Old 01-10-2012, 11:19 AM   #113
duffman13
Auto-Xer
Drives: 2004 Acura RSX Type-S
I'd go for a donut for sure. Goop makes lots of performance tires unrepairable, but at least with a donut I can limp somewhere to get a fix done.
Just have to remember to swap front/rear wheels if the puncture is in the rear tire so you don't screw up the diff
duffman13 is offline   Reply With Quote
Old 01-10-2012, 11:40 AM   #114
old greg
Rocket Surgeon
Drives: PSM GGA OMG
Originally Posted by Levi View Post
Are not the stock Tires some Michelins like the Prius? We can see the spare tire is a Yokohama on stel rims. Interesting!
Those pictures are of that red Nur-spec 86 from a while back. I'd imagine that has something to do with it.
old greg is offline   Reply With Quote
Old 01-10-2012, 07:05 PM   #115
Nambo
Nambo's Avatar
Drives: '12 BRZ [CBS]
From the BRZ,
http://www.crawfordperformance.com/n...cgi?linkID=100
From illmatic's post: http://www.ft86club.com/forums/showp...3&postcount=85
Nambo is offline   Reply With Quote
Old 01-10-2012, 08:38 PM   #116
2fast4you
2fast4you's Avatar
Drives: 2006 Scion tC RS 2.0
It looks like they will include collapsable wheel chocks (the white item in the upper part of the picture)... nice touch.
Brake. Turn. Accelerate. Repeat as necessary.
2fast4you is offline   Reply With Quote
Old 01-11-2012, 02:06 AM   #117
WhiteGDB
WhiteGDB's Avatar
Drives: Civic Si sedan
^Good eye, looks like another part of the track theme they're promoting.
WhiteGDB is offline   Reply With Quote
Old 01-11-2012, 03:00 AM   #118
2fast4you
2fast4you's Avatar
I carry a set to the track for tire changes and to chock the wheels at track days (no e-brake between runs). Just a little extra security, especially in the paddock at Buttonwillow.
Old 01-12-2012, 06:32 PM   #119
Want.FR-S
Want.FR-S's Avatar
Drives: 4 Wheels Auto
Originally Posted by SilentMike View Post
A full sized spare would be nice, provided the fronts and rears are the same size. I had a rare sidewall puncture on my front right tire on my current DD 08' Civic SI sedan. In the rain of course. Since the SI comes with a donut, and has an LSD, I had to jack up the right rear, remove the tire and replace it with the donut. I then lowered the car, jacked up the front right, removed the wheel/punctured tire, replaced with full sized wheel/tire from right rear.
Just out of curiosity, you had to do this because of the LSD? What would happen if you put a donut and a regular tire on the transmission axel equipped with LSD? Just wondering.
Originally Posted by Winding Road FR-S review
What is astonishing about the FR-S is that it combines the cruising comportment and function of the 128i with the dynamics of the Cayman, or Boxster, or S2000.
Want.FR-S is offline   Reply With Quote
Old 01-12-2012, 09:11 PM   #120
duffman13
Auto-Xer
A LSD expects you to have equal sized tires for it to transfer torque properly from side to side. If not, the torque transfer gets all wonky because grip characteristics are different even in a straight line at part throttle. It overworks itself and will eventually grenade itself.
I know this is a problem with viscous and clutch types. S2000 had a torsen and the recommend it there too, so I would do it just to be safe.
Old 01-12-2012, 10:46 PM   #121
Want.FR-S
Want.FR-S's Avatar
OK, I was thinking it may be something related to this. I have never owned a car with LSD so I do not know this problem. Thanks, learn something new today.
spare, tire, weight
NEW Bridgestone R10 Race DOT tire RRnold Other Vehicles & General Automotive Discussions 2 06-17-2011 05:58 PM
