Old 08-13-2013, 10:46 PM   #1
ericmpena
ericmpena's Avatar
Drives: Subaru BRZ Limited
Bottom Seatbelt Holder
I've had the car for 2 months but I just found this out. Maybe there are others out there who have overlooked this as well, so I thought I'd post.
Basically the handle on the side of the seat has a groove cut out for the seatbelt.
ericmpena is offline   Reply With Quote
The Following 4 Users Say Thank You to ericmpena For This Useful Post:
KelvinBRZ (08-13-2013), kevinnivek8877 (08-14-2013), Laika (08-14-2013), SirBrass (01-25-2014)
Old 08-13-2013, 10:56 PM   #2
SliverBrz
Drives: Silver 2013 BRZ limited
hmm i didnt know that...
I thought it was held by the shoulder strap only.
so this makes it easier to reach?
SliverBrz is offline   Reply With Quote
Old 08-13-2013, 11:00 PM   #3
ericmpena
ericmpena's Avatar
It helps clean up the look. I think it also helps with keeping it aligned with the top holder. Before I found this the seatbelt would always pop out of the shoulder holder whenever my gf would put it on. Now that I have the seatbelt into the bottom holder it seems to stay connected whenever she puts her seatbelt on. Idk, could just be coincidence.
If anything, it looks cleaner!
Old 08-14-2013, 12:11 AM   #4
Cjymiller
Original 2013 Owner
Cjymiller's Avatar
Drives: 13 BRZ, Galaxy Blue Silica
Dude, that's not for the seatbelt. That's to adjust the angle of the seat. It could break off in an impact or possibly prevent the seatbelt from working the right way if you get hit or hit something.
Perrin Headerback, OFH, OFT, Ohlins R&T MI20, 17x9 Weds TC105N, Hankook RS4 (235/40), TOM's JDM Tails, PCV AOS, Perrin Crank Pulley, Perrin Rear Trans. Mount, Whiteline Shift Bushing, SS brake Lines, Hawk DTC60, Bayson R Lip Kit, LED Lighting , Smoked JDM Sidemarkers, Rear Fog Enable, Carsmo Armrest, Grimmspeed Plate Relocater
φφκα
Cjymiller is offline   Reply With Quote
Old 08-14-2013, 12:19 AM   #5
SliverBrz
LOL!
good thing when i tried it, it looked stressed and i took it off
it doesnt feel like there is any groove there
i think the OP knows its the seat adustment, he just thought it had a groove for the belt too
Old 08-14-2013, 12:49 AM   #6
ericmpena
ericmpena's Avatar
Look in the first picture, there's clearly a groove at the bottom of the handle.
Old 08-14-2013, 12:55 AM   #7
ericmpena
ericmpena's Avatar
Go lift of your handle and look for yourself. Tell me there's not an obvious groove at the bottom of the handle.
Old 08-14-2013, 08:07 AM   #8
Enraged21
#RememberTheBuster
Enraged21's Avatar
Drives: Firestorm FRS MT
then how come the passenger side doesn't have it?
Enraged21 is offline   Reply With Quote
Old 08-14-2013, 08:10 AM   #9
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
If the handle was meant to act as a seat belt holder, it would have come like that from the get go.
Old 08-14-2013, 08:24 AM   #10
whaap
whaap's Avatar
Drives: '13 FR-S firestorm, 6 mt - '11 CR-V
My FR-S was built in August 2012 and the left handle is exactly like the right handle only it's a mirror image = no groove. Because of the clearance required for it to work up and down there is enough of a gap between it and the seat bottom that a seat belt could be put in there but if the belt were in there, time and use would cause chaffing to the belt.
whaap is offline   Reply With Quote
Old 08-14-2013, 09:14 AM   #11
ericmpena
ericmpena's Avatar
Here's better pics of the groove. Maybe the manufacturer just wanted grooves in the spot for some other reason. Seems right in line with the seat belt, but who knows what it's really for.
Old 08-14-2013, 09:20 AM   #12
ericmpena
ericmpena's Avatar
Not true. My seat belts weren't in the shoulder clips. For the first week I didn't even know why they had those clips on the seat, and then I read that it was for the seat belt. I wouldn't have known that since the car didn't come like that from the get go.
But anyways, not like I'm forcing anyone to use it. Just basically saying that there's a groove on the handle and your seat belt seems to slide right into there. If you don't have any grooves then you're not missing out on anything, right?
Old 08-14-2013, 09:36 AM   #13
chenshuo
chenshuo's Avatar
Drives: WRB BRZ
just because the handle has a groove doesn't mean it's for seat belt... if you put it there the movement of the seat belt would cause the handle to move.
chenshuo is offline   Reply With Quote
Old 08-14-2013, 09:45 AM   #14
ericmpena
ericmpena's Avatar
My seat belt doesn't seem to affect it, but I get what you're saying. You're right, I'm sure it's just a random groove on the handle.
I have seen other pictures with people having the seat belt in those grooves, but I'm sure they assumed wrong just me.
Check out this guy. He's got it in the groove but not in the shoulder clip. Madness!!!!
http://www.edmunds.com/subaru/brz/20...the-seats.html
seatbelt chime drei Cosmetic Modification (Interior/Exterior/Lighting) 49 07-14-2015 04:09 PM
SEATBELT padding. Filipino Royale Want-To-Buy Requests 0 07-20-2013 09:56 PM
Has the seatbelt 'burned' you yet? Rob_g Scion FR-S / Toyota 86 GT86 General Forum 22 07-17-2012 02:01 PM
Seatbelt snaps not holding very well ubersoph Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 7 06-23-2012 01:57 AM
wear your seatbelt... bofa Off-Topic Lounge [WARNING: NO POLITICS] 17 07-16-2011 04:25 AM
