Old 08-06-2013, 09:11 PM   #29
Firesnake
Firesnake's Avatar
Drives: Whiteout
BTW I should be more clear about the specificity that determines "best" tire. I went with PSS for the reasons mentioned above. I'm planning on keeping on getting an extra set of wheels with the Primacy HP to stay true to the 86's OG dynamic: to let it slide.
My OEM tires, being not so sticky, facilitates the tail happiness without significantly reducing the tread...since their not sticky in the first place. So IMO, for staying true to 86, OEM setup is perfect.
Firesnake is offline   Reply With Quote
The Following User Says Thank You to Firesnake For This Useful Post:
diss7 (08-06-2013)
Old 08-06-2013, 09:23 PM   #30
diss7
Drives: AE86, 2x GT86, TE27
With that thinking in mind. 215/40 or 205/40 are even better.
Lower profile, less profile 'mush'.
They're the lightest 17" tyre size. All this talk of lightweight wheels, yet guys put on heavy/meaty tyres. Light wheel/tyre combo, better handling, steering, braking.
You can get them in an entire range of grip levels, from semi slicks to snow tyres.
They have a smaller overall diameter than stock, so effectivly shorten your gearing.
They're cheaper.
If you like driving the car more than looking at it, then consider going this way.
diss7 is offline   Reply With Quote
The Following User Says Thank You to diss7 For This Useful Post:
why? (07-11-2017)
Old 08-06-2013, 09:33 PM   #31
diss7
Originally Posted by Draco-REX View Post
Lightweight tires tend to have poor response and flatspot issues. The tires are light because they have paper thin sidewalls and thin carcasses. This lends to the issues above.
Best to stick to a known good tire if you want excellent performance.
Not always true.
205/40/17 Achilles 123S are about 17lbs, and don't suffer from anything you mention above.
They're also have more grip than anything mentioned in this thread.
They only last about 8000kms or so though. But you can only have grip or mileage at the end of the day.
You might find a tyre that can give a better compromise, slightly less grip for more mileage, but it'll probably cost 2x or 3x more than the 123S.
Old 10-14-2015, 09:58 AM   #32
jonnyfrank
Ok....I officially have hurt head, after reading about tire sizes. Classic case of the more I learn the less I know (ugh!). BRZ 2016.
I have decided on the Michelin Super Sports 245/40/17. I was significantly impacted by the below link (scroll down a bit):
Thoughts?
http://www.vorshlag.com/forums/showthread.php?t=8145
And if you disagree with the tire size, would love to know why.
jonnyfrank is offline   Reply With Quote
Old 10-14-2015, 10:35 AM   #33
murdoc
Sometimes I'm wrong.
murdoc's Avatar
Drives: '13 FR-S/'96 240SX
Thoughts?
They are putting those on 17x9s, not stock wheels.
murdoc is offline   Reply With Quote
Old 07-11-2017, 03:09 AM   #34
rookietopro_frs
rookietopro_frs's Avatar
Drives: 2013 Scion FRS
Originally Posted by Ranatsu View Post
I run 225/45r17 Dunlop Z1 StarSpecs on a set of stock wheels for autox. They fit with no problems.
I probably wouldn't run anything wider than 225 on the stock wheels personally.
Happy to know this, because I'm looking at getting Falken Azenis RT615K
rookietopro_frs is offline   Reply With Quote
Old 07-11-2017, 03:11 AM   #35
rookietopro_frs
Originally Posted by Gary in NJ View Post
The tires mentioned above are all very good tires, but I wouldn't use any of these on my car due to their weight alone. In P225/45-17 these tires weigh:
Dunlop Z1 StarSpecs = 27 pounds each
Bridgestone RE070 = 27 pounds each
Michelin pilot super sports = 22 pounds each
Yokohama AD08R = 24 pounds each
The stock 205/45-17 Primacy are 20 pounds per tire.
The Dunlop Sport Maxx R weigh 18 pounds each and Continental Extremecontact DW are 20 pounds each. Both are well suited to the car.
They might way a bit more, but I personally would rather have better grip.
Another Stock Wheels+Tires FS ($500) 636 Wheels and Tires 0 05-09-2013 12:30 PM
FS: Stock Wheels and Tires - DFW boombacloud Wheels and Tires 1 05-04-2013 12:42 PM
FS: Stock Wheels+Stock Tires+TPMS sensor Pin Flare Wheels and Tires 1 03-26-2013 12:07 PM
FS: STOCK FRS WHEELS AND TIRES stevieb0y Wheels and Tires 4 03-11-2013 09:29 PM
17” OZ Alleggerita wheels with stock 215/45-17 tires… 17x7.5 or 17x8 wheels? SteveH Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 02-14-2013 11:26 PM
