Old 08-05-2013, 06:43 PM   #15
ZDan
ZDan's Avatar
Drives: '23 BRZ
No track usage, no snow/ice/cold usage, want good grip, for reasonable $$$?
I'd go with the Sumitomo HTRZIII in the stock 215/45-17 size. 225/45s would be ~1/2" taller, that's not going to help you.
$83/each from Tire Rack. Here's their test report of this tire vs. other similar Max performance tires:
http://www.tirerack.com/tires/tests/...y.jsp?ttid=149
Old 08-05-2013, 06:46 PM   #16
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Originally Posted by Gary in NJ View Post
Come on, tires that flat spot over night...on a 2700 pound car...from Dunlop. No. I have not experienced this or any poor performance for average street driving. Of course, my point of reference on this car are the OEM Primacy.
Yes, the weight in a tire is mostly a result of the steel belts and the durometer of the rubber. But what's better for the street; a tire that has a less precise turn-in (a subjective point and only really noticeable during a direct comparison) or a tire that is the MOST precise but at the expense of acceleration and transient response.
Probably the best compromise are the Michelin Pilot Sport PS2 (22 lbs) or the Pirelli P Zero (21 Lbs). without a significant increase in torque (180 lb-ft or more) it's hard to justify a 25-27 lb tire.
My Dunlop Wintersport M3 tires would flatspot while I was at work.
I've driven lightweight Hankook R-S2 and Continental ECDW tires with thin sidewalls and heavier tires like the Yokohama AD08, Bridgestone RE01R, and Dunlop ZII tires with stiffer sidewalls. And I'll tell you this, when it came to choose tires for the BRZ, I got a set of AD08s, and the next set will likely be another set of AD08s or ZIIs. I'm willing to give up a couple lbs for better response and communication.
It's up to the driver. What does the driver prefer? Unless you're trying to eke out a 1/10th of a second for a national title, go for what feels right. And even then, it doesn't matter a whole lot. Just look at the street tire classes at the SCCA Solo Nationals. Some tires will proves very popular but you won't see them on every car.
Old 08-05-2013, 10:15 PM   #17
pche
Guy on internet
Drives: Slowly
I second that. I love mine, recommend them to a friend, he loves them too. We both autocross our cars as well. For the price you really can't beat them, traction is night and day difference, and under 100 bucks per tire, you can't go wrong.
pche is offline   Reply With Quote
Old 08-05-2013, 10:49 PM   #18
Suberman
Drives: Subaru BRZ Sport Tech Satin White
Sumitomo owns the Dunlop trademark. Dunlop tires are made by Sumitomo.
This is why Bridgestone invented theirs: named after the stone bridge over the Le Mans track.
Suberman is offline   Reply With Quote
Old 08-05-2013, 11:03 PM   #19
brillo
Drives: 2013 Firestorm FR-S
At stock power levels no need to go bigger than the stock size 215/45-17 ... Just get a grippy tire like the pilot super sports. You don't want over tire the car and lose the playful feel. weight won't be an issue with 215s. I intend to track and auto-x with PSS in the 215/45-17 size which are already wider than the stoc tires
2013 Firestorm FR-S, MTX, build date 1/13.
brillo is offline   Reply With Quote
The Following User Says Thank You to brillo For This Useful Post:
Mr.Impreza (10-22-2015)
Old 08-05-2013, 11:40 PM   #20
retrosmiths
Drives: Scion FR-S Whiteout
Aren't the stock tires 215/45 R17?
2013 Scion FR-S
retrosmiths is offline   Reply With Quote
Old 08-06-2013, 12:08 AM   #21
RL_BRZ
Drives: BRZ WRB Pearl Limited Manual
Yes...
RL_BRZ is offline   Reply With Quote
Old 08-06-2013, 12:23 AM   #22
retrosmiths
Originally Posted by RL_BRZ View Post
Yes...
Oh, sorry, I got confused by your previous answer:
2013 Scion FR-S
Old 08-06-2013, 12:58 AM   #23
Batman
Easy, Tiger.
Batman's Avatar
Drives: Tiguan, S4, SBC 350 Wrangler
While everyone is on the subject, and preferences for an all season tire? with the winter here recently being snow once then sunny for a week, I hate putting purely-for-snow tires on for the whole winter, but i still love some good grip when cornering at high speed (in mexico or closed track, of course lol)
Two V8s, one turbo, 12 Wheels total.
Batman is offline   Reply With Quote
Old 08-06-2013, 01:03 AM   #24
gabeg86
gabeg86's Avatar
Drives: 2013 Raven FR-S
tread widths vary greatly from tire to tire even if they're classified as being the same size. look at the specs on tirerack and look at the tread widths of same sized tires. guaranteed none of them will be the same. he's just saying the PSS have a larger tread width than the Primacy's, even under the same size
Perrin (LWCP) - Blox (shift knob) - HID Powerhouse (LED's and HID's) - Eibach (sportlines) - Muteki (lugs) - SPL (LCA's) - Rays Engineering (57dr's) - Dunlop Direzza ZII (tires) - Greddy (Evo3) - Full Race (turbo kit) - Ecutek (tuned)
gabeg86 is offline   Reply With Quote
The Following User Says Thank You to gabeg86 For This Useful Post:
retrosmiths (08-06-2013)
Old 08-06-2013, 02:09 AM   #25
retrosmiths
Oooh, ok, I didn't know about that, thanks!
2013 Scion FR-S
Old 08-06-2013, 08:46 AM   #26
brillo
correct, its not a huge difference but they are slightly wider inspite of being the same "size".
I would do a google search for road and track FR-S tire swap, they did a neat article tring out difference tire and wheel sizes and showed the effects on the cars performance and handling. Bottom line, the stock size with better rubber was the best choice.
Old 08-06-2013, 06:46 PM   #27
gabeg86
gabeg86's Avatar
no prob
Old 08-06-2013, 08:05 PM   #28
Firesnake
Firesnake's Avatar
Drives: Whiteout
Personally, I wanted a good daily driver tire that I would occasionally AutoX and have spirited Sunday drives. I ended up with the Pilot Super Sport. So far it's been AMAZING! I thought I experienced the improvement when I first threw them on. But after "breaking them in", the car [i]feels[i] like there's so much more feedback! PLUS, the tires are quiet, and I mean quiet! for being stickier tires. The only gripes that Ive heard of is the treadwear and price/tire. So far, for me, worth every penny.
Firesnake is offline   Reply With Quote
The Following 2 Users Say Thank You to Firesnake For This Useful Post:
retrosmiths (08-07-2013), SuperDave (05-25-2016)
Another Stock Wheels+Tires FS ($500) 636 Wheels and Tires 0 05-09-2013 11:30 AM
FS: Stock Wheels and Tires - DFW boombacloud Wheels and Tires 1 05-04-2013 11:42 AM
FS: Stock Wheels+Stock Tires+TPMS sensor Pin Flare Wheels and Tires 1 03-26-2013 11:07 AM
FS: STOCK FRS WHEELS AND TIRES stevieb0y Wheels and Tires 4 03-11-2013 08:29 PM
17” OZ Alleggerita wheels with stock 215/45-17 tires… 17x7.5 or 17x8 wheels? SteveH Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 02-14-2013 10:26 PM
