Old 08-15-2013, 03:12 PM   #43
Ryan86
Road Warrior
Ryan86's Avatar
Drives: Toyota 86 Satin Pearl White
Excellent well done. You going to love the sound.
Ryan86 is offline   Reply With Quote
Old 08-15-2013, 04:49 PM   #44
chadstyle
chadstyle's Avatar
Drives: 2013 Subaru BR-Z Limited
Originally Posted by Ryan86 View Post
I might be wrong after all.
If I take my base stock run with no mods and compare to mods,
AFE Dif
Zeta intake
Borla header
Stock overpipe
HPC front pipe
Resonated rear
Visconti Stage 2
I used 93 equivalent fuel
I've got 22 whp gain and 20 nm torque gains.
We have almost the same mods, you have. FA20club tune
What is your take on my chart vs yours (1kw = 1.34whp)
Let me know if chart is inverted
It's hard to tell what's going on with your chart.. The TQ is scaled differently than the HP it seems and without your baseline to overlay its even harder to see where you made the most gains. What kind of dyno did you use?
chadstyle is offline   Reply With Quote
Old 08-15-2013, 07:35 PM   #45
sw20kosh
Drives: 2013 Black FR-S
This is sorta OT but no one has tried out the EL header + pump gas tune?
I know FT86speedfactory did a dyno with the EL but with no tune.
Robi did one with the EL but he tuned it on E85 and got 200 whp.
Old 08-15-2013, 08:21 PM   #46
mrk1
Drives: Sterling BRZ Ltd
I'm also curious about the EL, would like to see how they handle the dip
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Old 08-15-2013, 09:01 PM   #47
Ryan86
Road Warrior
Ryan86's Avatar
@chadstyle
I have been using a Inertia Dyno. The graph layout is different.
The red line is my base run, black is mods and tune.
17kw gain = 23whp
Visconti tune and Borla seems to also give strong mid torque gains too.
Old 08-16-2013, 09:27 AM   #48
PhastekSport
PhastekSport's Avatar
Send a message via AIM to PhastekSport Send a message via Yahoo to PhastekSport
Update:
A customer just sent me a picture of their Borla UEL header cracked before the collector. We'll probably get that one warrantied out, but he's going to be purchasing a different brand this time around.
Major mods to note about his vehicle - Vortech kit.
I'll be checking ours regularly now.
PhastekSport is offline   Reply With Quote
Old 08-16-2013, 09:33 AM   #49
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
Originally Posted by Chris@Phastek View Post
Update:
Another Borla header QC failure. Not surprised.
I thought the warped flanges were bad, but these weld failures at the collector seem like the final nail in the Borla coffin.
Is that @F1point4 's out of curiousity?
The Following 2 Users Say Thank You to ATL BRZ For This Useful Post:
Hawk77FT (08-19-2013), JPxM0Dz (08-16-2013)
Old 08-16-2013, 09:36 AM   #50
PhastekSport
You're correct. Pretty sad.
A one million mile warranty is one thing, but it still should not be on the consumer to have to install, uninstall, return, rinse, and repeat.
Old 08-16-2013, 09:38 AM   #51
Taber
Drives: 2013 BRZ Limited
Well sheit ... you just took the wind out of my sails...
Taber is offline   Reply With Quote
Old 08-16-2013, 09:46 AM   #52
6speed_Sam
Thumper
6speed_Sam's Avatar
Drives: 2013 FRS
Damn! I just ordered one last night
Car is gone - parts for sale
6speed_Sam is offline   Reply With Quote
Old 08-16-2013, 09:48 AM   #53
PhastekSport
There's no guarantee this will be happening to every vehicle. When I leave work in the late afternoon my thermometer says about 105. Plus we do have superchargers.
However, I'm pulling this product from the site.
Old 08-16-2013, 10:09 AM   #54
Chimpo
Chimpo's Avatar
Drives: '15 STi Ltd
Was this recently failed header from a "new" one or one of the first runs?
Chimpo is offline   Reply With Quote
Old 08-16-2013, 10:16 AM   #55
PhastekSport
It was probably toward the end of the initial 30 we sold. After the negative publicity with the flanges, sales took a huge downward turn. Also I didn't try to push the header on anyone and gave honest feedback, both personal and observed.
According to e-mails between customers and Borla which I was CCd the biggest issue of course were the warped flanges. People had mentioned that the welds appeared sloppy on the inside of the collector, but Borla never addressed that directly in the correspondence I read.
Old 08-16-2013, 10:53 AM   #56
F1point4
Photo Specialist
F1point4's Avatar
Drives: 2013 Toyota 86 DGM 6MT
Update:
Yes that one is mine. Just a few things, I put 6000 miles and one track day on this header since I purchased it. It is only 5 months old. I think the track day made the weld crack. A local fabricator told me the pipe is cracked all the way around.
Two things clued me in to something was wrong. There was a vibration that was resonating throughout the car when I started her. I thought it was the metal engine pan, but it was definitely the pipe coming off the cracked weld on the collector.
The other was that my wideband AFR gauge was telling me I was lean. Logically to me this means my primary O2 was reading the same and making the car run rich. Not the worst problem to have, but my fuel trims are probably jacked and I shouldn't push the car while I have this header.
It is a bit disappointing to see a part fail, but I am confident Borla will warranty this piece. For this car I am an early adopter of most everything and this part is no different; I got one of the first ones. Hopefully their QC is better in the subsequent batches.
I opted not to get this fixed because the other welds may break in a similar fashion. In addition, I can't be sure the replacement won't suffer the same fate. Things are coming up in my life and I can't be constantly be pulling headers for warranty. Need my car to work like a champ. Therefore I opted to purchase a different header from another manufacturer as Chris mentioned.
Must pay to play. It is what it is.
F1point4 is offline   Reply With Quote
The Following 5 Users Say Thank You to F1point4 For This Useful Post:
ATL BRZ (08-16-2013), autobrz (08-16-2013), number1Tango (08-16-2013), Taber (08-16-2013), yuicebox (10-21-2013)
Borla Headers-Now On Sale!!! FBPARTS Engine, Exhaust, Bolt-Ons 26 11-19-2013 04:23 PM
FS: Borla UEL Headers, SoCal RiskyTrousers Engine, Exhaust, Bolt-Ons 10 07-29-2013 07:01 PM
Question about the design of Borla EL Headers... Kiske Engine, Exhaust, Transmission 4 07-26-2013 11:54 AM
FS: SoCal-Borla Unequal Headers midnight23 Engine, Exhaust, Bolt-Ons 2 07-24-2013 12:50 AM
Borla headers! Get the boxer rumble! Esoteric Engine, Exhaust, Bolt-Ons 45 01-29-2013 05:47 PM
