Old 08-13-2013, 06:55 AM   #15
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
excited to come back from holiday and get me a pair of these
did you get your alignment done yet ?
how are you liking them so far?
any clunks and weird sounds
Old 08-13-2013, 09:13 PM   #16
86TruenoFRS
Drives: Rocket Bunny v1 FRS
No weird sounds or clunks... The suspension is a little stiff w/10k springs but not too bad. I wanna wait till the springs settle and I get wheels before I align it as I will prolly go lower once I get wheels. I'm planning on 18s
86TruenoFRS is offline   Reply With Quote
Old 08-13-2013, 10:13 PM   #17
86TruenoFRS
Originally Posted by Slash View Post
I drive my car lower than yours around Cleveland everyday you'll be fine. Unless you're completely oblivious to what's up ahead.
Sent from my SGH-T999 using Tapatalk 2
Where at in Cleveland are u from??
Old 08-21-2013, 02:59 AM   #18
ShikoBariki
Drives: 89 240sx S13 SR20DET, 13 FR-S
got the same coils but am debating if i should wait til i get some LCAs and toe adjustment or if i should slap the coils on...do you have anything else besides the coils? lcas?toe arms?
ShikoBariki is offline   Reply With Quote
Old 08-21-2013, 01:18 PM   #19
cabbagecookies
Drives: evo ix se
I got the same kit but didnt receive any instructions. I've done a few coilover installs before so i understand how to put them in. Only thing that im a little confused on is how to install the end links? Do i just put them in and tighten them or do they have to be at a certain length?
cabbagecookies is offline   Reply With Quote
Old 08-21-2013, 08:11 PM   #20
SmsAlSuwaidi
Boosted
any updates, how are you liking them ?
Old 08-21-2013, 08:53 PM   #21
g0lden
Drives: 2013 Scion FR-S Argento
I have the same BC racing coilovers. They have been nothing but awesome!
I however had to raise them up. I tried riding on them that low and that just made life very difficult. Plus, I didn't want to damage my precious. I'd recommend adjusting up a little or you will have a very difficult time getting around.
I installed the Invidia N1 at the same time, and the flange between the front and mid pipe hangs a little low (Could be cut out and welded for more clearance).
I'd like to know what settings you have the knobs turned to?
I turned them all the way soft, then dialed them up 8 clicks front and back. Other than that, I haven't experimented much.
g0lden is offline   Reply With Quote
Old 08-21-2013, 09:35 PM   #22
86TruenoFRS
Before I started I measures the distance between LCA and the endlink. Than I adjusted the BC endlinks to get the swaybar in the same position(or as close to)
If you have already done the install. Just try to keep a good distance between the swaybar and the LCA
Old 08-21-2013, 09:39 PM   #23
86TruenoFRS
Everything is stock aside from the coilovers. I do plan to get LCAs and align as soon as I get wheels. From what I've read, you don't need toe arms unless you run crazy camber. But it is easier to adjust toe w/ the arms.
Old 08-21-2013, 09:45 PM   #24
86TruenoFRS
To answer both questions:
The ride is actually very comfortable and handles quite well! However I did have a problem when I first installed them as they were set to full stuff and the seemed very bouncy. I currently have the damper set to full soft but I plan to play w/ the adjust a little. But to me full hard is just not a comfortable ride.
And as far as the height. I actually wanted to go a little lower. My previous car(s2000) was a lot lower than this and I had no issues. I appreciate the heads up tho. I read many of the aftermarket exhaust hang quite low so I'll keep that in mind when I purchase one!
Old 08-21-2013, 09:46 PM   #25
evox2frs
evox2frs's Avatar
Drives: Asphalt MT FR-S
What about the damper adjustment extenders in the rear, did you install them? If so, where did you put them? I want quick rear adjustment like the front
evox2frs is offline   Reply With Quote
Old 08-21-2013, 09:51 PM   #26
86TruenoFRS
I did install the extenders in the rear and the adjustment is just as easy as the front. But you do have to make a hole in th e trunk liner...
The Following User Says Thank You to 86TruenoFRS For This Useful Post:
evox2frs (08-21-2013)
Old 08-21-2013, 10:22 PM   #27
ShikoBariki
Do you have LCAs or toe arms to adjust camber and toes or straight coils? How much spacing from the lower perch to the height adjustment did you have?
Old 08-21-2013, 10:31 PM   #28
86TruenoFRS
I just have the coils for now. As far as space I have about an inch left both front and rear. But I believe both stance(and a few other) LCAs have 30mm bends in them allowing ~one more inch of height adjustment.
RS*R SUPER DOWN SPRINGS AND COILOVER AND MORE! ExtremeAutowerks Brakes, Suspension, Chassis 32 12-23-2013 02:39 PM
BC Racing Extreme Drop Coilovers 636 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 60 10-16-2013 11:42 AM
FT86 Cup exhibition event results, pics, and video CSG Mike BRZ Photos, Videos, Wallpapers, Gallery Forum 2 01-08-2013 01:49 PM
How (NOT) to install coilovers daytrip00 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 53 09-06-2012 02:20 PM
HKS Exhaust install Pics gtauto AUSTRALIA 23 07-23-2012 01:51 AM
