Old 07-15-2013, 02:13 PM   #71
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Wanted to update this thread with my opinons on the Full Blown oil cooler kit. The majority of the pieces are off the shelf Mocal items and your standard AN oil lines. The only truly custom piece is the mounting bracket for the outside of the oil cooler that connects under the passenger side headlight. This is similar to the Perrin kit that only contains stand offs for the bottom of the oil cooler. I was e-mailed a set of directions, and they had good pictures that made sure I knew where things were supposed to go and made recommendations such as using high temp sealant on the fittings going into the oil cooler instead of teflon tape (which I usually use).
You will need to take special care when mounting the oil cooler to make sure that you leave clearance for the driver side fitting on top of the oil cooler. It is very close to the bracing that comes out and holds the bumper bar. I would recommend you install the fittings on to the oil cooler before mounting it and tightening everything down. The driver side of the oil cooler mounts to a hole in the bottom radiator core support. That happens to be the hole that the Full Blown turbo kit uses to remount the horn. The instructions didn't mention that, but I just relocated it to the bolt that holds the A/C condensor to the radiator. The only real downside to the kit was that both oil lines were about a foot too long. I had to take each AN fitting apart and cut the lines to the proper length and reassemble. Since the kit tells you exactly where to run the lines, I would have expected them to be the correct length, but I understand a little flexibility for possibly needing to modify that routing. At the end of the day, the kit fits great and had no leaks:
The Following 8 Users Say Thank You to King Tut For This Useful Post:
akuhei (07-15-2013), Dezoris (07-15-2013), Dipstik-sportech (07-15-2013), FullBlown (07-15-2013), Kiske (10-29-2014), Pitman (07-20-2013), pmccut (07-15-2013), Sportsguy83 (07-15-2013)
Old 07-15-2013, 02:42 PM   #72
Dezoris
Dezoris's Avatar
I really need to re-do my lines seeing that. You running -10AN fittings?
Old 07-15-2013, 02:59 PM   #73
King Tut
NASA SpecE30 Racer
King Tut's Avatar
-10 sounds right to me. LJ @FullBlown would be better to answer that.
Old 07-15-2013, 03:08 PM   #74
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
Can you post oil temps before and after?
post_break is offline   Reply With Quote
Old 07-15-2013, 03:12 PM   #75
FullBlown
FullBlown's Avatar
Drives: Scion FRS
They are all -10 lines.
FullBlown is offline   Reply With Quote
Old 07-15-2013, 03:13 PM   #76
King Tut
NASA SpecE30 Racer
King Tut's Avatar
I will try and get some good logs tonight to compare to my logs before the oil cooler install. Here is my before post:
I have some more data for you. Over the course of 25 minutes I did twelve 3rd gear pulls from 2700 RPM to 8000 RPM on my Full Blown kit with no cooling modifications. My peak oil temp was 131C or 268F according to EcuTek. Ambient temp was in the 60s.
Ambient temp tonight will most likely be in the 80s.
The Following 2 Users Say Thank You to King Tut For This Useful Post:
Jrdad (04-07-2017), post_break (07-15-2013)
Old 07-15-2013, 03:43 PM   #77
Sniper2606
Sniper2606's Avatar
How safe will this run in the winter time, cold start?
Sniper2606 is offline   Reply With Quote
Old 07-15-2013, 03:50 PM   #78
King Tut
NASA SpecE30 Racer
King Tut's Avatar
It has a thermostat, so I assume it will work as well as any other car that has an OEM oil cooler. On cold start the oil will be cold anyways, the thermostat will allow it to warm up as soon as possible. If you are really worried you should have an engine block heater to prewarm the oil.
Old 07-15-2013, 04:07 PM   #79
dabocx
dabocx's Avatar
Drives: Scion FRS
Should be ordering this later this month, I am thinking about removing the washer fluid bottle and mounting it in that area instead.
dabocx is offline   Reply With Quote
Old 07-18-2013, 11:35 PM   #80
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Before:
65F Ambient Temp
25 minutes
12 3rd Gear Pulls from 2500 RPM to 8000 RPM
131C/268F Oil Temps
After:
85F Ambient Temp
4 minutes
7 3rd Gear Pulls from 2500 RPM to 8000 RPM
111C/232F Oil Temps
The Following 7 Users Say Thank You to King Tut For This Useful Post:
Boba_kz (05-28-2014), FullBlown (07-24-2013), jamesm (07-19-2013), post_break (07-18-2013), Sportsguy83 (07-19-2013), Thorpedo (02-14-2015), whataboutbob (07-19-2013)
Old 07-18-2013, 11:47 PM   #81
post_break
post_break's Avatar
Before:
65F Ambient Temp
25 minutes
131C/268F Oil Temps
After:
85F Ambient Temp
4 minutes
111C/232F Oil Temps
That's hot. (before) But it's amazing because of the location of the radiator. I think it's safe to say I'm sticking mine behind the fogs as well since it's obviously still working.
Old 07-19-2013, 12:18 AM   #82
jamesm
Yeah that's awesome. Ill probably put one in the same place. I was going to open up the mesh on that one side but it definitely doesn't seem necessary.
Old 08-17-2013, 09:18 PM   #83
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Originally Posted by tonystewart View Post
How did you stop the leaks? Every connection is leaking, except the sandwich adaptor fittings.
All AN fittings, the two at cooler and the two at fittings leak, I have tightened them to death.
I used sealer for the sandwich adaptor fittings. Am I supposed to use them on the an fitting as well?
Thought that would contaminate system.
Any help before i take this leak maker off the car.
I can't believe these fittings! All my years Ive never seen anything I couldn't stop from leaking.
Well I don't know how you can blame Full Blown for off the shelf AN fittings leaking. The answer is NO you don't use any sealant on AN fittings. My only suggestion would be to tighten them some more. I only used high temp sealant on the angled fittings that go into the sandwich plate.
Old 08-17-2013, 10:50 PM   #84
FullBlown
FullBlown's Avatar
Drives: Scion FRS
Buddy, which fittings leak. Please let us know, we alot of kits out there without any issues. Call us monday and I will send out a new line/fitting kit.
Oil Cooler wootwoot Engine, Exhaust, Transmission 92 12-27-2014 08:10 PM
ARC Oil Cooler ill86 Engine, Exhaust, Transmission 19 10-18-2014 04:30 PM
One-Off Oil Cooler? wootwoot Engine, Exhaust, Transmission 37 07-18-2014 05:42 PM
You want it, you got it: PERRIN Oil Cooler GB JoeBoxer Groupbuys 96 06-16-2013 03:10 PM
Best oil cooler whitefrs Engine, Exhaust, Transmission 4 02-21-2013 11:36 PM
