Old 08-08-2013, 08:56 PM   #855
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Originally Posted by GrimmSpeed View Post
This is not far off from the 12ft-lbs recommended for those studs,
Ummm.... totally unscientific opinion coming up:
12 ft-ibs doesn't read like much to stop any tower flex.
Old 08-08-2013, 08:59 PM   #856
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
we need those other 2 diagonal bars
Old 08-08-2013, 09:30 PM   #857
dhenson405
Drives: 13` argento FRS
Add me to the list! Red looking sick
dhenson405 is offline   Reply With Quote
Old 08-08-2013, 10:04 PM   #858
Brzzee
Brzzee's Avatar
Drives: 2015 Subaru BRZ WRBP Limited 6MT.
Black bar to 75088 please.
- When men make plans the gods laugh.
Brzzee is offline   Reply With Quote
Old 08-08-2013, 10:05 PM   #859
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
@loogs get this
Old 08-08-2013, 10:17 PM   #860
zex
zex's Avatar
Drives: Subaru WRB BRZ Limited
Wow did not see this til now.. interested ! Put me down
zex is offline   Reply With Quote
Old 08-08-2013, 10:19 PM   #861
chanomatik
Snow Don't Hurt!
chanomatik's Avatar
That energy is spread out across the bar, yo. Dissipation and shiz, dawg. Transference and all dat, son. Nahmean?
Old 08-08-2013, 11:54 PM   #862
Captain Snooze
Drives: Red Herring
Originally Posted by chanomatik View Post
Nahmean?
No I don't because it is the bolts that are anchoring the bar. If the mounting isn't strong enough the strongest bar in the world would be useless.
Old 08-09-2013, 02:25 AM   #863
doggieboy09
Sènior Member
doggieboy09's Avatar
Drives: '22 BRZ |'13 BRZ SSC (formerly)
I want one RIGHT NOAW!
doggieboy09 is offline   Reply With Quote
Old 08-09-2013, 09:40 AM   #864
HSC
Drives: Whiteout FR-S
Yea, I'm still trying to understand that too. Considering everyone discourages against strut bars with pivot points (Cusco) and says it needs to be rigid, yet its anchor points are only torqued to 12 ft lbs? Wouldnt the chasis flex that this bar is trying to prevent exert more than 12 ft lbs? Just trying to understand this bar's full benefit.
HSC is offline   Reply With Quote
Old 08-09-2013, 10:50 AM   #865
mottor
mottor's Avatar
The thing is, you have to consider where the force is being applied to the bar. When the chassis flexes it will push the two mounting points toward each other, rather than up or down. Most of the stress is not on the nut securing the bar, but on the bolt itself. When the chassis flexes on one side, the bar will be pushing outward on both mounting points. The bar would have to cut the bolts in half to fail.
2013 Asphalt FR-S 6MT - Perrin 2.5" Catback Exhaust - Grimmspeed Strut Tower Bar - Grimmspeed Master Cylinder Brace
Grimmspeed Hood Struts - Grimmspeed 86 Oil Cap - Grimmspeed Boxer Battery Tie Down - HID - Pioneer AVH-X5500BHS - Infinity Basslink 10" Sub
mottor is offline   Reply With Quote
Old 08-09-2013, 12:52 PM   #866
HSC
Thanks for the explanation but just like how its forces applied are not perfectly vertical, they are not perfectly horizontal either. I see the bar being "twisted" as it tries to prevent chasis flex and have to believe some of that torque will be applied in a vertical direction that the 2 nuts/bolts will then have to undergo.
Old 08-09-2013, 01:44 PM   #867
GrimmSpeed
GrimmSpeed's Avatar
Drives: '13 BRZ, '12 WRX
Send a message via AIM to GrimmSpeed Send a message via MSN to GrimmSpeed
I have a sneaking suspicion that Chase will have a longer answer for you when he's back in the office on Monday, but here's my quick $0.02 regarding the torque spec.
First of all, we've tested it pretty thoroughly, and haven't had a single issue. The second is that 12ftlb doesn't sound like much, but it all depends on the fastener. Bolting something together isn't about how tight the bolt is, necessarily, it's about the clamping load that the head of the bolt and the nut exert. The bolt stretches as you tighten it and that's what provides the force. Take head studs, for example. The same set of studs with different lube and the same torque applied will produce clamping loads that are likely much different. In that same manner, two different bolts with the same lube (or no lube) and the same torque will provide different clamping forces.
In an application like this, the bolts are not being used in shear. They're used to clear a clamping load. Your wheels are held to your car just the same way. You're applying a clamping force and it's the force/friction between your hub and wheel that are actually interfacing. None of your studs/lug bolts should be experiencing any sort of shearing force. Make sense?
Here's a good chart that shows how clamping force and the applied torque behave. You can see on the bottom that a larger bolt requires a much larger applied torque to provide the same clamping force. This is why it's so important to be careful with smaller fasteners!
http://www.spaenaur.com/pdf/sectionD/D48.pdf
Chase will be back on Monday with what will probably be a much simpler answer!
Matt Beenen
Engineering
GrimmSpeed is offline   Reply With Quote
The Following 2 Users Say Thank You to GrimmSpeed For This Useful Post:
chanomatik (08-09-2013), kwood9000 (08-09-2013)
Old 08-09-2013, 01:48 PM   #868
GrimmSpeed
GrimmSpeed's Avatar
Your stock bars are just fine!
Done!
Got you added!
Thanks for the support, got you added!
Got you on the list!
So glad you guys are thinking critically about the parts that you buy! That's exactly how it should be! I gave you a quick explanation above as to why 12ftlb is plenty!
Matt Beenen
Engineering
Anyone using the STi Flexible Strut Tower Brace? ngabdala Suspension | Chassis | Brakes -- Sponsored by 949 Racing 45 08-15-2019 01:59 AM
F/S Beatrush Strut Tower Brace Type-2 $175 Dan-in-Japan Brakes, Suspension, Chassis 2 02-24-2013 01:38 PM
FT-86 SpeedFactory Strut Tower Brace Review F1point4 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 35 01-07-2013 04:31 AM
DIY - Strut Tower Brace - FT-86 SpeedFactory F1point4 DIY (Do-It-Yourself) Guides 4 10-28-2012 04:30 PM
