go_a_way1
Old 08-14-2013, 11:33 PM   #1345
FT_Monk
Drives: Over the hill WRX
Was the current draw actually measured or based on the ESC advertised rating?
FT_Monk is offline   Reply With Quote
Old 08-15-2013, 12:33 PM   #1346
Larkin
Larkin's Avatar
Drives: 2013 FR-S, manual, asphalt
I wonder how well this system would work with E85. With the right map running E85 and an electrocharger, or whatever the heck you call these things, could provide some very strong gains.
Larkin is offline   Reply With Quote
Old 08-15-2013, 01:22 PM   #1347
Toma
Drives: Viper, Mustang, FD RX7, FFR GTM
That it would. But we don't have E85.
Toma is offline   Reply With Quote
Old 08-15-2013, 01:29 PM   #1348
fenton
Back from vacation.... ready to try some new stuff and maybe get it back on the dyno when you guys are.
fenton is offline   Reply With Quote
Old 08-15-2013, 01:41 PM   #1349
mid_life_crisis
Drives: FR-S 10 #103 AT
Finally, the dyno I've been begging for.
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West
Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid."
mid_life_crisis is offline   Reply With Quote
Old 08-15-2013, 01:42 PM   #1350
neutron256
neutron256's Avatar
Drives: '13 GBS Subaru BRZ
@Robftss since it seems like a lot of us have different ideas about how to improve/modify this have you considered selling a 'Tuner' kit that just had the compressor and motor at a discounted price?
Just a thought.
The Following 2 Users Say Thank You to neutron256 For This Useful Post:
DAEMANO (08-16-2013), R2 (08-16-2013)
Old 08-15-2013, 01:42 PM   #1351
Wonderbar
Driveway labs.
Wonderbar's Avatar
Drives: '13 BRZ Limited, 6sp, SWP
NA cars hit over 200whp on e85, I'd say you could expect the same 20-30whp more.
-'13 Subaru BRZ Limited, SWP. (Mods: Driveway Labs full aero, MCA, etc)
-'06 Mitsubishi Eclipse 3.8L, UV blue. (Mods: turbocharged, full suspension, too much to list)
-'13 Town and Country Limited (Mods: too many kids)
Wonderbar is offline   Reply With Quote
Old 08-16-2013, 05:02 PM   #1352
fenton
Update
Got the new recharger system installed and have to say it makes a dramatic difference in recharge time. Doing some test runs from 0 - 200 km/h resulted in recharge to 28v in about 10 seconds.... essentially the time it took me to slow back down to 80km/hr.
You can just drive and drive it and the second you let off it the recharge begins to sore immediately. I have stated many times that i didnt have a problem with the recharge rate on the street but this will really help out the guys that will be trying this on autocross and on the road course.
The one time i DID notice the recharge was with the BMW races. We did about 15 pulls in different gears most times back to back. After about 15 minutes of abuse it was taking longer than it did on the street.
This system also has the added benefit of getting the rechargers and batteries warmed up quicker which help you get to optimal temps for dumping the most juice to the charger.
Rob has also fitted a larger battery tray and with it we are able to run essentially the stock battery size with the dump batteries on the side. This will help me with starting in the winter. Total weight increase over stock with current battery setup is 9 lbs.
Here is a pick of the new layout.
The Following 9 Users Say Thank You to fenton For This Useful Post:
autobrz (08-16-2013), BRAWL (08-18-2013), Calum (08-16-2013), DAEMANO (08-16-2013), Inzandity (08-17-2013), Mr.Jay (08-16-2013), neutron256 (08-16-2013), VR46 (08-17-2013), waterbison777 (08-16-2013)
Old 08-16-2013, 05:07 PM   #1353
fenton
Added Bu-Tangs race with the S2000 to Post 5 with other comparison videos'
[ame="http://www.youtube.com/watch?v=-wau1k13Gwc"]stock S2000 (AP1) vs FRS Boost(Electric Supercharger) Run 2 Dualview - YouTube[/ame]
The Following User Says Thank You to fenton For This Useful Post:
Mr.Jay (08-16-2013)
Old 08-16-2013, 05:33 PM   #1354
fenton
Some pictures the other day when butang and I were both getting some test stuff at Robs shop.
Two electric supercharged unicorns in such close proximity is a rare occasion. Lol.
Sent from my HTC One using Tapatalk 4
The Following 5 Users Say Thank You to fenton For This Useful Post:
autobrz (08-16-2013), BRAWL (08-18-2013), DAEMANO (08-16-2013), Mr.Jay (08-16-2013), waterbison777 (08-16-2013)
Old 08-16-2013, 05:54 PM   #1355
Gary in NJ
Gary in NJ's Avatar
Drives: WR Blue BRZ, 240Z
Want...now....right now.
Phantom ESC, ECUtek Tune, Nameless Front Pipe & Axle Back, Enkei RS+M 17x8 et35, OEM+Ref
Gary in NJ is offline   Reply With Quote
Old 08-16-2013, 06:13 PM   #1356
asher187
Drives: 2013 FR-S, 1995 Civic Coupe
Ditto, ready to reserve mines today:-D
Sent from my DROID RAZR using Tapatalk 2
asher187 is offline   Reply With Quote
Old 08-16-2013, 06:33 PM   #1357
Thatruth2001
Drives: Raven FR-S
Is the new rapid charger bolted to the battery? Also I got version 1.5 yesterday the new battery plate and fan. Looking forward to getting caught up with you guys in the next few weeks. Will likely have the ecutek tune done sometime soon. Until then the only cel code is is tied to high manifold and intake pressure from the sensors.
Thatruth2001 is offline   Reply With Quote
Old 08-16-2013, 08:13 PM   #1358
fenton
After reviewing the logs it looks like the new double recharger system really does help the system preform at its best....we are getting consistently .3 psi more across the entire rpm band.
Anyone have suggestions for a good water meth setup? I'm thinking cooling the charge would have a pretty dramatic effect on the power potential.
We have a appointment on a dyno jet this time for august 21st to get closer apples to apples to others results
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 05:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 07:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 08:07 AM
