Old 08-14-2013, 03:59 PM   #953
Subzero
Old...
Subzero's Avatar
Drives: Subaru
Originally Posted by evo4g63 View Post
It's more of a pop type sound
Could it be the recirc diaphragm / butterfly slamming shut? You could see that on a dyno run or maybe with a go-pro under the hood.
Subzero is offline   Reply With Quote
Old 08-14-2013, 05:37 PM   #954
evo4g63
evo4g63's Avatar
Drives: 2016 Subaru WRX
Originally Posted by tech4pdx View Post
@evo4g63 Are you on the stock clutch?
I am on the stock clutch and flywheel
If you want to make the drive to tucson on friday night for our local meet, I'll be more than happy to demonstrate said noise for you. And maybe I'll get abatter idea of whatever popping noise you're experiencing sounds like.
I may take you up on that. It's easy to replicate like I said. WOT and shift at high rpm. You'll hear it each time. There are the other ways as I mentioned to replicate but this is the easiest to do so.
We are hosting a dyno day out here on the 23rd and 24th. Toni @FA20club is coming down to tune some vehicles. I am just paranoid due to DI issues.
-2016 Subaru WRX
-2013 Scion FR-S: Wastegated Vortech V3'd, E85 SOLD
evo4g63 is offline   Reply With Quote
Old 08-14-2013, 05:46 PM   #955
MattF
MattF's Avatar
Drives: s13<EP3<s14<RSX TYPE-S<WRX<GTI<FR-S
Anyone else running the fa20club tune? If so how many revisions have you gotten and are you seeing any lean spikes or shuddering below 3k under partial throttle? I am seeing lean spikes up to 19 on my latest tune.
MattF is offline   Reply With Quote
Old 08-14-2013, 06:08 PM   #956
NickFRS
Drives: 2013 Asphalt FRS
Originally Posted by DriftEm View Post
I was actually asking about Nick (the guy with 14 flat), sorry I wasn't clear.
245/45/17 Federal 595's with -2.2 camber in the rear. I also was still spinning the tires in 1st n 2nd. I'll be going out again sometime soon and actually airing down the tires + working on a perfect launch to break mid 13's
2013 Sion FRS
2014 Subaru WRX
2014 Subaru XV
NickFRS is offline   Reply With Quote
Old 08-14-2013, 06:53 PM   #957
mad_sb
Drives: 2013 Asphalt FR-S
Originally Posted by sw20kosh View Post
This is interesting and worth discussing. Why are the MAP sensors failing?
I don't think the sensors are failing, i think they are hitting max voltage for a pre determined (by the ecu code) amount of time / capped out. The solution is to install a map sensor with a wider range and redo the map scale table in the rom.
From the FSM:
P0108
Manifold absolute pressure sensor voltage is 3.906
V or more for 2 seconds or more.
(1 trip detection logic)
The cheap fix is to disable to CEL in the rom. the Proper solution is to install a sensor with more range and calibrate it properly since there are port injector scale tables that rely on the map sensor output as an input. Sorta like boost comp tuning on AEM.
Old 08-14-2013, 07:47 PM   #958
MattF
MattF's Avatar
I am thinking of upgrading my map sensor for when the stage 2 kit comes out. Any one purchased one they would recommend?
Old 08-14-2013, 11:16 PM   #959
invisage
Drives: Thunder Silver 86 GTS
Here in Perth Sprintex provided a 2.5 bar MAP sensor with their kits (which includes the intercooler). I will find out what make/brand it is for you.
invisage is offline   Reply With Quote
The Following 2 Users Say Thank You to invisage For This Useful Post:
MattF (08-15-2013), tech4pdx (08-14-2013)
Old 08-14-2013, 11:21 PM   #960
Carwhisperer
Drives: A lot of supercars.
Originally Posted by ft_sjo View Post
A crackling noise from the front?
Hey I get this once the engine is warmed on a couple of WOT's NA in 1st gear.
Is that "Normal"?
Carwhisperer is offline   Reply With Quote
Old 08-14-2013, 11:21 PM   #961
tech4pdx
Make love
tech4pdx's Avatar
Drives: H8R.. Not really
Just another thing we got screwed out of here in the US..
tech4pdx is offline   Reply With Quote
Old 08-14-2013, 11:23 PM   #962
xjohnx
Grip>Slip
xjohnx's Avatar
I believe @moto-mike is working with the omni 3bar, awaiting details on that one.
Old 08-15-2013, 12:40 AM   #963
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
Just added @Ethan to the list... he got his S/C installed today!
The Following User Says Thank You to DarrenDriven For This Useful Post:
lbroskee (08-15-2013)
Old 08-15-2013, 01:07 AM   #964
wrxgoose
WUB WUB
Drives: 2013 Firestorm
o.O just found out that Rockingham is doing a TnT this saturday evening. I may have to go play with the big boys. See what I can get out of her
wrxgoose is offline   Reply With Quote
Old 08-15-2013, 09:23 PM   #965
evo4g63
evo4g63's Avatar
Still have this annoying noise. I have checked the car over and over. Good news is that it's not the DI popping sound. After watching several vids on this I am at least that much relieved. I just wish I could figure it out as its a thorn in my side.
-2016 Subaru WRX
Old 08-15-2013, 09:25 PM   #966
tech4pdx
Make love
tech4pdx's Avatar
Can you get a recording?
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
