Old 06-19-2013, 12:42 AM   #15
FTEIGHTSIX
Switched to the dark side
FTEIGHTSIX's Avatar
Drives: 91 & 95 240sx KA-T SOLD, 2013 BRZ
"COURTESY LAMP AY CLR" - 94256CA000
Part number for Subaru door step light housing.
I bought them almost exactly a year ago.
Time to put them in!!!!
http://www.ft86club.com/forums/showt...ght=door+light
@boredom.is.me
Glad you didnt give up like you said you did in the thread above.
WTB: FA20 longblock in Socal or shipped.
FTEIGHTSIX is offline   Reply With Quote
Old 06-19-2013, 01:16 AM   #16
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
Haha, ya I'm glad too. It's the little things that bring the smile. I was supposed to take pics of between the door jamb but forgot. If someone can remind tomorrow, that would be great.
Old 08-13-2013, 09:29 PM   #17
foney_email
foney_email's Avatar
Nice job. I was just looking into doing this myself. Thanks for the info!
foney_email is offline   Reply With Quote
Old 08-13-2013, 09:46 PM   #18
boredom.is.me
Custom User Title
Thanks and no problem. The DIY is a bit lame so if you need anything, just ask.
Sent from my mind using telepathy.
Old 03-06-2015, 11:53 PM   #19
HueyLooie
Drives: Scion
Thank you two posters above! You are a great help!
HueyLooie is offline   Reply With Quote
Old 03-11-2016, 09:55 AM   #20
Huicho
Drives: 2016 Scion FR-S
Originally Posted by boredom.is.me View Post
More info tomorrow once I'm done. I tapped the dome light though.
I think it would be easier to tap the ignition switch light ring instead of the dome light!
Huicho is offline   Reply With Quote
Old 03-11-2016, 05:09 PM   #21
boredom.is.me
Custom User Title
Possibly, but the dome was incredibly easy as well.
Old 03-11-2016, 05:30 PM   #22
ShadowReaper
Indulgent Tormenter
ShadowReaper's Avatar
Drives: 15' LTD Subaru BRZ DGM
I made a shortcut that didn't pay off. I'll get the wire I need to finish the job tomorrow.
How do you take the cover of the door light off?
Instagram: Gabe.it.the.ole.college.try
ShadowReaper is offline   Reply With Quote
Old 03-11-2016, 05:41 PM   #23
boredom.is.me
Custom User Title
You have to take the door panel off.
two screws inside the handle
plastic clip to the front
pull straight out starting from one side > bottom > other side, then lift the panel
Old 12-11-2019, 07:12 PM   #24
hexxen
Drives: 2018 Toyota 86
You dont need to go through the door and tap into the dome light.
just tap into the wires in the door
[ame="https://www.youtube.com/watch?v=SjTjz-eEiiA"]https://www.youtube.com/watch?v=SjTjz-eEiiA[/ame]
hexxen is offline   Reply With Quote
The Following User Says Thank You to hexxen For This Useful Post:
EndlessAzure (11-13-2022)
Old 01-08-2020, 08:27 PM   #25
tarzan_nojane
tarzan_nojane's Avatar
Drives: 2014 FR-S
found a new source for the OEM connector to the Toyota (Camry) or BRZ Limited door courtesy lamps. They are $5.40 a pair in quantity of two (one pair):
https://www.aliexpress.com/item/32967395244.html
tarzan_nojane is offline   Reply With Quote
Old 01-15-2020, 04:49 PM   #26
tarzan_nojane
Drives: 2014 FR-S
Red Door Courtesy Lamps
Found the Toyota part number and JDM source for the Red Lens Door Courtesy Lamp (not the reflector): SU003-03290
lamp
as well as the connector (without pigtail)
or connector (including 4-inch pigtail)
The Following User Says Thank You to tarzan_nojane For This Useful Post:
Old 05-24-2024, 12:06 PM   #27
Chosen86
Drives: 2014 FR-S
Courtesy door lights.
Thanks. You should be able to go to a Suby dealership and get them.
They're all over eBay for less than $20 if you want white, and LED. No need to start a cardboard craft project.
Chosen86 is offline   Reply With Quote
Old 05-24-2024, 01:30 PM   #28
boredom.is.me
Custom User Title
This is a 10 year old post from when the car came out.
BRZ Driver's Door Courtesy Light Won't Work delusional Issues | Warranty | Recalls / TSB 31 05-29-2022 08:15 AM
Changing out the door/courtesy lights - problem mikalem Cosmetic Modification (Interior/Exterior/Lighting) 19 02-10-2014 09:39 AM
Passenger Door Courtesy Light Wont Turn Off zex Issues | Warranty | Recalls / TSB 12 10-04-2013 02:31 PM
