#267 |
Drives: 2013 Hot Lava FR-S 6 MT
I have the Tarmac 2 Clubsports, and have noticed some slipping in the ride height on my front right coilover. The locking nut on the plastic collar apparently isn't holding any longer. I was more than careful in the torque applied to the locking screw, but it appears that it's no longer going to hold.
My question is, are replacement collars available? Also, is it possible to fit a dual locking set of metal collars to this KW strut instead of relying on the plastic collar and lock screw? These are wonderful coilover - I absolutely love them - but this one piece seems to be an achilles heel in an otherwise amazing product from RCE .... @Racecomp Engineering
2013 Scion FR-S Hot Lava 6MT Current Mods: KW V3 Coilovers - Raceseng CasCam Plates - Volk TE37SL Black Edition 18x9 +45 - Dunlop Direzza ZIIs 255/35 - Tomei Expreme Ti 60S - FT86 SpeedFactory UEL Catted Header
#268 |
Interesting, we haven't seen that before on BRZ or our Impreza sets. We do have replacements, so please give us a call as soon as you can.
- Andy |
#269 |
Do you have a dual locking metal collars available for the Tarmac 2s?
#270 |
Drives: 2013 asphalt fr-s
My FRS on Tarmac 0s w/ rpf1s on 255/35 bf Goodrich tires
#271 |
#272 |
So I installed my Tarmac 0's this past weekend. Love the way they look and the ride is very nice. Only problem I am running into is my car veers off to the right when I brake and the brakes feel different. I have to push the pedal much harder than before.
Hoping I didn't damage any of the lines, but I don't see how I could have. The bolt that holds the line in the back left wheel didn't fit and it stripped the stock bolt. I had to use a different bolt and a nut just to hold it there. Any advice? I'm going to get an alignment today if that may be my issue. |
#273 | |
TEQSPORT Brand Manager
Drives: '24 GR86 + '16 FR-S
Are you certain that your ride height settings are consistent side to side? I'm not sure but maybe one side is slightly higher than the other and possibly contributing to the car being off balance under braking? Number of threads used/remaining on the strut collar are a good reference point to check ride height side to side.
#274 | |
- andy |
#275 | |
#276 | |
I Love custom Turbo kits
Drives: Limited BRZ
I believe your method of measurement is accurate, but check that threads left too.
#277 | |
I'll check the threads on each coil when I get home. |
#278 |
There's a good chance the alignment will help a lot. Check the brakes though.
- Andy |
#279 | |
Drives: 13 BRZ Limited WRB
I plan to live forever. So far, so good.
My Build - http://www.ft86club.com/forums/showthread.php?t=31925 |
#280 |
| Racecomp Tarmac II Clubsport coilover | JoeBoxer | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 47 | 11-16-2013 11:02 PM |
| Tarmac Zero Coilovers Specs? | tintumz22 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 18 | 06-13-2013 11:26 PM |
| KW CLUBSPORT COILOVERS W/ FREE SHIPPING FOR THE SCION FR-S/SUBARU BRZ!!! | NJA | Brakes, Suspension, Chassis | 7 | 03-30-2013 08:26 PM |
| Wheel Directory: Enkei ES-Tarmac 16x7.0 +45 | quik1987 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1 | 09-12-2012 12:24 PM |
| Toyota 86 Tears Up Tarmac at 2012 TAS (TRD, N1, HKS, Up Garage Models) + LFA Roadster | knoxviue | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 35 | 01-20-2012 01:44 AM |
