Old 08-06-2013, 10:31 AM   #127
ft_sjo
Drives: GT86
Originally Posted by regal View Post
You say you don't think its an issue, not to be an A$$ but how much experience do any of us really have with Direct Injection
Not a huge amount personally, but the hundreds of powertrain engineers on this floor with their hundreds of dyno cells downstairs kind of gave me a hint.
Old 08-06-2013, 11:51 AM   #128
cevin45x
cevin45x's Avatar
Drives: '13 BRZ Limited
Hey check out this Hot Version video. At the end (around 30:20) it shows that the direct injectors were burnt out for one of their modded cars. This video I believe was released last year.
[ame="http://www.youtube.com/watch?v=LuQklVDaSjQ"]http://www.youtube.com/watch?v=LuQklVDaSjQ[/ame]
cevin45x is offline   Reply With Quote
Old 08-06-2013, 11:58 AM   #129
CSG Mike
CSG Mike's Avatar
This issue wont exhibit under dyno pulls, unless you're doing simulations.
Old 08-06-2013, 12:06 PM   #130
Dezoris
Dezoris's Avatar
Originally Posted by JackSmiley View Post
I tried checking the injectors via the driver's side area and cant seem to see a number.
Originally Posted by cevin45x View Post
Hey check out this Hot Version video. At the end (around 30:20) it shows that the direct injectors were burnt out for one of thier modded cars. This video I believe was released least year.
Thanks I just downloaded that and will re-edit that clip for easy viewing.
Old 08-06-2013, 12:09 PM   #131
Dezoris
Dezoris's Avatar
This is one of the questions I wanted to get answered.
You can see in that video they lost two seals. When we pulled the DI on our car we had two seals backed off one on each bank.
Two were "normal".
Need to understand why.
Old 08-06-2013, 12:16 PM   #132
CSG Mike
CSG Mike's Avatar
Two were "normal".
Additional data point.
One on each bank of our engine was more severely damaged than the other.
Old 08-06-2013, 02:26 PM   #133
cevin45x
cevin45x's Avatar
Two were "normal".
I saw that vid awhile back and didn't think much of it cuz I couldn't understand what they were saying. Then I saw your youtube vid. I actually joined this site to post this vid. Hopefully we can get some answers soon.
Old 08-06-2013, 02:43 PM   #134
ft_sjo
Drives: GT86
When I say dyno, i'm not talking about some amateur chassis crap.
Old 08-06-2013, 02:46 PM   #135
CSG Mike
CSG Mike's Avatar
Now I'm curious who you work for... PM if you'd rather not say publicly
Even Honda Racing only has 4 dyno cells...
Old 08-06-2013, 02:59 PM   #136
ft_sjo
Drives: GT86
A car manufacturer. It doesn't matter which one.
Old 08-06-2013, 03:01 PM   #137
R2
Front injectors or the rear ones? I wonder if there is some correlation here between your failures and some others that have happened.
R2 is offline   Reply With Quote
Old 08-19-2013, 07:28 PM   #138
Skyllz
Drives: Something fun.
Noticed something last week-end, I just want to know if it's related to this issue or not.
When driving around town, if I short shift "aggressively" around 3500-4000 from 2-3 then 3-4. I can make it ping 90% of the time and it would ping from the moment I would start giving it gas as the clutch starts to grab again until the clutch is fully depressed. Does not last long but it was loud enough even my wife noticed.
I talked to my dealer about it and he has no clue, "first time I hear this" he says... like everything else.
Does this sound like the same issue described here?
Skyllz is offline   Reply With Quote
Old 08-20-2013, 01:33 AM   #139
ft_sjo
Drives: GT86
No, but it does happen. Try not to slip the clutch during shifts.
Old 08-20-2013, 07:56 AM   #140
regal
Drives: Scion FR-S/Toyota Yaris
Just drive it like grandma in her Subaru and you'll be fine.
2013 FRS Argento Silver 6MT
Mods:
Clear fender side lights
Tactrix ZA1JB01C 2014 Calib
regal is offline   Reply With Quote
Driver's side window seal/door seal KAB-FRS Issues | Warranty | Recalls / TSB 255 01-01-2021 06:09 PM
Injector / seal failure or Miss-fire codes.. please post here mad_sb Engine, Exhaust, Transmission 378 04-24-2020 06:33 PM
Direct Injector Leaking Carwhisperer Issues | Warranty | Recalls / TSB 356 03-13-2020 12:35 PM
Direct Injector Failure Poll track_warrior Issues | Warranty | Recalls / TSB 553 01-12-2017 06:12 PM
Direct Injector's Leaking Carwhisperer Scion FR-S / Toyota 86 GT86 General Forum 1 05-11-2013 09:31 AM
