Old 08-10-2013, 08:51 AM   #43
feldy
feldy's Avatar
Drives: 2013 FRS Asphalt
Originally Posted by (fr-s) View Post
If you're wanting to have warranty work done on your modified car you'd be a fool not to replace with stock IF THAT'S AN OPTION for you. Seems like common sense. Why give the dealer any sliver of a reason to back you into a corner with the whole "modified car spiel"? If you have the ability, go back to stock.
I like being somewhat honest here. I'm on lowering springs and konis the car is getting looked at in 30 minutes no time to swap.
2013 Scion FR-S AT Picked up 5/30/2012
feldy is offline   Reply With Quote
Old 08-10-2013, 04:59 PM   #44
BlaineWasHere
Grip>Drift
BlaineWasHere's Avatar
Drives: FRS
You're not nearly as low as me, AND you car is an auto, I'd say that helps you in terms of "is this a competition car." Let us know what happens.
Old 08-10-2013, 05:00 PM   #45
BlaineWasHere
Grip>Drift
Drives: FRS
Did your carrier assembly also split in two like in the picture above? Wondering if that part of the axle is serviceable to save buying a new axle everytime.Also do you have a list of the part numbers needed to fix this?
Yes, exact same failure as pictured.
Old 08-10-2013, 05:19 PM   #46
husker741
Drives: 2013 Whiteout Scion FR-S 6MT
Let us know how this goes and what they say.
husker741 is offline   Reply With Quote
Old 08-15-2013, 07:39 PM   #47
feldy
feldy's Avatar
Just got word I have a new axle at the dealer waiting to be installed. Yay
Old 08-15-2013, 08:33 PM   #48
husker741
Are they covering it under warranty? If so, I need to figure out how they can for me because I'm lowered also.
Old 08-15-2013, 09:45 PM   #49
feldy
feldy's Avatar
Yes. I'm on koni yellows and Rce springs. Also a automatic. First thing he said was normally he sees this on a manual car but not a auto. Not sure if that helped my case. Never once did he mention the car was lowered. However I did mention to the service dude first that a member who got denied was due to being lowered a ton. I'm only lowered the same amount recommend by Trd and I'd be pissed if I was denied. To be honest I didn't know it was coming. He torqued the nut Saturday Monday they asked me if I was still hearing it. I said only when putting it into gear but not like I had. Which is the truth I was hearing it on acceleration and decell. But now only hearing when brake torquing the car to launch it. You can bring me up but I don't want my info being given to them. Don't need to be thrown under the buss.
Old 08-15-2013, 10:05 PM   #50
husker741
Oh I know, I would just say "another member" and keep it as general as possible. Thank you for that info! Where have you seen the thing about what TRD says to lower it? I'm on stock struts with RCEs.
Old 08-15-2013, 10:35 PM   #51
BlaineWasHere
Grip>Drift
Drives: FRS
Glad you're getting warranty coverage on this!
Old 08-16-2013, 12:18 AM   #52
feldy
feldy's Avatar
The Trd coil over is either 15mm drop or 20mm. The Rce springs are 20mm.
Old 08-18-2013, 05:20 PM   #53
Carwhisperer
Drives: A lot of supercars.
I've had the clicking/ticking from the front right axel for 7-8kish miles. Guess I should watch out now.
Carwhisperer is offline   Reply With Quote
Old 08-18-2013, 07:13 PM   #54
BlaineWasHere
Grip>Drift
Drives: FRS
Ummm... there is no axle in the front of the car.
Old 08-19-2013, 05:08 AM   #55
WillRacer1jz
Drives: 1987 JZA70 Supra, 2013 FR-S
My drivrs side axel started clicking :-( time to make an appointment at the dealership. My car is all stock except for a k&n filter.
WillRacer1jz is offline   Reply With Quote
Old 08-27-2013, 09:57 AM   #56
TRev
My driver axle has started clicking as well. It comes and goes but is mostly only present when I first start driving the car after it has been sitting. I can recreate the issue even when not present by loading up the car against the e-brake. Not what I wanted to deal with right before Nationals but better than it breaking out there. May have to just order one and put it in myself as I don't think the dealer will be able to get through the warranty process prior to me leaving for Lincoln.
TRev is offline   Reply With Quote
DDM HID Problem LinknLog Cosmetic Modification (Interior/Exterior/Lighting) 18 04-11-2013 12:43 PM
A bit of a problem Gost Other Vehicles & General Automotive Discussions 13 02-12-2013 07:07 PM
Problem! axss Scion FR-S / Toyota 86 GT86 General Forum 32 11-24-2012 02:31 PM
ABS Problem chrislee2423 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 2 07-09-2012 04:06 PM
anyone with this problem? debs0712 Scion FR-S / Toyota 86 GT86 General Forum 2 06-30-2012 10:17 AM
