Old 08-09-2013, 02:04 PM   #869
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
But but i want pretty ones
Old 08-09-2013, 05:30 PM   #870
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
No I don't because it is the bolts that are anchoring the bar. If the mounting isn't strong enough the strongest bar in the world would be useless.
I was inferring was the bolts are providing the clamping force;the bolts themselves are not seeing any shear force but they are still doing the "anchoring".
Originally Posted by GrimmSpeed View Post
In an application like this, the bolts are not being used in shear. They're used to clear a clamping load. Your wheels are held to your car just the same way. You're applying a clamping force and it's the force/friction between your hub and wheel that are actually interfacing. None of your studs/lug bolts should be experiencing any sort of shearing force. Make sense?
Makes sense, I understand that. What I don't get is how little clamping force is generated with just 12lb-ft of torque. As I mentioned earlier, this is just my unscientific gut feeling and I know gut feeling is something you get after eating too quickly.
Old 08-12-2013, 12:03 PM   #871
GrimmSpeed
GrimmSpeed's Avatar
Drives: '13 BRZ, '12 WRX
Send a message via AIM to GrimmSpeed Send a message via MSN to GrimmSpeed
Matt nailed it while I was away, but I think an easy way to convince yourself is simply by looking at the stock triangulation bars. They are trying to achieve the same goal as the strut tower bar, but have a compromise to achieve an additional goal (bracing to the firewall to prevent strut tower movement in the fore and aft directions). Our strut tower brace eliminates that compromise, directly linking the towers together. The input forces (forces from the road to your tire, all the way up to the strut tower) are still the same, so the output forces also have to be the same, but are directed or resolved in different directions.
But, just to convince ourselves that there is more than enough clamping force from only 12 ft-lbs, lets look at those stock triangulation bars. They are on your car right now, only torqued to 12ft-lbs (unless you've messed with them). You've driven your car, possibly thousands of miles, experienced plenty of driving conditions, road conditions, chassis flex, etc. Now go remove the bolts holding the triangulation bars to the strut towers. If there were not adequate clamping force they would be scratched up and rubbed raw from the flange of the nut. But I'm willing to bet you the price of a strut tower brace that they are still in perfect condition. This is because the bolt and the triangulation bar are not moving relative to each other, because there is more than adequate clamping load.
The same can be said for when you at the strut tower brace to the assembly. If you were to bolt it on, torque to 12 ft-lbs, and then go drive the car harder than you've ever driven it before, then come home and open your hood, you would notice if the bolts were not providing adequate clamping because you would easily see where the flange of the nuts had rubbed the bar, but I can assure that that isn't going to happen. There are 4 total nuts (4x the clamping force), each with a large flange (bearing area), providing over 1000lbs of clamping force EACH. I know this is all very counter-intuitive, but hopefully this puts some perspective on exactly how much force can be applied with a seemingly small amount of torque.
They're both very pretty! In fact, you stated nearly three months ago:
I want this in red or gold
way back when we were only making them in black, so we decided to add an extra color. I assure you, red is very pretty
Originally Posted by stratodyne View Post
Recommend me a good starter torque wrench (for this install, as well as torquing lugs) and then add me to this list for a black one, thanks!
I hate to even admit it, but back in the day I had a torque wrench from Harbor Freight. I think it was around 15-25 bucks. Then I picked up a cheap craftsman from Sears. For my "big boy stuff" I use a Matco. I would stay away from the HF, and probably run over to Sears and pick up a 3/8th in torque wrench that fits your budget. I'll add you to the list, now go pick up a torque wrench!
REMEMBER FOLKS, THE GROUP BUY IS OVER THIS FRIDAY!!! IF YOU'RE NOT ALREADY ON THE LIST, YOU NEED TO DO SO BY THIS FRIDAY 8/16/13. We'll then start sending out PMs Monday, start taking payment, and then start shipping!
Chase
Engineering
GrimmSpeed is offline   Reply With Quote
The Following 3 Users Say Thank You to GrimmSpeed For This Useful Post:
chanomatik (08-12-2013), Jayde (08-12-2013), stratodyne (08-12-2013)
Old 08-12-2013, 12:16 PM   #872
xwd
Put me on the list for a black one.
Old 08-12-2013, 12:35 PM   #873
2point0
2point0's Avatar
Drives: '13 BRZ Ltd WRB
Hot damn, this is happening! I've been checking the forum so infrequently lately that I keep thinking I'll miss this. I'll just trust you guys. I know you won't let me miss out!
2013 BRZ Limited - SOLD
2008 Forester XT Sports
1967 Mustang Coupe - 289 V8
2point0 is offline   Reply With Quote
Old 08-12-2013, 05:22 PM   #874
Nardi330
Nardi330's Avatar
Drives: 86
Please add me on the GB list. Thx
Nardi330 is offline   Reply With Quote
Old 08-12-2013, 05:37 PM   #875
Iamthebatman
Drives: Black Subaru BRZ
Sign me up!
Iamthebatman is offline   Reply With Quote
Old 08-12-2013, 05:56 PM   #876
GrimmSpeed
GrimmSpeed's Avatar
Will do, got you added right now!
Have no fear, you're absolutely right! We will even make it super easy on you folks by sending YOU a PM when it's time to start sending these out.
No problem, I have you added to the list right now!
Originally Posted by Iamthebatman View Post
Sign me up!
You are signed up (and also batman)!
Chase
Engineering
The Following 2 Users Say Thank You to GrimmSpeed For This Useful Post:
2point0 (08-13-2013), stratodyne (08-12-2013)
Old 08-12-2013, 09:33 PM   #877
Nardi330
Nardi330's Avatar
Drives: 86
oh btw, just wondering what is the actual weight of the bar.
sorry i haven't read through 40 pages as i am busy at the moment. i'm only on page 5....
Old 08-12-2013, 09:39 PM   #878
Captain Snooze
Drives: Red Herring
Just weighed a finished bar: 3.95lbs
The Following 2 Users Say Thank You to Captain Snooze For This Useful Post:
GrimmSpeed (08-13-2013), Nardi330 (08-13-2013)
Old 08-12-2013, 10:02 PM   #879
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Chase
Engineering
yea lol
Old 08-13-2013, 12:12 AM   #880
Lee358
Lee358's Avatar
Drives: nissan frontier, DGM MT BRZ
Finally!
Lee358 is offline   Reply With Quote
Old 08-13-2013, 12:43 AM   #881
joel86
Drives: 86 GT (Australian)
Put me on the list, black one.
joel86 is offline   Reply With Quote
Old 08-13-2013, 03:08 AM   #882
Symmetrical
Symmetrical's Avatar
Drives: 2013 DGM BRZ Limited
Sign me up for a black one!
Symmetrical is offline   Reply With Quote
Anyone using the STi Flexible Strut Tower Brace? ngabdala Suspension | Chassis | Brakes -- Sponsored by 949 Racing 45 08-15-2019 01:59 AM
F/S Beatrush Strut Tower Brace Type-2 $175 Dan-in-Japan Brakes, Suspension, Chassis 2 02-24-2013 01:38 PM
FT-86 SpeedFactory Strut Tower Brace Review F1point4 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 35 01-07-2013 04:31 AM
DIY - Strut Tower Brace - FT-86 SpeedFactory F1point4 DIY (Do-It-Yourself) Guides 4 10-28-2012 04:30 PM
