Old 08-04-2013, 11:09 PM   #1
Figo
Figo's Avatar
Drives: Vortech Supercharged FR-S
Smile Question: TPMS Tire-pressure monitoring system installed on aftermarket wheels
Hey everyone, I order a set of Rota Grids rims and 4 new tires.
Here is my setting:
18X8.5 225/40r18 front
18X9.5 245/40r18 Rear
I was wondering that whether I will be able to install the TPMS sensor from my OEM wheels on those Rota Grids wheels?
BTW, anyone knows whether Rota Grids rims comes with value? Can I install them on my OEM wheels?
Since I am gonna sell those OEM wheels, I think installing OEM senors on new wheels will be the best solution. But the only problem is whether they are going to fit or not.
Thank you!
I'd rather lose by a mile because I built my own car,
than win by an inch because someone else built it for me.
Your car is your story, so don't let someone else write the book.
( White Tiger ) - FiGo's 車誌.
Figo is offline   Reply With Quote
Old 08-05-2013, 12:57 AM   #2
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
YES they will work in your rotas zero issues at all. I run stock tpms sensors in my staggered RT5 rota set.
Old 08-05-2013, 03:42 AM   #3
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
TPMS is usually only a problem on multi-piece wheels using an angled valve stem, or a valve stem that goes through the barrel into one of the holes in the center disk of the wheel.
Either an adapter is used, or the wheel is drilled to accommodate the TPMS sensor.
-alex
Old 08-05-2013, 04:20 AM   #4
KONVERTER
KONVERTER's Avatar
(or strap the spacer to the inside of the wheel with a large band / tie strap)
KONVERTER is offline   Reply With Quote
Old 08-05-2013, 08:16 AM   #5
Figo
Figo's Avatar
Thanks hah. Now I am sure that they are going to fit on my Rota Grids rims. Actually I have to wait foe 6-8 weeks because the 18X9.5 Flat Black is out of stock now.
Old 08-05-2013, 08:19 AM   #6
Figo
Figo's Avatar
lol. It is my first time to change wheels. So I just have no idea what I am gonna do to those TPMS. Thanks.
-alex
Old 08-05-2013, 11:48 AM   #7
mav1178
mav1178's Avatar
For what it looks like and how it's mounted:
https://www.google.com/search?q=tpms...KIHoiwL3hIDYCg
-alex
Old 08-05-2013, 12:54 PM   #8
Figo
Figo's Avatar
Got it, just the value stems. Thanks man.
-alex
Tyre Pressure Monitoring Systems Fish Eagle AFRICA 3 07-14-2013 04:52 PM
Recommended Tire Pressure for Aftermarket Wheels and Tires Chri5 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 05-15-2013 01:28 PM
New Tire Pressure Monitoring Sensors? Kochinopride Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 11 04-14-2013 08:51 PM
new rim/tire. question about bolts pressure? and etc WATCHMEHEAL Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 03-25-2013 05:59 PM
WTB: Tire Pressure Monitoring Sensors (TPMS) RYU Wheels and Tires 6 09-18-2012 12:52 PM
