Old 08-09-2013, 05:24 PM   #1
brillo
Drives: 2013 Firestorm FR-S
Can the stock rotors and pads hold up to light auto-x duty?
going to start doing a bit of auto-x for fun and I haven't made any break system modifications to this point. Can the stock rotors and pads hold up to 5-6 spaced out runs? I'm a novice at this point so I'm not going to be 10/10ths around the course.
2013 Firestorm FR-S, MTX, build date 1/13.
brillo is offline   Reply With Quote
Old 08-09-2013, 05:28 PM   #2
m.wood0213
Driving Enthusiast
m.wood0213's Avatar
Drives: 2013 BRZ Limited
stock brake system has held up well for spirited canyon driving for me. Never done any autoX yet. Also need to consider your track layout. Are there long straights where the brakes can cool or is it all corners?
“This isn’t a supercar, it’s a sports car. It sacrifices rear seats yes but it just feels alive. Pure, direct, immediate. The other two are going to get all the admiring looks yes, that’s my point. I’m not driving around in this for other people’s benefit. I’m driving around in this BECAUSE I LOVE DRIVING IT. END!”
-Richard Hammond, Top Gear, USA Supercar Road Trip, 2011 Porsche GT3 RS.
My BRZ
m.wood0213 is offline   Reply With Quote
Old 08-09-2013, 05:33 PM   #3
jprice130
AutoX Nut
Drives: 2020 Toyota Supra
I've had my BRZ on the stock rotors, pads, and fluid for 14 months and have about 20 Autocrosses and 11,000 miles under my belt. I've never experienced brake fade and my pads and rotors are holding up fine.
You won't be going fast enough or running long enough on a typical AutoX course to worry the brakes too much, so just go out there and have fun!
jprice130 is offline   Reply With Quote
Old 08-09-2013, 05:33 PM   #4
f0rge
head of infinite swagger
Drives: 2013 FR-S 6MT
100% yes, I've done 4-5 events with my car with zero issues.
The biggest issue with the stock system is that the pads fade, you wont get them hot enough at auto-x to make them fade.
2019 Golf R 6MT - current daily...I need another coupe
2008 Civic Si - winter beater
2000 Silverstone M5 6MT - SOLD
2013 Ultramarine FR-S 6MT - Car Journal - SOLD
2004 AlpineWhite M3 6MT - SOLD
f0rge is offline   Reply With Quote
Old 08-09-2013, 05:53 PM   #5
brillo
thanks, I appreciate the feedback.
Old 08-09-2013, 07:36 PM   #6
Miniata
Drives: 13 BRZ - 90 Miata - 07 FXT -05 Mini
Yeah, normal autocrosses won't tax the stock brakes at all. I ran mine several events last season, and have done 5 or 6 this season, most with a co-driver, sometimes with a 3rd driver in another class, and the brakes have held up very well. Only time at an autocross type event where they might start to give you problems is at a test and tune or driver's school where you might be going back out for repeated back to back runs (and I'm talking dozens of runs over the course of the day).
17x7 Kosei K1-TS w/ 215/45-17 Dunlop Star Specs
Nameless Track Pipe - Strano front sway bar
Miniata is offline   Reply With Quote
Old 08-09-2013, 09:00 PM   #7
n8dog11914
n8dog11914's Avatar
Drives: 2013 WRB Subaru BRZ 6MT
Yes, you should have no problems with the stock pads and rotors for autocross. For HPDE events I would recommend at least a brake fluid change and brake pad change.
n8dog11914 is offline   Reply With Quote
Old 08-10-2013, 09:59 AM   #8
brillo
What if any downsides exist to switching to higher performance brake fluid? The only thing my research has shown is dot 5 is less able to absorb water. Does it have any other negative daily driving effects?
Old 08-10-2013, 10:58 AM   #9
CSG Mike
CSG Mike's Avatar
Use DOT4.
You'd need to change the fluid more regularly, but what this really means, is that unless you boil it, you need to religiously change it once a year.
Old 08-10-2013, 11:23 AM   #10
Sccabrz192
Detroit Region, MI
Sccabrz192's Avatar
Drives: 13 BRZ, 13 Volt, 02 WRX
I've had a little bit of fade one time when my car had 3 drivers at one event, otherwise no issues. I think a mild pad upgrade (like a stoptech street pad) will be beneficial if you are running a higher grip road tire, but it's certainly not a necessary upgrade.
Detroit / NWOR SCCA Member
2005-06: #192 ES 91 MR2 N/A Hardtop
2007-08: #54 STX 05 WRX Sedan
2009-12: #92 BSP/ASP 07 Solstice GXP
2013-14 : #192 CS 13 Subaru BRZ
Sccabrz192 is offline   Reply With Quote
Old 08-10-2013, 12:25 PM   #11
feldy
feldy's Avatar
Drives: 2013 FRS Asphalt
I have 327 Autocross runs on my car between the two seasons. Still on stock pads and fluid and run a co-driver all the time. 15kmiles. Pads are still strong. No issues.
2013 Scion FR-S AT Picked up 5/30/2012
feldy is offline   Reply With Quote
Old 08-10-2013, 02:17 PM   #12
brillo
Use DOT4.
With Dot 4 do you need to change it every year or just Dot 5?
DBA Rotors & StopTech Brake Pads IN STOCK, FREE SHIPPING Import Dynamics Brakes, Suspension, Chassis 26 04-30-2013 09:05 PM
Selling stock FRS Springs/Struts + Stock Pads + Rotors 6k on all! NickFRS Brakes, Suspension, Chassis 6 03-14-2013 02:38 AM
GTS OEM rotors and pads yomchi1989 AUSTRALIA 1 12-30-2012 05:47 PM
Stock pads + rotors + springs/struts for sale in Gladstone Oregon 6k miles NickFRS Northwest 2 12-23-2012 02:03 AM
DBA rotors w/ stock pads yomchi1989 AUSTRALIA 16 12-12-2012 08:46 AM
