Old 08-01-2013, 10:26 AM   #15
Adeets
OEDC
Adeets's Avatar
Drives: Vortech 8.5psi 274WHP 2013 BRZ
Vortech
3.48 8.5 psi pully
92 WAWA gas
Borla UEL header, perrin cat-back, 500sir port injectors, 290l fuel pump.
Moto-east tune
0 knock correction, IAT kicking in at the top, more upgrades to come. (Waste gate, EBC, 2.87 pully)
My BRZ FI Build
Visconti is like a Tick that sucks as much blood(money) as he can before you figure out he's there.
please make sure to leave your experiences with visconti on his feedback thread located here: Visconti feedback
Adeets is offline   Reply With Quote
Old 08-02-2013, 11:01 PM   #16
Darryljr11
Sideways and Smiling!
Darryljr11's Avatar
Drives: Scion FR-S
-Darryl/Darryljr11
-Visconti Tuned Vortech Supercharger Kit
-93 Octane BP Gasoline
-9 PSI
-Borla UEL header, Perrin Front Pipe, Invidia Catless Front Pipe, FT86SpeedFactory V1 Catback Exhaust, Pure Automotive Custom Oil Cooler, Crawford AOS
Element Tuning 10:1 Pro Comp Long Block, Ptuning SS GT3076R turbo kit, Exedy Stage 2 Clutch, and a bunch of other stuff
Darryljr11 is offline   Reply With Quote
Old 08-03-2013, 11:05 AM   #17
Wonderbar
Driveway labs.
Wonderbar's Avatar
Drives: '13 BRZ Limited, 6sp, SWP
Carl / wonderbar
- Perrin tuned Vortech supercharger
- 91 octane water
- 9.99 psi, 9psi pulley
- header back Perrin 2.5", catted, resonated; Perrin crank pulley
- blue lines are pre-supercharger, still full exhaust/pulley, stock intake.
-'13 Subaru BRZ Limited, SWP. (Mods: Driveway Labs full aero, MCA, etc)
-'06 Mitsubishi Eclipse 3.8L, UV blue. (Mods: turbocharged, full suspension, too much to list)
-'13 Town and Country Limited (Mods: too many kids)
Wonderbar is offline   Reply With Quote
Old 08-05-2013, 09:46 AM   #18
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
Lots of superchargers
No build thread. I don't want to be reminded of how much money I spent.
[insert profound quote here]
ecko04 is offline   Reply With Quote
Old 08-05-2013, 05:31 PM   #19
jamesm
- James / jamesm
- rev works turbo kit w/ gtx2867r
- 93 octane
- 7 psi
- stock everything except clutch and front pipe.
Old 08-10-2013, 08:37 AM   #20
JD86
Drives: 2013 Toyota 86 GT
JD's AVO Turbo
-JD86
-AVO Turbo Kit (BOV, Catch Can, First run 5psi Actuator)
-Cosworth Panel Filter, Motive Overpipe/high flow cat test pipe, Kakimoto Regu CBE, AVO base tune.
-4th Gear pulls, Dyno Dynamics Dyno
Name:  Dyno Comparrison.png
Comparrison between stock car and stage 1 kit.
-Upgraded to AVO 7psi actuator, ECUtek controlled boost, Tokyo Motorsports tune.
-Dynapack hub dyno.
Green line Torque (NM), Blue line Power (KW), Yellow line Boost (KPa)
JD86 is offline   Reply With Quote
Old 09-01-2013, 09:17 PM   #21
Adeets
OEDC
Adeets's Avatar
Bump to the top, need more turbos, and the new innovate tunes.
My BRZ FI Build
Old 09-02-2013, 04:08 AM   #22
wrxgoose
WUB WUB
Drives: 2013 Firestorm
that's the most recent tune, i'm not gonna try to get any more until i get a new clutch and the injectors/pump installed. And yes, i know that it's off by a thousand RPM. think the dude had a brain fart with setting up the dyno
wrxgoose is offline   Reply With Quote
Old 09-02-2013, 01:19 PM   #23
sw20kosh
Drives: 2013 Black FR-S
I would love to see what this makes on a dynojet!!!
Old 09-02-2013, 01:31 PM   #24
wrxgoose
WUB WUB
once I've got money, i'm gonna toss it back on a mustang dyno. the one that i showed 174whp stock.
Old 09-02-2013, 11:06 PM   #25
GTB/ZR-1
GTB/ZR-1's Avatar
Drives: '13 BRZ in WRB--let's mod!!!
- George B. --GTB/ZR-1
- P&L Motorsports Base Turbo Kit
- e73
- .6 Bar/8.8 lbs
- 900cc injectors/265 pump/Motiv overpipe & catted front pipe
- FA20Club.com tuned/conservative for track days
* ‘23 Corolla GR—AutoX/DE toy
* '13 Toyobaru P&L Turbo WRB BRZ SCCA XS-A build starting. SOLD
* '22 Z51 Vette--sold.
* '09 Nissan GT-R--gone, but not forgotten... 10.63 @ 131+ on streeties.
* '90 ZR-1 11.0 @ 130.2 & 11.2 @ 132.4 sprayed 120 shot.
GTB/ZR-1 is offline   Reply With Quote
Old 09-03-2013, 09:31 AM   #26
Alhammadi
Drives: 2013 Toyota FT86
- Ali Alhammadi / Alhammadi
- Full Blown Motorsports Stage 1 Premium Turbo Kit
- 97 Octane, Bosch 550cc Injectors, 2008 Nissan Patrol Fuel Pump
- 7 psi
- 3" FBM Exhuast (Stock over pipe)
- 4th Gear Pull
Alhammadi is offline   Reply With Quote
Old 09-03-2013, 10:01 AM   #27
Adeets
OEDC
Adeets's Avatar
Anychance we can get this stickied so I don't have to dredge it up from the abyss next time someone needs this data.
My BRZ FI Build
Old 09-07-2013, 05:02 PM   #28
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
Joe Adams
Avo kit
Cat less front pipe, catback, dw 700 injectors, 3 bar map
Tuned by ptuning, manassas VA
93 pump, Max boost of 10.5, dropped to 8.5 5500 to redline (need higher wastegate actuator)
Dyno numbers list from Evasive Motorsports Meet/Dyno Fish Southern California 29 02-24-2013 03:16 AM
Dyno Compilation - dyno testing results and recommendations Illusive Engine, Exhaust, Transmission 82 02-08-2013 07:00 PM
Bolt-ons dyno comparisons thread? seven Engine, Exhaust, Transmission 6 11-25-2012 10:28 PM
Base line dyno figure (dynapak Hub dyno) gtauto AUSTRALIA 16 10-08-2012 08:06 AM
