Old 04-26-2013, 02:25 AM   #15
SuiSid3l
Drives: 2013 Scion FR-S Whiteout White
Originally Posted by GTM_Challenge View Post
18x9.5 +40 can fit with 265 all around with proper camber settings. The rear might just slightly rub the bumper plastic at worst accoding to customers.
Appreciate the information, the rpf1's are 38 offset i believe. The car wont be low enough to worry about the fenders I dont believe. I was more worried about it rubbing against the shock mount or the springs. I just dont wanna have to get crazy with the camber but I want some rim protection and it looks so much cleaner.
SuiSid3l is offline   Reply With Quote
Old 04-26-2013, 06:28 AM   #16
PRORICAN
PRORICAN's Avatar
I'm on stock struts with lowering springs so I had to use a 3mm spacer up front to avoid rubbing on the strut.
PRORICAN is offline   Reply With Quote
Old 04-26-2013, 02:44 PM   #17
PRORICAN
PRORICAN's Avatar
Originally Posted by Tansey86 View Post
Looks great! How much camber out back?
Thanks, not sure on exact camber but its on Eibach sport lines so whatever camber you get when putting those on is what it has. Need to get an alignment done but probably after coilovers.
Old 04-26-2013, 03:49 PM   #18
PRORICAN
PRORICAN's Avatar
Originally Posted by Touge Factory View Post
Nice setup!
Love NT03's!
No rubbing issues while driving?
We ran the 245 Yoko S.Drives up front (they run slightly wider then the FK452's) and ran into rubbing issues on the inside fender liner up front while turning.
Surprisingly no, but maybe is because I'm not too low and running a 3mm spacer pushing the wheel further out. I haven't heard any rubbing/touching noises and just went outside to check if there are any signs of it.
Old 05-09-2013, 06:43 PM   #19
PRORICAN
PRORICAN's Avatar
Wow, amazing. Looks like you rolled the rear fenders? How did you camber dialed back so much being that low?
Thanks! I still need an alignment but Im guessing is close to -3deg right now and dont plan on keeping it that way. Hoping closer to -2deg. No fenders rolled yet, but I am rubbing on the rear plastic bumper tab which Im going to trim.
Old 05-10-2013, 03:00 PM   #20
PRORICAN
PRORICAN's Avatar
Originally Posted by Vonsamhain View Post
Can you measure the distance between your stock caliper and wheel spoke for clearance. These are the wheels I want but I'm running wilwwoods. Need a few extra mm. Thanks
I'll try to help you when I get a chance.
Old 05-10-2013, 06:55 PM   #21
PRORICAN
PRORICAN's Avatar
The Following 2 Users Say Thank You to PRORICAN For This Useful Post:
TouchMyHonda (03-03-2014), trigger happy (04-06-2016)
Old 05-14-2013, 05:35 PM   #22
PRORICAN
PRORICAN's Avatar
Originally Posted by TheSlickOne17 View Post
What you dropped on?
ISC coilovers
Old 05-18-2013, 10:13 PM   #23
PRORICAN
PRORICAN's Avatar
The Following User Says Thank You to PRORICAN For This Useful Post:
Metabrz (05-21-2013)
Old 08-07-2013, 05:14 PM   #24
Touge Factory
Touge Factory's Avatar
Drives: ZN6
Send a message via AIM to Touge Factory
One of the staff at TF picked up a FR-S...and put these bad boys on.
SBC NT03's!
Touge Factory is offline   Reply With Quote
The Following 2 Users Say Thank You to Touge Factory For This Useful Post:
evo4g63 (08-07-2013), PRORICAN (08-07-2013)
Old 08-07-2013, 06:53 PM   #25
ajcacio
Drives: DGM BRZ-L
Might as well put this here:
ajcacio is offline   Reply With Quote
The Following 2 Users Say Thank You to ajcacio For This Useful Post:
PRORICAN (08-07-2013), Tansey86 (08-20-2013)
Old 08-18-2013, 10:47 AM   #26
PRORICAN
PRORICAN's Avatar
Originally Posted by etherealfall View Post
Just checking that it is correct - 265s on 18x9.5+40 requires 3mm spacer to clear, 245s without spacer will rub against inner strut lining
Will any camber + fender work help for the 245s or will I just HAVE to run the spacer?
People were having 18x10 +44s with 2-3mm inner clearance; I thought 18x9.5+40 will be fine!
Are you talking about stock suspension or coilovers? Because with coilovers you won't need spacers.
Old 08-20-2013, 09:36 AM   #27
etherealfall
Drives: Toyota 86 GTS Storm Black
i was meaning stock suspension
etherealfall is offline   Reply With Quote
Old 08-28-2013, 08:51 PM   #28
Touge Factory
Drives: ZN6
Originally Posted by loogs View Post
what spacers were used on the 17x9's and where (front and back or just back, etc) ???
thx
both cars look awesome
also need tire specs on 17's
We're using the 5x100 to 5x114 Conversion spacers by Kics (10mm)
Enkei RPF1's are 17x9 +45 in 5x114... after spacers they are 17x9 +35
Wheel Directory: Enkei RS05RR 18x9.5 +43 FT-86 SpeedFactory Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 129 09-22-2019 10:39 PM
Wheel Directory: Enkei Raijin 18x8.5 +45 / 18x9.5 +45 GuerillaRacing Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 221 08-01-2019 10:30 AM
Wheel Directory: Enkei RPF1 18x9.5 +38 FRS8SIX Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 297 02-15-2018 03:50 PM
Wheel Directory: Enkei Tenjin 18x8.5 +45/18x9.5 +45 Sciby Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 11-10-2014 12:53 AM
Wheel Directory: Work Meister S1 3-Pc 18x9.5 +29 / 18x9.5 +24 PradiG Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 48 12-12-2013 03:15 AM
