go_a_way1
Old 08-06-2013, 12:50 PM   #1233
bfrank1972
Drives: 2013 FR-S Argento
This thing definitely has my attention - any prediction/hypothesis on what would happen on a track day? AutoX?
For instance, what happens as voltage drops - does it limit boost or just shut itself off completely. At some point in a full on DE event it would just run out of juice completely, what does it do?
Battery/motor overheating risks? Protections built in?
For track days could it have an 'idle' mode that it just spins in low speed 'non-restriction' mode? Or perhaps lower max boost level to extend battery?
Thanks
Old 08-06-2013, 12:57 PM   #1234
Robftss
Drives: VW
Battery/motor overheating risks? Protections build it?
Thanks
Phantomsuperchargers.com has all the specification regarding your questions.
Under Superchargers tab /TQ-25024V & Electronics, all ratings provided.
Robftss is offline   Reply With Quote
The Following User Says Thank You to Robftss For This Useful Post:
DAEMANO (08-06-2013)
Old 08-06-2013, 01:24 PM   #1235
bfrank1972
Thanks that answers a few of my questions - I also need to spend time digging through this massive thread (sorry wasn't trying to be lazy ). Basically just trying to gauge what happens when I go to my local DE events - I'd be happy to run it without the supercharger, so I'd probably just shut the thing off. AutoX it should be enough for a run - I also very much like the idea that this thing is easily uninstalled. Would be huge fun with it on an AutoX course, but obviously puts the car in a tough class, so I'd like to be able to pull it off and just run STX competitively when I want.
Old 08-06-2013, 02:58 PM   #1236
Bu-Tang
Drives: 2013 Scion FR-S, Nissan Pathfinder
Originally Posted by nonicname View Post
was this from 1st? or single gear pulls?
Some 1st - 3rd, some 2-5th as well, I forgot I do have na pulls between us well a but I lost those.
Sent from my SGH-I337M using Tapatalk 4
Bu-Tang is offline   Reply With Quote
Old 08-06-2013, 03:44 PM   #1237
asher187
Drives: 2013 FR-S, 1995 Civic Coupe
Smile Count me in too...
Waiting to hear about pre-orders....
You can count me in too!
asher187 is offline   Reply With Quote
Old 08-06-2013, 03:53 PM   #1238
asher187
Thumbs up Looking forward to it too....
Thanks
Very good questions, but from what I can see so far if one were to flip it off when it gets low to let it charge back up for straights it would still have a great deal of usefulness on a track with 2-3.5 minute or so laps. I think with practice one could learn to use it effectively even on the track (You won't be 75% or > WOT the entire drive) I read the entire post and did a lot of my own research and I think this application might have a good mix of usefulness for the predicted/expected price of ~$1500. It's not a dream come true solution, but I think 30Hp and 55TQ on demand will be fun and useful in many situations with the right tuning. Keep in mind engineering phase not even in the hands of master tuners.
Old 08-06-2013, 05:51 PM   #1239
fenton
You don't even have to shut it off, just don't go over 80 percent physical throttle.... That's still 100 percent throttle to the ecu anyways.... You can test this out yourself just go 50 to 70 percent throttle in 3rd gear and then go 100 physical and see if you accelerate more.... you won't.
Sent from my HTC One using Tapatalk 4
fenton is offline   Reply With Quote
The Following User Says Thank You to fenton For This Useful Post:
nonicname (08-06-2013)
Old 08-06-2013, 05:55 PM   #1240
fenton
This thing is a absolute blast on the street. Just point and shoot as merging or passing cars. Its a very noticeable difference.
What was once a slow car and could be overtaken by a Camry or Toyota sienna is now faster than many cars on the road.
Adding 80 torque is increasing the total output by almost 60 percent
Old 08-06-2013, 05:58 PM   #1241
nonicname
Drives: it has 4 wheels and a motor
that's interesting.
nonicname is offline   Reply With Quote
Old 08-06-2013, 06:45 PM   #1242
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
Here's a question: with a few of us wondering if the unichip could be utilized to run this I was wondering if the motor controller on the phantom was variable.
The unichip reads the throttle position so in theory we could use the unichip to control the speed of the super charger that way it's not full bore on when activated. I.e variable speed on the supercharger based on throttle position.
Installed Mods:
Old 08-06-2013, 06:51 PM   #1243
bakerr6
Drives: 2013 raven black fr-s
You could utilize the unichip to run this, but you would need to alter the reading to pass through the unichip first. What I mean by this is for instance, you could controll boost with the boost controller built into the unichip, I don't see why you couldn't control the load via an input signal into the unichip. May be an interesting theory.
I'm still new to this whole theory, but have been paying close attention. I like the idea of the electric supercharger
bakerr6 is offline   Reply With Quote
Old 08-06-2013, 06:51 PM   #1244
bfrank1972
Fenton, looking at your dyno charts I don't doubt it. At SL I'm thinking the torque curve is starting to look similar to my old E36 M3 (but in a much much lighter vehicle).
So I'm sifting through this entire thread now, and have read the specs on Phantom's website (what I could make of them). To circle back to one of my original questions - say I leave the thing on and just run it wide open at the track. I mean run the hell out of it. What happens when you completely deplete the batteries? Anything bad? Does it eventually start placing heavy load on your alternator or does the control module shut things down?
I know we're in the development stages here, just curious. Sounds like you guys might need a 'sea level' tester. Ahem cough I live near the beach
Old 08-06-2013, 07:03 PM   #1245
Calum
That Guy
Drives: 2013 asphalt FRS MT
A few of us have inquired about this but have never gotten a straight answer. They were able to setup an 'idle' speed where the charger spins just fast enough to not cause a restriction. But I have a feeling it wasn't a setting in the firm ware or anything that is continuously variable. It's probably hardware changes that allowed them to do this.
Old 08-06-2013, 07:08 PM   #1246
Tromatic
If you are going to race this thing, wont you have done some serious work making the car lighter? 50 pounds of some of the new LiPo batteries should get you through a race. Some of the power systems the car-stereo tards run would probably power this thing for a week.
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 05:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 07:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 08:07 AM
