Old 08-10-2013, 01:48 PM   #379
Darryljr11
Sideways and Smiling!
Darryljr11's Avatar
Drives: Scion FR-S
Too bad these PID's dont work with engine link for the iphone
Element Tuning 10:1 Pro Comp Long Block, Ptuning SS GT3076R turbo kit, Exedy Stage 2 Clutch, and a bunch of other stuff
Darryljr11 is offline   Reply With Quote
Old 08-12-2013, 02:49 AM   #380
Kostamojen
I just discovered these Bluetooth adapters... I'm buying one now and going to test the Torque ap with my Nook HD+ 8.9" before my BRZ gets here
I'll report back when my scanner tool arrives...
Old 08-12-2013, 09:50 AM   #381
yamsta
daGangsta
yamsta's Avatar
Drives: 2013 FR-S 6MT
Originally Posted by pixel67 View Post
Go to google play and force the update of torque. Mine now senses bt but still acts weird and freezes occasionally.
Sent from my SPH-L710 using Tapatalk 2
This seems to have fixed the connection issue. I'll play around with it some more and see if I get freezing and what not.
yamsta is offline   Reply With Quote
Old 08-13-2013, 08:10 AM   #382
Hoey
Drives: Black GTS
hmm...I seem to be having trouble reading Custom PIDs.
I bought one of those cheap OBD adapters (BT) from ebay.
normal guages work but custom PIDs like the Oil Temp and and Fuel remaining doesn't seem to work.
Any ideas?
Hoey is offline   Reply With Quote
Old 08-15-2013, 10:15 PM   #383
Kostamojen
I got it to work on my Galaxy S3 on both the Forester and Lexus CT200h (getting it setup for the BRZ when I go pick it up) but I can't get my Nook HD+ to use the PIN# for the adapter and its frustrating...
I REALLY want to use the Nook cause of the 8.9" display!
Old 08-16-2013, 08:10 AM   #384
yamsta
daGangsta
yamsta's Avatar
You may need to root the nook if possible. The 1st gen Nexus 7 is going for super cheap these days and that thing works nice with Torque.
Newegg has the refurbished Asus NEXUS7/1B16 Nexus 7 16GB Android Tablet (1st Generation) for $150 - 10% off with coupon code VME10BTS [Exp 8/19] (when you check out with V.me by Visa) - $20 rebate [Exp 8/16] = $115 with free shipping.
Old 08-16-2013, 03:22 PM   #385
AdrianG
Generally Well Liked
Drives: '08 STi Hatch, '11 Outback 3.6R
Is anyone else having trouble with the Oil Temperature PID?
I'm getting values all over the place and definitely not the results I'd expect to get. When graphing the value jumps around like crazy. It's definitely reading data but there's no way it's the oil temperature, as it registers in the negatives on a warm summer day after the car's been running for a half hour.
AdrianG is offline   Reply With Quote
Old 08-16-2013, 03:45 PM   #386
mikalem
mikalem's Avatar
Drives: 2020 DGM BRZ Limited
I use it to monitor mine with w oil cooler installed and it registers correctly, I would double check your pid and calculation
Sent from my SGH-M919 using Tapatalk 4
mikalem is offline   Reply With Quote
Old 08-16-2013, 06:53 PM   #387
AdrianG
Here is a screenshot, I don't see any mistakes but if anyone has any input it would be greatly appreciated.
Sent from my Nexus 7 using Tapatalk 4
Old 08-16-2013, 08:56 PM   #388
Hoey
Drives: Black GTS
Same Adrian G.
It might have something to do with the adapter settings?
Have to borrow someone else's cheapo adapter to check.
Anyone here can shed some light?
Thanks.
Old 08-16-2013, 09:49 PM   #389
dsrttigr
"GOD ARM"
dsrttigr's Avatar
Drives: 2013 Toyota GT-86R E85 Tuned
I set mine for 0 and 500 for min and max temps, since I have it set for Fahrenheit not Celsius.
dsrttigr is offline   Reply With Quote
Old 08-16-2013, 11:02 PM   #390
AdrianG
It must be an issue with my adapter. With my Scantool.net OBDLink SX my oil temperatures are all over the place:
This is with the car fully warmed up.
I get stable numbers with my V-Link wifi adapter though.... Unfortunately it reads a lot slower than the OBDLink.
Anyone have any ideas?
Old 08-27-2013, 04:25 PM   #391
aagun
Drives: 86
interesting
aagun is offline   Reply With Quote
Old 08-27-2013, 04:43 PM   #392
Yruyur
Yruyur's Avatar
Perhaps the interval?
Sent from a Motorola DynaTAC 8000X
android, app, boost, gauges, torque
Torque app for android question Brody602 Electronics | Audio | NAV | Infotainment 8 01-08-2015 04:53 PM
Torque for Android Freeman Scion FR-S / Toyota 86 GT86 General Forum 7 11-22-2012 11:05 PM
Android Torque app questions Craig Engine, Exhaust, Transmission 1 11-12-2012 04:14 PM
Bluetooth OBD scanner and Android Torque - less than 25 shipped whataboutbob Engine, Exhaust, Transmission 7 10-20-2012 01:15 PM
Android Tablet + torque CharlieChaos Electronics | Audio | NAV | Infotainment 3 10-04-2012 08:23 PM
