Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > ASIA
Old 08-09-2013, 03:28 AM   #1275
bRaWzZz
Drives: Toyota 86
Un! Natapos ko din basahin 64 pages.
I have my L. Red 86 last 2 weeks p. sana mksama ko nxt n eb. Thanks nga pla mga useful infos n ntutunan ko dto. ASTIG TLGA 86!!!
bRaWzZz is offline   Reply With Quote
Old 08-09-2013, 04:22 AM   #1276
NIKDENG
Drives: RED BRZ
Congratulations on your new rides @Alfman and @bRaWzZz
NIKDENG is offline   Reply With Quote
Old 08-09-2013, 04:52 AM   #1277
Alfman
Alfman's Avatar
Drives: Toyota 86
Thank you bro. Hope to join you guys in your future fun rides! 👍
Alfman is offline   Reply With Quote
Old 08-09-2013, 04:58 AM   #1278
Alabang BRZ
Size:  177.9 KB saw this 86 in front of south mall
Alabang BRZ is offline   Reply With Quote
Old 08-10-2013, 03:12 AM   #1279
ayuk
Drives: none planning to buy
sorry mga sir pa-OT; what did you do sa gt86 DRL to light? gusto ko sana paganahin yong DRL sa 86 ko. thank you guys.
ayuk is offline   Reply With Quote
Old 08-10-2013, 03:14 AM   #1280
ayuk
Originally Posted by Alabang BRZ View Post
Attachment 47345 saw this 86 in front of south mall
different person with a different taste
Old 08-10-2013, 03:42 AM   #1281
Touge_ninja
Sending rods to their doo
Touge_ninja's Avatar
Drives: 700HP STi
mga pre, sino sainyo ang gusto mag trade para sa USDM Badges ko?
Touge_ninja is offline   Reply With Quote
Old 08-10-2013, 06:18 AM   #1282
NIKDENG
Drives: RED BRZ
@ayuk,
To enable the DRL on the 86, just add a relay in the DRL slot of the fusebox located in the engine. The DRL will light up when the car is running and the handbrake is disengaged.
For the BRZ, aside from adding the relay, you will have to buy and install the BRZ LED DRL assembly which will have to be installed above the foglights on the bumper.
Old 08-10-2013, 10:49 AM   #1283
ayuk
sir NIKDENG, do you have tha part number of that fuse your telling me? just want to be sure the fuse im going to buy is the right fuse. 
Old 08-10-2013, 12:39 PM   #1284
NIKDENG
Drives: RED BRZ
@ayuk,
It's not a fuse, its a relay on the engine fusebox. The relay type for the DRL is the same as that of the horn relay. If you want to test the DRL function, temporarily use the horn relay and place it in the DRL location. The diagram and the relay locations are as follows:
The red box is the DRL relay location, the green box is Horn relay location.
When you are going to buy a relay for the DRL, just bring the horn relay as your sample. Remember when testing your DRL, the engine must be turned on and the handbrake disengaged.
The Following User Says Thank You to NIKDENG For This Useful Post:
melon (08-13-2013)
Old 08-10-2013, 04:34 PM   #1285
ayuk
thank you sir NIKDENG.
OT; typical FC for 86/BRZ?
Old 08-11-2013, 08:00 AM   #1286
pcuerpo
pcuerpo's Avatar
Drives: Toyota 86
Send a message via ICQ to pcuerpo Send a message via Yahoo to pcuerpo
nice to know that you just need a relay for you to have the DRL in the 86 work though i wish they just made it work just like the usual DRL wherein as long as the ignition is on, the DRL lights up as well
pcuerpo is offline   Reply With Quote
Old 08-11-2013, 08:40 AM   #1287
NIKDENG
Drives: RED BRZ
@pcuerpo,
The 86/brz actually follows the standard DRL implementation of the DRL lighting up whenever the engine is running and the handbrake is deactivated. They should turn off when the headlights, parklights, or foglights are turned on or when the handbrake is activated.
Old 08-11-2013, 04:36 PM   #1288
Alabang 86
Alabang 86's Avatar
Drives: GT86
Any upcoming dates for a track day?
...my turn...
Alabang 86 is offline   Reply With Quote
