View Poll Results: Do you have chirping (cricket) noise during idle once the car is warmed up?
Yes (Please only vote after you have 300 miles or more on the odometer) 3,101 85.22%
No (Please only vote after you have 300 miles or more on the odometer) 538 14.78%
Voters: 3639. You may not vote on this poll
Old 08-04-2013, 07:07 PM   #2507
R3d
Drives: White FR-S
Originally Posted by DylanFRS View Post
They are putting a lot of energy in, mostly from the Sun.
I don't know man, but the original report like this I read was from a company called blue fuels (witch I cant find anymore lol) and it was in french. But they were basically saying that to eliminate the need to use high energy sources to make the fuel, they instead connected the water tanks to the exhaust of a cement factory to ``boost`` the photosynthesis effect, this way it would cost very little energy and take very little time to make both fossil fuels and omega 3. Another by product of this was that it ``cleaned`` the exhaust fumes at the same time.
I don't know how good it is or isn't!
But just the tough of having locally made fuel, that anyone can make (witch means competition, witch means competitive pricing and less traveling to get to the pump) sounds like a plan that's both good for the consumer and the environment!
R3d is offline   Reply With Quote
Old 08-04-2013, 08:36 PM   #2508
BRZnut
Drives: BRZ DGM Limited
Originally Posted by mike the snake View Post
On my old BMW 135i, they had a bunch of HPFP failures which were replaced under warranty.
Somewhere, reading about that, I read about someone recommending to add a capfull of synthetic 2-stroke oil into every tankfull of gas.
I wonder if doing this might lube up the pump on our cars and cure the chirping crickets?
might be worth a try, it certainly won't hurt anything.
I think it's Blendzall that is a castor based octane booster that might kill 2 birds with one stone.
I've been reading about the benefits of adding 2-stroke oil for some time now. I've read that adding 1 oz/5 gallons of gas can quiet an engine and improve starts but it has to be TC-W3 oil. Wonder if it can cure the crickets.
Old 08-05-2013, 11:54 AM   #2509
EK_Golfer
EK_Golfer's Avatar
Drives: 2013 Whiteout FR-S AT
Originally Posted by im2lazy789 View Post
Contacted SOA about getting the chirping, stating I did not have the intention of getting the fuel pump replaced until there was a final fix for it. They instructed me to bring it into the dealership to make sure nothing else was going on. Dealer tech recommended a HPFP change as he has done 5 of them and has not had anyone come back with the chirping problem. New fuel pump ordered, we'll see what happens. I'm only going to go for the replacement process once.
I also did the same, I reported the chirping with my dealership and told them I did NOT want a replacement pump right now citing other owners having the chirp come back. However, the master technician insisted all the pumps they've replaced have not had chirping come back thus far, and that they had a pump in stock and wanted to replace for me. Oh well, might as well give it a shot.
**Update**
Replacement fuel pump installed- went the rest of today driving about 50 miles and no crickets. Will keep posted
EK_Golfer is offline   Reply With Quote
Old 08-05-2013, 03:36 PM   #2510
cantholdanymore
cantholdanymore's Avatar
Drives: FR-S Very Hot Lava
Any 10 series chirping yet?
cantholdanymore is offline   Reply With Quote
Old 08-05-2013, 03:45 PM   #2511
thill
Yes. Several. Why wouldn't there be? These cars all have the same HPFP, there is no magic pump out there.
Old 08-05-2013, 04:17 PM   #2512
cantholdanymore
Just hoping for good news
Old 08-05-2013, 04:37 PM   #2513
EK_Golfer
EK_Golfer's Avatar
Originally Posted by vteclol View Post
Which dealership is this?
Puente Hills Toyota/Scion
City of Industry, CA
Old 08-05-2013, 04:38 PM   #2514
thill
Honestly, the crickets I get are not too bad 90% of the time. Even if I have the car running in my garage with the radio off and windows down.
Gives the car character.
The Following User Says Thank You to thill For This Useful Post:
Scionshaun (08-06-2013)
Old 08-05-2013, 04:47 PM   #2515
cantholdanymore
These last couple Of days temp is about 10f below average and chirps are gone
Old 08-05-2013, 08:40 PM   #2516
Terrapin77
Terrapin77's Avatar
Drives: 2013 Argento FR-S
My experiment with the Lucas Oil Ethanol Fuel Conditioner was unsuccessful. The crickets were gone for 3 days. Now they're back. Even though it does seem that the crickets are little quieter, it's not quiet enough to justify buying another bottle.
Sent from my XT912 using Tapatalk 2
Terrapin77 is offline   Reply With Quote
Old 08-05-2013, 08:42 PM   #2517
Auzburner
Drives: BRZ Limited WR Blue Pearl 6MT
I noticed the same thing today. Granted I didn't drive a whole lot, but the same drive home from work on a hot day results in the chirp.
Auzburner is offline   Reply With Quote
Old 08-05-2013, 09:55 PM   #2518
evera
New BRZ, 50 miles (less than a week old!) chirping.
evera is offline   Reply With Quote
Old 08-05-2013, 10:36 PM   #2519
Lizai
Lizai's Avatar
began to have this problem last Tuesday. Went to dealer today and they are gonna replace the fuel pump and also update ECU. Hope for good
Lizai is offline   Reply With Quote
Old 08-06-2013, 01:29 PM   #2520
Burninator
Trogdor ftw
Burninator's Avatar
Drives: Asphalt FR-S M/T
Originally Posted by EK_Golfer View Post
**Update**
Had mine replaced with one of the "new" ones last Thursday as well. After using up the last half tank of no ethanol gas, I filled up with 93 oct Shell VPower (which caused bad chirping before) 75-100 miles or so and no chirps yet. I guess only time will tell at this point.
Just checked the service invoice again, and besides the fuel pump replacement parts and service list there was a no charge "Miscellaneous Fuel System - Repair" line item as well. Not sure what it was for . Didn't have time to check as I got a call while I was picking up the car about an issue I had to go back to work and deal with. Will have to ask them next time I go in for an oil change.
"Hell hath no fury like a driver stuck behind a Toyota Prius."
Burninator is offline   Reply With Quote
Is this idle noise normal? robo_robb Engine, Exhaust, Transmission 288 01-25-2022 09:40 AM
Squeak noise from engine. Fish Scion FR-S / Toyota 86 GT86 General Forum 52 05-08-2014 01:06 PM
Video of chirping at idle Julio86 Engine, Exhaust, Transmission 15 02-01-2013 10:37 AM
Starting to get worried - Engine noise Laika BRZ First-Gen (2012+) — General Topics 49 07-02-2012 03:45 PM
Idle issue poll/role call Hawaiian Scion FR-S / Toyota 86 GT86 General Forum 8 06-13-2012 12:00 PM
