Old 08-07-2013, 09:41 AM   #57
Belial86
Drives: 2013 FR-S MT firestorm
Anybody know what the settings between are for?
Belial86 is offline   Reply With Quote
Old 08-15-2013, 05:06 PM   #58
MFPC
MFPC's Avatar
Drives: 2013 Subaru BRZ
I wanna give my input.
A/C blows pleasantly cold when I'm driving normally, but as soon as I rev past 4500rpm, it's like the A/C turns off and starts blowing outside air.
In other words, any sort of aggressive driving with the A/C on will lead to non-cold air.
Of course... who the hell drives aggressively with A/C on? lawl.
Normal or abnormal? Input?
MFPC is offline   Reply With Quote
Old 08-15-2013, 05:13 PM   #59
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
The A/C clutch disengages under heavy acceleration. It's normal.
-alex
Old 08-15-2013, 10:01 PM   #60
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
I really would like the A/C on the coldest option to be a setting where I never want it to be at .. that way I'd be able to reach a temperature that I find comfortable
as is im still sweating on the max settings on set 3 which is freaking loud too
sure on the freeway going +50 mph it feels good after a while but local streets im melting even after getting off the freeway.
I just don't think this is acceptable and debating trying to find ways to make the a/c stronger
Old 08-15-2013, 10:38 PM   #61
kALMIGHTY
Drives: TRD Ultramarine '13
Mine blows really cold air even on the "1" position. The highest I've ever gone is the "2" position because anything after that, it gets uncomfortably cold.
I live in Calgary, so I'm perfectly okay with cold temperatures, and even then 3 and 4 are a little uncomfortable.
Old 08-16-2013, 12:36 PM   #62
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
What's the hottest temp in Calgary usually? Looks like your record high is 96 degrees, the poster above you has several months above that temperature and probably sees a few days above 105. I've had very few issues with the A/C when it's under 95 outside but it takes awhile to counterract the hot engine sitting 6 inches away from your feet and the black interior that's been baking in the sun.
When it hits 100+ though, it's fighting a losing battle, especially if you've got direct sunlight coming in the windows.
ineedyourdiddly
Old 08-16-2013, 03:50 PM   #63
kALMIGHTY
I'd say average summer days are usually between 25-30 C, which would be between 77 and 86 for you Americans. So it's not overly hot to begin with I suppose.
I guess we'll see how true the opposite is when the winter hits and we hit -31 Fahrenheit here and we'll have to start a thread called "How hot is your heater blowing?"
Old 08-17-2013, 12:12 PM   #64
*KID*
86-er
*KID*'s Avatar
Drives: BRZ tS
I live in south Texas. Outside temperatures are at 100+ . I run the AC on HIGH and stop and go traffic the compressor shuts off till I hit the highway. I don't know why the AC shuts off often.
2018 Subaru BRZ ts 020/500 - My Daily, work car, and track car
*KID* is offline   Reply With Quote
Old 08-17-2013, 12:28 PM   #65
Mikem53
Drives: FR-S 6MT
it doesnt shut off.. low rpms and no airflow over the condenser doesnt allow it to work effectively at idle or low speeds..
Mikem53 is offline   Reply With Quote
The Following User Says Thank You to Mikem53 For This Useful Post:
*KID* (08-17-2013)
Old 08-18-2013, 02:51 AM   #66
(fr-s)
Drives: 2013 fr-s 6sp
Mine blows ice cold. I live in dallas with temps usually upwards of 100. I rarely turn past 2 on my AC dial. Normally I end up getting chilly.
(fr-s) is offline   Reply With Quote
Old 08-18-2013, 03:41 AM   #67
Burrcold
Drives: Subaru BRZ Limited
You just have to know how to get the temperature down quickly. Open the windows, and put the AC on so that it's pulling outside air. As soon as the stale heat drops a bit inside the cabin, put it on recirculate and put the windows back up.
Old 08-18-2013, 03:44 PM   #68
mike the snake
My AC I can feel it cycling on and off, the air going from icy to just cool, back and forth.
Is there anything the dealer can do to change the parameters of the AC controls to mkae it stay on more?
I'd really like my AC to run colder than it does. I know it has it in it, because every 20-30 seconds it gets nice and cold, but then it clicks off and then it's not so super cold. I want COOOLLLD
Old 08-18-2013, 04:29 PM   #69
Celica00
Celica00's Avatar
Drives: 86
mine is pretty damn chilly. I usually have it near the center of hot and cold just so it isn't overwhelming
Celica00 is offline   Reply With Quote
Mind-blowing features of the next model BRZ Baldoak BRZ First-Gen (2012+) — General Topics 89 08-28-2013 07:59 PM
Passenger side HID Ballast keep blowing CharlieChaos Cosmetic Modification (Interior/Exterior/Lighting) 3 04-13-2013 01:13 PM
it to cold Pekingduck Southern California 9 01-05-2013 09:08 AM
Did the issue with the air vents blowing hot ever get resolved? fiveoneoh Scion FR-S / Toyota 86 GT86 General Forum 25 09-05-2012 02:21 AM
A/C Compressor blowing hot? Is this normal? SocalBurt Engine, Exhaust, Transmission 3 08-22-2012 08:10 AM
