Old 08-08-2013, 04:08 AM   #29
Efferalgan
Drives: 2025 BRZ, ex-2012 GT86
GFB water pump pulley is 0.50-0.53, not 0.75 - it's a typo, copy/paste of the crank pulley weight which was copied by many resources.
http://www.ft86club.com/forums/showthread.php?t=24081
Efferalgan is offline   Reply With Quote
Old 08-08-2013, 04:59 AM   #30
Anthony
Weight Nazi
Anthony's Avatar
Drives: 13 FRS -399lb, 11 335is, 05 Tiburon
Originally Posted by Hawk77FT View Post
You got some different numbers than I did here. Where did you get your numbers from? I used ft86speedfactory.com and the Raceseng thread.
Build Thread | The Venus Project | Any car which holds together for a whole race is too heavy.
Anthony is offline   Reply With Quote
The Following User Says Thank You to Anthony For This Useful Post:
Hawk77FT (08-08-2013)
Old 08-08-2013, 09:31 PM   #31
nabe
Drives: 86
Originally Posted by diss7 View Post
My toda units will be here in a week. Will get you the missing weights.
Remember its not just weights. The toda units are under-drive, which puts even less strain on the motor.
Did you order from toda direct?
nabe is offline   Reply With Quote
Old 08-08-2013, 09:42 PM   #32
diss7
Drives: AE86, 2x GT86, TE27
No, I went via a importer - www.41.co.nz
I've used them quite a bit.
diss7 is offline   Reply With Quote
The Following User Says Thank You to diss7 For This Useful Post:
nabe (08-08-2013)
Old 08-08-2013, 09:49 PM   #33
nabe
Drives: 86
really keen on the toda kit, lets us know your feedback once installed.
The Following User Says Thank You to nabe For This Useful Post:
diss7 (08-08-2013)
Old 08-09-2013, 11:59 AM   #34
tom@kartboy
tom@kartboy's Avatar
Drives: American Made Shift!
Hi all,
First of all I have no affiliation with ANY of the companies listed here. I am more than happy to be corrected or have some figures added to this table.
Basically, being in the market for a set of light weight pulleys I have put together a table to compare the brands, weights and their offering. As you can see some offer only the crank pulley others the whole set. Only one offers the 2 idlers in the set. At the top you can see the stock weight too. I couldnt find the Idler weight so if anyone knows it, please feel free to let me know and I will update it.
The price might change from vendor to vendor so you will have to hunt for the best deal.
So if anyone has any input please let me know.(please post the link/source of your info). Enjoy!
Attachment 46870
Our pulley sells for 95.00 not the 110 listed here. We are also looking into doing a run of accessory pulleys to match our crank pulley.
Tom
tom@kartboy is offline   Reply With Quote
Old 08-09-2013, 02:51 PM   #35
CamryDS
Drives: 2003 Camry Blue | 2013 FR-S White
hmm with these pulleys anyone notice any stability issues or negative changes with a completely stock engine. I've been wanting to pull the trigger on this but not sure how it will affect the car if there's any negative affects at all.
CamryDS is offline   Reply With Quote
Old 08-15-2013, 05:20 AM   #36
Hawk77FT
Drives: GTS 86
Just checked them and they are pretty much the same.
Hawk77FT is offline   Reply With Quote
Old 07-01-2014, 01:12 PM   #37
Namuna
Namuna's Avatar
New player to the game: Non-Stop Tuning (NST).
Material: 6061-T6 aircraft aluminum
Crank: 12oz/0.75lbs.
Water Pump: 10oz/0.625lbs.
Alternator: 3oz/0.18lbs.
Kit MSRP: $248.00
Groupbuy currently going on: http://www.ft86club.com/forums/showthread.php?t=68052
Namuna is offline   Reply With Quote
Old 07-01-2014, 01:18 PM   #38
calibrz
Turbo 86
Drives: GT86
Kit MSRP: $248.00
these things seems like the ebay ones for $50
10 - 1 = 0
real math
calibrz is offline   Reply With Quote
Old 07-01-2014, 01:23 PM   #39
stugray
Drives: 2013 GBS BRZ Limited
The "underdrive" vs stock pulley diameters is key to how these work. (so should probably be included in the chart)
If you want to feel a difference (HP gain), then you need the underdrive pulleys.
If you just want to reduce the total vehicle weight, then all you care about is total weight difference.
Old 07-01-2014, 01:40 PM   #40
Namuna
Namuna's Avatar
Here's a snip from the description for the NST Kit:
"The NST Lite series is designed for owners looking to reduce weight and increase the throttle response of their engines. These OEM-diameter pulleys will neither underdrive nor overdrive the associated accessories, yet lead to great throttle response and improved horsepower numbers in many applications."
AFAIK, no one makes an underdrive pulley for the 86. I have no expectation of any kind of HP/Tq gain, I'm getting a kit for the better throttle response.
Old 07-01-2014, 01:46 PM   #41
stugray
See above where other posters discuss the underdrive options.
I have no intention of ruining this thread with a long debate about the benefits (or lack thereof) of pulleys. However there is no basis in fact for the statement : "yet lead to great throttle response and improved horsepower numbers in many applications". That is purely marketing BS.
If you would like to debate this, then ressurect one of the old threads on the topic. There are many to choose from (hint: search by my name)
http://www.ft86club.com/forums/showthread.php?t=54612
http://www.ft86club.com/forums/showthread.php?t=50879
http://www.ft86club.com/forums/showthread.php?t=59641
Old 07-01-2014, 04:58 PM   #42
Namuna
Namuna's Avatar
...I have no intention of ruining this thread with a long debate about the benefits (or lack thereof) of pulleys. However there is no basis in fact for the statement : "yet lead to great throttle response and improved horsepower numbers in many applications". That is purely marketing BS.
If you would like to debate this...
Nope, not looking to debate. I was merely quoting NST's statement (I have no affiliation) and trying to be helpful as far as contributing to the info pool.
I've read your comments and theoreticals about how these lightweight pulleys should have no appreciable effect to performance (via HP gain). But as I've already stated, I have no expectations of any kind of HP/Torque gains (I absolutely agree with you that that's marketing BS, or if there are any gains it would be too inconsequential to merit mention), but I AM expecting to gain the quicker throttle response.
The Following User Says Thank You to Namuna For This Useful Post:
stugray (07-01-2014)
Wheel Balancing Weights Black Tire Tracking / Autocross / HPDE / Drifting 4 06-13-2013 05:51 PM
Corner weights - Toyota 86 diss7 Scion FR-S / Toyota 86 GT86 General Forum 15 04-07-2013 07:30 PM
Wheel weights BAE Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-09-2012 09:16 AM
does anyone know why GT86 weights so much? wu_dot_com Scion FR-S / Toyota 86 GT86 General Forum 85 03-19-2012 04:24 PM
