Old 08-09-2013, 06:13 PM   #1
Matt90
Matt90's Avatar
Drives: 2013 Raven Scion FR-S
LEDs dim/turn off when braking ?
When I am driving and braking normally everything is fine , but if I need to hit the breaks hard from a decent speed I noticed my DTRs will turn off until I stop completely then turn back on as if nothing happend.. ( I can see the lights shut off in the reflection of other cars ahead of me ) is this normal ?
Matt90 is offline   Reply With Quote
Old 08-09-2013, 06:20 PM   #2
beaver_scott
beaver_scott's Avatar
Drives: 2013 FRS hot lava
Not normal. They come on when the e brake is released. Something doesn't sound right.
beaver_scott is offline   Reply With Quote
Old 08-09-2013, 06:27 PM   #3
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
I'm sorry but your car is totaled.
Just take it into the dealership. Check your e-brake handle to make sure it doesn't wiggle or anything like that.
Old 08-09-2013, 06:31 PM   #4
Matt90
Matt90's Avatar
I forgot to add this is for the LEDs only the newly installed day time running lights and switchbacks. Stock bulbs work fine. Precision leds
Old 08-09-2013, 06:34 PM   #5
boredom.is.me
Custom User Title
Contact P-LEDs about it.
Old 08-09-2013, 06:43 PM   #6
Gen
Drives: Scion FR-S
Sounds like your RPM may be dipping too low under hard braking if these are DRLs.
Gen is offline   Reply With Quote
Old 08-09-2013, 06:48 PM   #7
boredom.is.me
Custom User Title
How can the DRL's be related to RPM? It's either you are on (driving) or not (off or parked). DRL's are a safety feature so they aren't supposed to shut off with low RPM.
Old 08-09-2013, 07:10 PM   #8
kALMIGHTY
Drives: TRD Ultramarine '13
If the RPM's drop too low, and you're lugging the engine, even the stock bulbs start to fade out and turn off until you push in the clutch or give it a bit of gas for the RPM's to go up, and the bulbs go back to full brightness.
You can basically see your car "dying" when it's on the verge of stalling. If that's the case, then there's nothing wrong, but if your RPM's are high, then it is a problem.
The Following 2 Users Say Thank You to kALMIGHTY For This Useful Post:
boredom.is.me (08-09-2013), Matt90 (08-09-2013)
Old 08-09-2013, 07:14 PM   #9
Matt90
Matt90's Avatar
Kal , I drive AT, manual mode usually and sometimes I downshift aggressively .. could that with braking be the issue ? I should test this with it in auto mode and see if it happens ? I read LEDs can't dim like stock bulbs they just shut off ?
Old 08-09-2013, 07:16 PM   #10
Matt90
Matt90's Avatar
Would be hard to beleive both DTR and switch backs are bad ..
Old 08-09-2013, 07:19 PM   #11
kALMIGHTY
If you're downshifting and braking, even if it's aggressively, in an AT, there's definitely a problem. The situation I described happens in my MT when the car is about to stall, but that's not a problem with AT so there's no reason for the car to have that "death" effect.
If this doesn't happen in AT with the stock bulbs for you, it shouldn't happen with LED's either. Check to make sure the connections to the LED's aren't loose and just temporarily come undone under hard braking and if you can't fix it, then I suggest contacting the people you bought your DRL's and switchbacks from and asking for a replacement set.
Old 08-09-2013, 07:20 PM   #12
wparsons
wparsons's Avatar
It really sounds like under braking the revs are dropping low and there isn't enough voltage being supplied by the alternator so the voltage to the bulbs drops. I can recreate this on mine by letting the revs drop too low from a stop (manual).
flickr
Old 08-09-2013, 07:20 PM   #13
boredom.is.me
Custom User Title
Ah I see what you mean now.
I'm not sure you can lug the engine in an AT.
Old 08-09-2013, 07:21 PM   #14
boredom.is.me
Custom User Title
But he is driving an AT.
FR-S / BRZ Turn Signal LEDs! No Resistors! Switchbacks! Plug & Play Install! Diode Dynamics Interior Parts (Incl. Lighting) 158 08-08-2018 07:52 PM
** INTRO PRICING** JWM Switchback Turn Signal LEDS For FR-S Owners JWMotoring Exterior Parts - Lighting 212 04-07-2014 12:24 AM
Quickets AND Cheapest Turn signal and DRL LEDs? BlackyRose Cosmetic Modification (Interior/Exterior/Lighting) 2 06-17-2013 10:52 PM
