!! NJA Brakes, Suspension, Chassis 7 03-30-2013 08:26 PM
Wheel Directory: Enkei ES-Tarmac 16x7.0 +45 quik1987 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 09-12-2012 12:24 PM
Toyota 86 Tears Up Tarmac at 2012 TAS (TRD, N1, HKS, Up Garage Models) + LFA Roadster knoxviue FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 35 01-20-2012 01:44 AM
