Old 08-09-2013, 07:26 PM   #15
Matt90
Matt90's Avatar
Drives: 2013 Raven Scion FR-S
Well I'll be damned it could be all 4 bulbs are faulty ?..
Let me be more specific ,when I hard brake its at the point where I stop completely and the car jerks slightly that the LEDs turn off and back on quickly.
Matt90 is offline   Reply With Quote
Old 08-09-2013, 07:26 PM   #16
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
Loose connection?
Old 08-09-2013, 07:27 PM   #17
Matt90
Matt90's Avatar
Its happend 3 times so far
Old 08-09-2013, 07:29 PM   #18
Matt90
Matt90's Avatar
Originally Posted by boredom.is.me View Post
Lose connection?
I installed all 4 bulbs snuggly and securely the probability of all 4 doing that seems so unlikely
Old 08-09-2013, 07:36 PM   #19
kALMIGHTY
Drives: TRD Ultramarine '13
Do the AT's have the "idle dip" issue? If so, maybe when your car finally stops, the RPM's drop really low for a split second just before true idle really starts and that's when the LED's go out for a second.
Next time you're in the car and brake hard, watch how low the RPM's go and report back.
Old 08-09-2013, 07:36 PM   #20
OrbitalEllipses
Drives: Attitude
Originally Posted by kALMIGHTY View Post
You can basically see your car "dying" when it's on the verge of stalling. If that's the case, then there's nothing wrong, but if your RPM's are high, then it is a problem.
You certainly can and it's certainly funny!
Old 08-09-2013, 07:56 PM   #21
Tony Mac
Tony Mac's Avatar
Drives: SWP BRZ
I noticed this as well under hard braking. AT also. I think it does have something to do with the RPMs dropping suddenly, as the transmission lets the RPMs drop to just before stalling. When I stop gradually, this isn't an issue.
Tony Mac is offline   Reply With Quote
Old 08-10-2013, 09:45 AM   #22
wparsons
wparsons's Avatar
But he is driving an AT.
It can still let the revs drop too low... I would bet A LOT that this is 100% tied to rpm dropping too low and voltages dropping.
flickr
Old 08-10-2013, 10:37 AM   #23
s0sl0w
Proud of Boxer
My BRZ does this with the DRL strips, near as I can tell by playing with it, it's RPM related and nothing to worry about.
s0sl0w is offline   Reply With Quote
Old 08-10-2013, 10:37 AM   #24
Xanzent
Xanzent's Avatar
Drives: 2013 Scion FR-S Asphalt
LEDs unlike traditional filament bulbs are either on or off, and require a minimum voltage to operate. Assuming you're in gear the entire time you're stopping, the revs are dipping below normal idle and as a result the voltage going to the lights is dropping.
Filament lights would just dim in this situation, but LED lights, if the voltage gets too low, will simply shut off. This is perfectly normal and unavoidable.
Xanzent is offline   Reply With Quote
Old 08-10-2013, 12:13 PM   #25
DJ_Joee
Drives: 2013 BRZ Sport/Tech Pearl White
When I am driving and braking normally everything is fine , but if I need to hit the breaks hard from a decent speed I noticed my DTRs will turn off until I stop completely then turn back on as if nothing happend.. ( I can see the lights shut off in the reflection of other cars ahead of me ) is this normal ?
Funny i thaught i was crazy, i have swp limited brz and i notice the same thing when hard breaking happens and to confirm this i even tried it again while holding down the ee-brake handle just to rule it out, i dont know about you but i have a canadian spec car, and people talking about rpm, it has nothing to do with it by the time i let go of the brakes im eather not less then 2000rpm or i hvae downshifted to make sure i dont drop that low (i have a manual btw)
DJ_Joee is offline   Reply With Quote
Old 08-10-2013, 01:09 PM   #26
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
You replaced your high beam with LEDs. The high beam when on DRL mode use a reduced voltage so you don't blind people when it's not totally sunny, they're not getting 12-14 volts when in operation.
So maybe you're getting 6 volts or so, any reduced voltage might be enough to shut off the LEDs.
Rayme is offline   Reply With Quote
Old 08-10-2013, 07:18 PM   #27
DJ_Joee
I beleive where talking about the brz witch comes with led drl from factory (right above the fogs) well at least i am!
FR-S / BRZ Turn Signal LEDs! No Resistors! Switchbacks! Plug & Play Install! Diode Dynamics Interior Parts (Incl. Lighting) 158 08-08-2018 07:52 PM
** INTRO PRICING** JWM Switchback Turn Signal LEDS For FR-S Owners JWMotoring Exterior Parts - Lighting 212 04-07-2014 12:24 AM
Quickets AND Cheapest Turn signal and DRL LEDs? BlackyRose Cosmetic Modification (Interior/Exterior/Lighting) 2 06-17-2013 10:52 PM
