Old 08-17-2013, 06:51 PM   #1
DarkestBuddha
Drives: BRZ limited GBS
Perrin 3" catback exhaust - impression
soooo i just installed my perrin 3"
and i gata say. its awesome.
startup sounds beastly
Heres a quick vid with a gopro. with NO OTHER MODS.
stock front pipe / stock overpipe / stock headers
[ame]http://youtu.be/iI3j5VAdPEI[/ame]
and a slightly more exuburant vid using my galaxy s3
[ame]http://youtu.be/l2Re4BrgEso[/ame]
from 3rd and up half the sounds drops off tho. so cruising wont give you migranes.
the look is the same as the regular perrin catback.
also your gana need a deep socket and some right angle attachment for the wrench.
i had neither and didnt want to go to homedepot to get some
so i just tightened the clamps and bolts by hand.
the clamps where easy and you can feel when its tight enough.
the top bolt of the midpipe was the worst tho. no space to fit anything there expect maybe that right angle attachment i mentioned. i literally tightened that bolt in 1cm increments :\
if there was another way, PLEASE LET ME KNOW!. . .
all in all. im happy with the sound, look, and fitment.
DarkestBuddha is offline   Reply With Quote
The Following 2 Users Say Thank You to DarkestBuddha For This Useful Post:
DrDuquette (08-18-2013), PERRIN (08-18-2013)
Old 08-17-2013, 07:40 PM   #2
Turkish
Serial Cone Killer
Turkish's Avatar
Drives: '14 BRZ - WRB Premium 6MT
Any intakes mods? If so, have you noticed any gains at the wheels? Are you planning on going FI down the road? Looks good!
Sent from my SCH-I535 using Tapatalk 4
For those who hear him call...
... his name is...
C'THULHU
Turkish is offline   Reply With Quote
Old 08-17-2013, 07:54 PM   #3
DarkestBuddha
no intake mods.
thinking about FI, but really not sure.
if i do go FI tho, its gana be a turbo instead of SC
Old 08-17-2013, 08:57 PM   #4
humanshield
Drives: bucket
i really dig this setup, but i can't see the need for so little back pressure on an NA setup. but i suppose if a turbo is in your near future it makes more sense.
humanshield is offline   Reply With Quote
Old 08-17-2013, 10:55 PM   #5
Ross
Drives: 85 corolla gts
Once cams and other items become available to really help this motor breath I feel 3" will be the standard as it has become on so many other 4cy high out put applications.
Ross is offline   Reply With Quote
Old 08-17-2013, 10:58 PM   #6
TOZER
Drives: 2013 Whiteout FR-S
Your video makes me think I messed something up on mine lol my cold start idle and anywhere below 2.5k is almost raspy... yours is deep throughout the revs
but sounds beautiful
TOZER is offline   Reply With Quote
Old 08-17-2013, 11:13 PM   #7
kuhlka
Drives: 2013 BRZ Limited AT
Stock STI isn't even 3", so I have to think this is overkill on anything under 300whp.
kuhlka is offline   Reply With Quote
Old 08-17-2013, 11:21 PM   #8
Tansey86
Tansey86's Avatar
Drives: 2003 Subaru Outback
And a stock STI gains a lot from upgrading to a 3" TBE. Its about emissions from a stock standpoint, not whats best.
" I know a lot about cars, man. I can look at any car's headlights and tell you exactly which way it's coming. "
Tansey86 is offline   Reply With Quote
Old 08-18-2013, 12:14 AM   #9
Ross
I have seen 10 to 20 whp going from a 2.5" to 3.0" on a high compression 4cyl engines with large cams. No turbo just natural aspiration. These motors flowed air very well. I personally can not wait to see what these do, the fa20 that is, with head and cam upgrades possibly intake manifold, ect... only time will tell.
The Following 2 Users Say Thank You to Ross For This Useful Post:
humanshield (08-18-2013), PERRIN (08-18-2013)
Old 08-19-2013, 12:34 PM   #10
kuhlka
Did you do a separate dyno run with just the exhaust without the cams? Most people aren't going to be tearing their engine down, so internal changes are irrelevant for people like me who are simply trying to pick an optimal header-back solution.
If Perrin has stock vs Perrin 2.5 vs Perrin 3" (ideally on the same dyno, same car), it would go a long way toward helping me decide which exhaust to buy. Thus far I've narrowed my choices down to STI, Perrin, or Borla, but I'd like to see which one sounds the best and gives the biggest power bump.
If the power gains are about equal or better for the 3", I'd just go with that for long-term upgrade-ability.
Old 08-19-2013, 12:53 PM   #11
DarkestBuddha
one a sound note:
one reason i got the 3" over the 2.5 is because its a bit louder while still sounding like a perrin.
these exhausts are pretty quiet compared to others tbh, so i wanted that little boost in sound you get with the 3"
and imo i think these sound the best
it also gives you room for future modifications, because you never know what you might end up doing (vrooooom PSSSTTTT)
Old 08-19-2013, 01:11 PM   #12
Ross
I have not tested this on the FA20 yet. I have found those gains by only installing the exhaust and re-tuning for the extra air flow. If I was to purchase an exhaust I would personally look to a 3" as I would not want to be limited later. As well if you do not have a full 3" system and a good header then it would be a waste in my mind, unless you were planning to upgrade in the future. Plans change over time and if I decided time to pop some cams in, supercharge or turbo it, ect... I would not want to think I had to buy a new part that I already had purchased to support my ultimate goal.
Old 08-23-2013, 08:49 AM   #13
Jeffboyarrdee
Jeffboyarrdee's Avatar
Drives: 2013 Subaru brz limited wr blue
Is this resonated or nonresonated?
Jeffboyarrdee is offline   Reply With Quote
Old 08-23-2013, 09:07 AM   #14
Wonderbar
Driveway labs.
Wonderbar's Avatar
Drives: '13 BRZ Limited, 6sp, SWP
Guys, debating the performance qualities of an exhaust on our NA car is pointless. We have a 2.0 that the ecu limits any increase in horsepower. So long it sounds great and it looks great, that's what matters.
@PERRIN did do dyno testing on the 3" vs the 2.5" and it did in fact show higher gains. If it didn't, they wouldn't have built it. It's the same reason we can't talk Jeff into building a header yet. But it's not going to be enough to feel in the butt dyno, just the ear and smile dyno.
3" will be very nice once you go boosted. You're not doing anything negative to your performance in the meantime.
-'13 Subaru BRZ Limited, SWP. (Mods: Driveway Labs full aero, MCA, etc)
-'06 Mitsubishi Eclipse 3.8L, UV blue. (Mods: turbocharged, full suspension, too much to list)
-'13 Town and Country Limited (Mods: too many kids)
Wonderbar is offline   Reply With Quote
The Following 2 Users Say Thank You to Wonderbar For This Useful Post:
mtsui (08-25-2013), PERRIN (08-23-2013)
Perrin 3" Catback Exhaust Group Buy!! Check it out!! Mike@CZP Groupbuys 1190 06-01-2018 01:27 PM
FEELER: Perrin 3" Catback Groupbuy DarkestBuddha Groupbuys 56 02-02-2016 04:53 PM
PERRIN Big 3" Catback DAN_BRZ Engine, Exhaust, Transmission 95 04-28-2014 07:19 PM
Perrin 2.5" Non Res Catback Pudge Ate Me Engine, Exhaust, Transmission 8 06-08-2013 02:11 AM
Perrin Catback Exhaust vs Nameless Performance Exhaust. vignesh Engine, Exhaust, Transmission 201 06-05-2013 10:47 PM
