Old 07-30-2013, 10:50 AM   #211
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Originally Posted by Marrk View Post
Which Japanese guy got the Efficiency Award of the Month for this brilliant idea?
The holes are used as tie-downs in shipping I believe.
The Following User Says Thank You to Draco-REX For This Useful Post:
Marrk (07-30-2013)
Old 07-30-2013, 11:01 AM   #212
jamesm
i checked for mine the day i picked up the car (thanks forum!). luckily they were installed. if i discovered the weren't after a while of driving, and i lived up north, i'd be asking the dealer to inspect it for any rust and fix/replace it. thankfully we don't have rust in florida anyway
Old 08-05-2013, 02:18 PM   #213
oldpueblo
oldpueblo's Avatar
Drives: Scion FR-S 10 #853
So I ordered the underside plugs and they went in fine, I didn't even get down on the ground just felt underneath and mashed them in. However the plugs that go over the struts didn't fit, they seem far too big in terms of diameter. I ordered the part number from earlier in the thread, so FYI I guess.
PLUG D40
SU003-03038
oldpueblo is offline   Reply With Quote
The Following User Says Thank You to oldpueblo For This Useful Post:
Marrk (08-05-2013)
Old 08-05-2013, 02:45 PM   #214
Marrk
Drives: Honda Fit
PLUG D40
SU003-03038
Pics, by chance . . . ?
Marrk is offline   Reply With Quote
Old 08-05-2013, 03:05 PM   #215
oldpueblo
oldpueblo's Avatar
My bad, here you go.
Product placement!
You can see it has this lip all around it.
And the money shot, if someone knows how to shoehorn that on I'm all ears.
Marrk (08-05-2013)
Old 08-05-2013, 03:14 PM   #216
Admiral Ballsy
Shorter of breath
Admiral Ballsy's Avatar
Drives: a soft bargain
Those look like the plugs the BRZ Limiteds use for the spoiler bolt access holes (trunk lid underside).
EDIT - I looked at my car, the spoiler plugs are a lot smaller than the holes for the shock mounting. Having said that, I don't see any way to get water into the trunk from those holes. The top shock flange appears to be watertight (shining a 100W shop light by the top of the spring resulted in no visible light when viewed through the hole), and even if not - the shock is not in the path of tire spray, AND you'd have to fill the channel in the bodywork before any spilled into the trunk.
Looking at all the part numbers referenced in this thread...I'm 99.9%, nope, 100% sure there are no plugs intended for installation above the rear shocks. The plugs in the diagrams referenced are below the foam inserts for the jack assembly.
Admiral Ballsy is offline   Reply With Quote
Old 08-05-2013, 03:35 PM   #217
Draco-REX
Corner Junkie
Draco-REX's Avatar
They still might fit. Try some silicone spray.
Old 08-05-2013, 03:41 PM   #218
oldpueblo
oldpueblo's Avatar
If it looks like they're unnecessary then I won't worry about it. I was more concerned about the underside plugs anyway.
Old 08-05-2013, 03:52 PM   #219
Admiral Ballsy
Shorter of breath
These are what you have:
Old 12-19-2013, 10:21 PM   #220
Frost
CASC-OR T.A. Director
Frost's Avatar
Drives: '13 Prius, '22 BRZ
So now that we're almost into 2014, has anyone actually gotten a vehicle WITH the strut tower cover?
Want the best quality track times for new personal bests? Come on out to Ontario Time Attack!!!
OTA LIVE TIMING LINK
Frost is offline   Reply With Quote
The Following User Says Thank You to Frost For This Useful Post:
Marrk (12-20-2013)
Old 05-04-2014, 05:13 PM   #221
Mikepage
Mikepage's Avatar
Drives: Scion FR-S 2013 Raven
Potential design flaw with factory rear suspension? (WATER in boot area)
Bump for new owners!
o= FR-S =o
Mikepage is offline   Reply With Quote
Old 06-13-2014, 12:23 AM   #222
Jarent
Drives:
Let's assume someone may have popped a plug into the frame all the way and can't feel where exactly it went. How would that someone go about retrieving the plug?
Sent from my SM-P600 using Tapatalk
Jarent is offline   Reply With Quote
Old 06-15-2014, 12:21 AM   #223
Mikepage
Mikepage's Avatar
Lol! Don't worry, Just get a new plug
o= FR-S =o
Old 06-15-2014, 12:23 AM   #224
Jarent
Drives:
Kinda what I figured. I can't here a rattle, and a flexible rubber plug won't damage anything. Ah well.
The Following User Says Thank You to Jarent For This Useful Post:
Mikepage (06-15-2014)
Basic tech info: spring rates, rear suspension, motion ratios, and you. Racecomp Engineering Suspension | Chassis | Brakes -- Sponsored by 949 Racing 77 07-08-2022 03:56 PM
water temp driver01 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 30 04-11-2013 03:57 AM
Impressive boot space! BD AUSTRALIA 14 08-24-2012 05:30 AM
Fatal FRS Flaw!! Skin Scion FR-S / Toyota 86 GT86 General Forum 4 07-12-2012 05:21 PM
Pics of rear passenger area with plastic removed JRitt Cosmetic Modification (Interior/Exterior/Lighting) 20 06-12-2012 09:17 AM
