#15 | |
#16 |
2 Cats, one primary and one secondary. The primary cat is important its connected to O2 sensors before and after it, the secondary can easily be removed without a CEL (hence a catless headerback exhaust can gain 10-20 hp), because that catalytic converter (secondary) is not connected to the car electronically in any way. The reason some people want catted headers is that they don't want to go full catless for whatever reason so they can run catless headerback.
| The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post: | Nevermore (07-21-2013) |
#17 |
Drives: 2013 black AT, OFT, 4.65
Here is one way around all that. Get a PO box and register to car in Bishop or Maraposa CA. No smog in ether of those places.
#18 |
Drives: toyota solara sle
What do you mean we will drink to my horsepower loss
#19 |
Valley 86 SoCal !
Drives: whiteout frs
Headers will not pass smog in California, a cat back exhaust will. They will pass the visual test but not the actual smog test. Anything from the cat up will cause you problems with cel, smog test, and pigs.
#20 |
Drives: Scion FR-S
They don't use the sniffer on newer cars in CA--OBDII and visual only. You will fail the visual in CA as others have said.
From what I'm hearing, even a tune will potentially cause you to fail in a few years. Supposedly various voltages will be compared to a specified OEM range. |
#21 |
Drives: DGM BRZ, MR-S 3.5L V6 swap (sold)
Mod the heatshields to fit the header, do what it takes to have complete monitors and no CEL, and bring the car in warm.
#22 |
Drives: 2013 BRZ limited
So if the O2 sensors are in front and behind the primary cat in the exhaust manifold, can you ditch the secondary cat in the front pipe and still pass the OBD-II smog test?
I understand newer vehicles are not getting the sniffer test and are OBD-II only, so even though you can't get a header in CA and still pass smog, you may still be able to get a catless front pipe and pick up 5-7hp. |
#23 | |
Drives: UltraMarine 6 Spd MT
I didn't want to mess with CEL and future issues with any smog tests here in WA or where I live (never in the Socialist Republic of CA.)!!!!!!!
I am going FA20Club w/CAT. I dropped the 2nd CAT on my Invidia front pipe, but for noise control added a resonator in the hope it would drop a few db. Quote:
'13 Ultra Marine 6MT:AVO Stg 1.5 T, Berk Tech Cat'd FP, Perrin OP & 2.5" cat back, WinMax W3F/W2R, 18x8.5et44 Rota, 245/35R18's, Drift-Office EcuTek Tune, Cusco Strt Twr & Rear brace and Grimspeed hood struts.
#24 | |
#25 | |
A 2.5" catted front pipe will probably make about 1hp less than a 2.5" catless front pipe, plus the catless pipe will be raspier and louder. It might not be noticeable with the stock header, but if you go aftermarket you'll hear it for sure.
#26 | |
Drives: '13 dgm brz
And if both cats are swapped for high flow, will the sniffer be satisfied? I only swapped one cat for a Cobb high flow on my WRX and failed miserably. Pissed me off. |
#27 | |
I only said EL headers because those are the only headers so far I have found that have a cat, I don't think the EGT temps would have a difference because they all collect at one point so. I do believe with a tune and two cats being swapped the sniffer will be o.k. but only in the case of the FA20.
#28 | |
Drives: '13 dgm brz
Oic. FA20club came out with a UEL catted set not too long ago.
| Will the borla headers pass emmision test? | Frsexxxy | Engine, Exhaust, Transmission | 3 | 03-24-2013 09:39 AM |
| Truck hanging on 217/Denny rd over pass | Fascist Fish | Northwest | 5 | 11-25-2012 02:49 PM |
| 2x MotoGP Gardner Straight Tickets (3 Day Pass) | sax086 | Australia Classifieds | 0 | 10-11-2012 02:01 AM |
| SMOG Issues | SkullWorks | Engine, Exhaust, Transmission | 8 | 10-04-2012 01:23 PM |
| Question about smog checks/emissions | showbe | Scion FR-S / Toyota 86 GT86 General Forum | 3 | 09-28-2012 12:03 AM |
