Old 08-15-2013, 10:41 PM   #225
pleong
Drives: 2013 Whiteout FR-S
this was an AMAZING DIY video and write! thanks for posting this!
pleong is offline   Reply With Quote
Old 08-15-2013, 11:59 PM   #226
DriftEm
DriftEm's Avatar
Originally Posted by mikalem View Post
Back from the dealership - what ended up being replaced was the entire hose from the metal fitting to the side of the sensor coupling. Pictures are attached - they reused the clamp, but it's not tightened on very tight and I can physically see the bulge in the rubber hose - gives me a feel good on the seal being created. See pictures for the changes, sorry I don't have any before but it used to look very close to the DIY pics, as that was what I was working from in the beginning.
Do you have the details for the hose they used? part number, size, brand.
thanks in advance.
DriftEm is offline   Reply With Quote
Old 08-16-2013, 12:36 AM   #227
Sensisnow
Drives: 05 TSX & 13 BRZ
thanks in advance.
I'm not sure about the length, but this hose would work.
http://www.summitracing.com/parts/dac-80079/overview/
They also offer it in 10ft. lengths, which I'm sure you could cut down and sell to other people looking for an alternative.
2013 DGM BRZ
Visconti STG2 FlexFuel Tune - aFe intake - Perrin resonated catback - P&L header, front pipe, & overpipe - Kartboy short shifter - Eibach prokit springs - Smoked sidemarkers - Full LED interior/exterior - Kenwood cmos-210 backup camera - Hardwired Valentine V1
Sensisnow is offline   Reply With Quote
Old 08-16-2013, 06:58 AM   #228
mikalem
mikalem's Avatar
Drives: 2020 DGM BRZ Limited
thanks in advance.
Unfortunately I don't know specifics on the part and/or size - the only markings on the hose itself are visible in the pictures I provided the day I brought it back from the fix. Trying to locate the receipt to see if there was a part number mentioned on it, will post back if I find it.
mikalem is offline   Reply With Quote
Old 08-16-2013, 08:11 AM   #229
mikalem
mikalem's Avatar
Couldn't find the invoice but I'll do you one better - stopped by the dealership on the way to work and got a sample of the hose that was used, included is a picture of the markings. Looks to be a 5/16ths ID fuel hose, goodyear manufactured.
Old 08-16-2013, 11:32 AM   #230
2superblus
2superblus's Avatar
Drives: 13 BRZ WRB
This looks to be the hose used for the Visconti kit. However I am not 100%, but each manufacturer uses traces colors in the braid to mark their hose.
http://www.russellperformance.com/mc...oclassic.shtml
Is that Goodyear hose E85 rated?
As far as I am aware the only braided racing hose that is E85 rated has a PTFE liner (aka Teflon). Rubber lined braided racing hose does not last with E85 it does get soft and seep or split in time.
2superblus is offline   Reply With Quote
Old 08-16-2013, 12:08 PM   #231
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
This is all it says for the Dayco stuff.
"Constructed with a fluoroelastomer, low-permeation, gasohol and diesel fuel inner tube, they provide exceptional resistance to alcohol blended fuels that commonly weaken normal fuel injection hoses."
post_break is offline   Reply With Quote
Old 08-16-2013, 12:08 PM   #232
mikalem
mikalem's Avatar
I believe it is - [ame="http://www.amazon.com/gp/aw/d/B000C30MKI"]Goodyear 65128 SAE 30R7 Fuel Line/ PCV / Emission Control Hose:Amazon:Automotive[/ame]
Sent from my SGH-M919 using Tapatalk 4
Old 08-16-2013, 12:36 PM   #233
accelerated
Drives: Scion FR-S
Just a heads up but 30R7 hose is not a high pressure rated hose nor is it ethanol rated and should not be used in this application. While it has a burst pressure of 250PSI, it's working pressure is 50psi. The correct high pressure hose is 30R9. It has a 100PSI working pressure with a 900PSI burst pressure and it is ethanol rated.
50PSI 30R7 Fuel Hose
http://www.goodyearep.com/productsDetail.aspx?id=6088
100PSI 30R9 Ethanol Fuel Injection Hose
http://www.goodyearep.com/productsdetail.aspx?id=5144
Regards
accelerated is offline   Reply With Quote
Old 08-16-2013, 12:44 PM   #234
mikalem
mikalem's Avatar
250PSI 30R9 Ethanol Fuel Injection Hose
Regards
Not so concerned about the pressure as it's on the low pressure side of the fueling system - am a little concerned on the fuel rating however as I've read elsewhere that 30R7 will support ethanol enriched fuels (see my other post). Thanks for providing the links and info!
Edit* This is the link for the hose I pictured: http://www.goodyearep.com/ProductsDetail.aspx?id=17820
Last edited by mikalem; 08-16-2013 at 12:46 PM. Reason: missed a t, added url for hose
Old 08-16-2013, 12:48 PM   #235
accelerated
Drives: Scion FR-S
^^^ Corrected my previous post as 30R9 has a working pressure of 100PSI, NOT 250. No idea how I erroneously typed that twice.
Old 08-16-2013, 01:07 PM   #236
post_break
post_break's Avatar
Which size would we need to order?
Old 08-16-2013, 01:39 PM   #237
accelerated
Drives: Scion FR-S
From what @enouf has said in other threads, the hard fuel tubing is ~7.5mm OD so you would want to get the 5/16" ID hose.
Perhaps @FA20Club.com would sell the hoses and fittings he is using with his kit to those that are having issues with leaks.
Old 08-16-2013, 01:45 PM   #238
Yruyur
Yruyur's Avatar
Im getting fa20clubs line next week. I have the uodated kit so the sensor is the same as their kit.
Does anyone know if the diameter changed from the first sensor to the updated? If it didnt then fa20club's line should work for everyone.
Sent from a Motorola DynaTAC 8000X
campaign: ban jv, diy, e85, fuel leak, kit, laughing to the bank, oh lord jesus its a fire, visconti, viscontifried, viscontinued
Flex fuel testing Dynotronics1 Southwest 5 06-22-2013 03:27 PM
FA20CLUB Flex Fuel Kit Ready FA20Club.com Engine, Exhaust, Transmission 16 05-22-2013 11:04 AM
ECUtek Flex Fuel REVOLUTION: World's First Flex Fuel Factory ECU GTR - BRZ soon! Visconti Engine, Exhaust, Transmission 356 05-20-2013 09:36 AM
Cheap flex fuel? nix Engine, Exhaust, Transmission 1 05-11-2013 04:05 AM
Flex Fuel? VenomRush Scion FR-S / Toyota 86 GT86 General Forum 12 01-15-2010 02:55 AM
