Old 08-13-2013, 11:43 PM   #1
SuperJimmyK
Drives: Multi colored Scion FR-S
Plasti Dip Problems
Back in June when the Man of Steel movie came out I dipped my car superman themed.
I laid down 4 coats of the blue then I laid the carbon fiber pattern down and did two heavy coats of blaze blue. After that all dried I taped off the shield and put down 3 coats of blaze yellow and then used a darker yellow over that to complete the carbon fiber look again in yellow. Then finished taping the S and sprayed 3 heavy coats of red on top of everything.
A week after I had dipped my car I was involved in a flooding and I seized my engine. Insurance covered all expenses but it took about 2 months to get back to me. All that time the car sat in the sun not moving. Anyway I peeled the car today. . .
It looks like the red bled thought staining my paint. Has anyone else experienced this or have any ideas on what I can do to remove it. Scrubbing with soap and water does nothing, neither does a pressure wash
SuperJimmyK is offline   Reply With Quote
The Following User Says Thank You to SuperJimmyK For This Useful Post:
Flako (08-18-2013)
Old 08-13-2013, 11:45 PM   #2
mikeTee
Yup.
mikeTee's Avatar
Drives: MT Subaru BRZ '13
I'm guessing the red paint you used wasn't plastidip?
mikeTee is offline   Reply With Quote
Old 08-13-2013, 11:48 PM   #3
SuperJimmyK
All plasti dip. Light blue gallons, blaze blue on top of that, the blaze yellow and plasti dip red for the shield.
Old 08-13-2013, 11:50 PM   #4
mikeTee
Yup.
mikeTee's Avatar
[ame="http://www.youtube.com/watch?v=4ynMrKFZJHI"]How to remove Plasti Dip that's too thin - Dip Dissolver - YouTube[/ame]
Try "Dip Dissolver". If you're pressed on time, Goo Gone may work as well.
The Following User Says Thank You to mikeTee For This Useful Post:
supragoods (08-14-2013)
Old 08-13-2013, 11:52 PM   #5
Flat Black VW
Flat Black VW's Avatar
Drives: 2013 Subaru BRZ
I have no idea how to get that off, and I would probably cry if it were my car. Unfortunately right now I can't help but laugh when I look at those pictures.
Good Luck.
Flat Black VW is offline   Reply With Quote
The Following 11 Users Say Thank You to Flat Black VW For This Useful Post:
Ammonia (08-14-2013), bkblitzed (11-25-2013), Carlitoz3 (08-14-2013), EAZYBRZY (03-27-2014), ericmpena (03-27-2014), Exhaust (12-01-2013), Godzilla35 (08-19-2013), husker741 (08-14-2013), kidgogeta (08-14-2013), slicktop (11-25-2013), Wes (08-14-2013)
Old 08-13-2013, 11:54 PM   #6
Krazy
Krazy's Avatar
Drives: FR-s
Maybe the only way is to sand it or new Hood?
Sent from my SGH-T989 using Tapatalk 2
Krazy is offline   Reply With Quote
Old 08-14-2013, 12:04 AM   #7
Wes
Wes's Avatar
Drives: JRSC'd Asphalt FR-S
Oh wow that sucks.. maybe try buffing it with some cutting compound or polish? Good luck
Old 08-14-2013, 12:08 AM   #8
DAEMANO
Time Traveller
Like the above posters said, just use polish or other paint restoration compounds. It should come out. Alternatively you can just re-dip your hood white for a funky look.
Old 08-14-2013, 12:21 AM   #9
husker741
Drives: 2013 Whiteout Scion FR-S 6MT
Just showed this thread to a buddy of mine who works for a local company that Plasti Dips cars. He said...
A good buffing or some rubbing compound. I would even just try a good cleaner wax by hand first
Hope that helps.
husker741 is offline   Reply With Quote
Old 08-14-2013, 12:25 AM   #10
SuperJimmyK
I an not upset about it, and have dipped many other vehicles before without a problem. This is something new though and just wanted to get some input on what everyone thought. I have every intention of dipping it again but might not be doing any decals or extras until I figure out if this was a one time thing or something the clear coat of this car does when dipped. I almost like the ghosted look of the symbol.
I will try the polishing compound and what not tomorrow and see if that helps, thanks for the quick responses.
Old 08-14-2013, 02:53 AM   #11
Freeze2196
Freeze2196's Avatar
Drives: 2013 Scion FRS
Does the surface feel raised at all ? try some WD40
Freeze2196 is offline   Reply With Quote
Old 08-14-2013, 03:44 AM   #12
cdo221
Drives: 2013 Ultramarine FR-S, 2015 RS 1.0
Just wanted to say that the super man dip was pretty sick looking! Anyway, I would get in contact with someone at https://www.dipyourcar.com/home.php
They might have some suggestions for you if using some rubbing compound doesn't work. I would also try a bit of rubbing alcohol (70% isopropanol) to see if it would come out - I've had good success with rubbing alcohol at getting gunk off the car. Also nail polish remover (acetone) - just don't leave it on your car's paint too long and remember to wash off the acetone afterwards.
Also, you can take it to a reputable, professional detailer/restorer. It's really unlikely the dip went through the clear coat, at most it was partially absorbed by the clear coat I think. A professional should be able to take care if it.
If all else fails... new carbon fiber hood or vinyl wrap it black! It would look great on white
cdo221 is offline   Reply With Quote
Old 08-14-2013, 03:48 AM   #13
IgnitionGundam
IgnitionGundam's Avatar
Drives: Silver Ignition Gundam
Hakuna Montana?
IgnitionGundam is offline   Reply With Quote
The Following User Says Thank You to IgnitionGundam For This Useful Post:
unsurety (03-27-2014)
Old 08-14-2013, 03:54 AM   #14
dori.
Señor Member
dori.'s Avatar
Drives: white BRZ 6MT
rub some kryptonite on it
dori. is offline   Reply With Quote
The Following 35 Users Say Thank You to dori. For This Useful Post:
4Running Daily (09-22-2013), 636 (12-27-2013), Ahmeda (08-29-2013), Ammonia (08-14-2013), Anomie (11-25-2013), bkblitzed (11-25-2013), Black Tire (03-30-2014), boonFRS (03-20-2014), Brody602 (03-28-2014), BRZ21 (08-16-2013), EAZYBRZY (03-27-2014), ericmpena (03-27-2014), Exhaust (12-01-2013), Froylavin (08-23-2013), Godzilla35 (08-19-2013), hur1ey02 (08-14-2013), Jive Turkey (03-27-2014), jkr (01-12-2014), Khalis (12-03-2013), khan (03-26-2014), meWant (03-26-2014), nix (09-11-2013), Philly758 (08-17-2013), PineappleFriedRice (09-14-2013), sklimo (08-14-2013), smbstyle (09-11-2013), Sportsguy83 (08-14-2013), stefmiesterb (08-14-2013), STS-V (03-27-2014), Takumi788 (07-14-2015), Turkish (08-26-2013), vividracing (11-27-2013), was385 (08-22-2013), Wes (11-27-2013), YDNA (08-18-2013)
Where to get plasti dip done? Norcalmav23 Northern California 22 03-06-2014 11:31 PM
Just another Plasti dip fun :) EPIKsung FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 4 07-17-2013 02:08 AM
Plasti Dip Professionals ChandlerSwyng Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 05-25-2013 05:09 PM
Plasti Dip Vancouver? Dispect CANADA 12 11-15-2012 09:44 AM
Plasti dip on top of a clear bra? Maps316 Cosmetic Modification (Interior/Exterior/Lighting) 2 10-06-2012 01:32 PM
