Old 08-08-2013, 10:19 PM   #57
M_Dubbs
Drives: My lil bro has a white BRZ limited
Originally Posted by DrDuquette View Post
Just like the hitch used on the MINI COOPER. Way to go!!! Those are good connection points. Best yet!!! Super light.
It's my brother's car. I have an 09 WRX but get on here sometimes. I've worked on 2 BRZs though. The rack pieces are in the tow hook holes. Super solid.
M_Dubbs is offline   Reply With Quote
Old 08-09-2013, 07:34 AM   #58
a2cpc
Drives: WRX
Lol, yeah, got the yakima bars and forklift bike rack. Guess I'll have to slap it on tonight to take pics Actually considered the seasuckers, but I also had a storage rack that I use when camping once in a while.
I wonder if you could throw a kayak or two on top if you had the Yakima bars?
a2cpc is offline   Reply With Quote
Old 08-09-2013, 10:53 AM   #59
Jymrv
Drives: Subaru BRZ-Black
Yakima makes the clips for their Q-Towers for the BRZ. You can run whatever setup you want that they offer within the weight restrictions. I won't put a roof rack on a car again unless there are rails due to the silicone pads which gum up the finish. PITA! I have used the rods in the tow hook ports for 8 months now and it works really well. If you use the locks on the system it locks to the car. How does the sea sucker not dent the roof when you hit a bump?
Jymrv is offline   Reply With Quote
Old 08-09-2013, 12:14 PM   #60
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
Not sure, but it maybe a little iffy. The contour of the roof and the way the bars mount cause span between the bars to be very short. I actually had to a little bit more research to find the right cargo box that could mount at a short enough span. I think you might me able to mount a short kayak no problem.
Old 08-09-2013, 12:17 PM   #61
BigFatFlip
BigFatFlip's Avatar
Yeah, had the same problem. Solution: clear vinyl strips where the mounts contact. I've used the Lamin-x rack guard http://www.lamin-x.com/Roof-Rack-Pai...ion-p/rr-8.htm
Old 08-09-2013, 02:42 PM   #62
TurboBrett
Drives: 13 BRZ
Did you make or buy these?
TurboBrett is offline   Reply With Quote
Old 08-10-2013, 02:34 AM   #63
Jymrv
You have to have them made. About $140 or so then buy a rack to fit.
Old 08-13-2013, 08:25 AM   #64
Deslock
Deslock's Avatar
Drives: 2013 DZE/01 (sold for MX5 ND1)
Current state of FT86 bike racks, AFAIK:
kask2_6.0's Trailer Hitch
+ holds up to 4 bikes (depending on rack purchased)
+ stable
+ if you wire for lights, can be used with small trailer too
+ only ~10 pounds added, and all down low (not counting the rack itself)
+ won't scuff paint anywhere
+ easy to remove bike rack
- expensive
- no warranty (technically not rated and "offroad use only" so if something goes wrong, you're on your own)
- possible clearance issues on such a low car
- more work to install (disassemble bumper, trim flange)
UHaul Trailer Hitch
+ stable
- expensive
- weight unknown
- installation process unknown
- no one at ft86club has one yet (AFAIK)
Roof rack
+ holds up to 2 bikes
+ stable
+ out of the way
+ can use cross bars to carry other things
- expensive
- increases drag (even without bikes)
- adds weight on top
- without adding vinyl sheets, may scuff paint a bit
Tow hook bars
+ stable
+ (presumably) reasonable price
- not available yet (unless DIY)
- only holds 1 bike
- possibly partially in way of trunk when loaded (doesn't swing down like a class 1 rack)
Sea Sucker
+ won't scuff paint
+ out of the way
+ easy to remove and use on different vehicles
+ holds up to 2 bikes (if you buy a second one)
- expensive
- increases drag (when bikes are on it)
- unsure about using this on FT86's thin glass
- need to remove front wheel (also may need to do this with some other options, depending on rack purchased)
Strap mounted trunk rack
+ cheap
+ folds for storage
- less stable
- may scuff paint
- in way of trunk
Inside trunk
+ free
+ secure
- only fits 1 bike
- must fold down rear seat and use trunk space
- may scuff interior and/or get dirt/water/mud inside
- may be difficult to fit some bikes
I have kask2_6.0's trailer hitch (but haven't installed it yet).
A couple of the more intriguing strap racks I've seen are the Allen MT1 ([ame="http://www.amazon.com/Allen-Sports-Compact-Folding-1-Bike/dp/B004C94X12"]$26[/ame]) and MT2 ( [ame="http://www.amazon.com/Allen-Sports-Compact-Folding-2-Bike/dp/B004C966JE"]$43[/ame]). Don't seem very stable, but they're only 6-7 pounds, tiny, and come with a carry bag.
Deslock is offline   Reply With Quote
The Following 4 Users Say Thank You to Deslock For This Useful Post:
Bobharp (08-09-2021), chas3wba0 (10-04-2013), retrosmiths (02-03-2014), TurboBrett (08-13-2013)
Old 08-27-2013, 10:18 AM   #65
felisa
Drives: Subaru BRZ
Did someone try the new U-Haul trailer hitch for the FRS or know how it look (design) ?
http://www.uhaul.com/MovingSupplies/...eId=45619&ship
felisa is offline   Reply With Quote
The Following User Says Thank You to felisa For This Useful Post:
Jeff_DML (08-27-2013)
Old 09-06-2013, 11:57 PM   #66
shadowlady1997
Drives: Subaru BRZ, BMW R1150rt
U-Haul hitch
I too am very interested to find out if the hitch for the Scion FR-S will fit the BRZ. Does anyone have any idea if it will work?
shadowlady1997 is offline   Reply With Quote
Old 09-07-2013, 01:25 AM   #67
spdfreak
spdfreak's Avatar
Drives: GBS BRZ Limited
sorry, no bike rack yet. My 29er does fit with both wheels off though...
spdfreak is offline   Reply With Quote
The Following User Says Thank You to spdfreak For This Useful Post:
YW-Slayer (09-28-2013)
Old 09-07-2013, 02:03 AM   #68
vinh
Drives: a car
i have fit two track bikes in my trunk with seats folded down. i had to remove all four wheels though.
vinh is offline   Reply With Quote
Old 09-07-2013, 07:24 PM   #69
Dorb
Drives: 16 LM STI/13 LM BRZ/04 AVALANCHE
Bike rack on a sports car? I think you bought the wrong Subaru. Lol.
Dorb is offline   Reply With Quote
Old 09-07-2013, 08:39 PM   #70
Deslock
Deslock's Avatar
Sarcastic, smarmy attitude about bike racks on a sports car? I think you're in the wrong thread. LOL.
The Following 2 Users Say Thank You to Deslock For This Useful Post:
Dorb (09-10-2013), Luna (09-07-2013)
My road bike fits in the trunk Brett Scion FR-S / Toyota 86 GT86 General Forum 45 04-20-2016 05:13 PM
Factory Roof Rack? \o/ Scion FR-S / Toyota 86 GT86 General Forum 92 02-15-2013 03:25 AM
Brz limited on the rack at tire rack Nate219BRZ Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 14 07-06-2012 03:01 PM
FR-S/BRZ + Bike night in Lancaster,MA raphymartinez New England 10 06-21-2012 12:58 PM
Tire Rack still needs a BRZ! Lonewolf Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 06-12-2012 02:35 PM
