Old 08-05-2013, 05:10 AM   #29
JordanWho
JordanWho's Avatar
Drives: Ford Focus RS & Toyota 86 GTS
Originally Posted by Lanbaldo3 View Post
damn reading all these makes me worried.
I have BC br coils too and I've been sliding my car also. Im afraid when i do word up drift, i'd be stuck there... my car is maxed out on lowered height but i was gonna take off the lock rings to give me an extra inch or so, once im done drifting it and buy a track car, but now im afraid to even slide it...
im broke and don't wanna spend so much on fixing a new car.
I'm pretty sure we're gonna get alot of hate replies from the forum member for lowering our cars but to each their own. I love flush cars and seeing them drift.
They're definitely breaking so I'd be careful with it at that height especially if you're drifting. I was drifting mine a lot and yeah, mine was pretty low. Check my build thread.
I know we will get haters and probably a lot of them. I love stanced cars and it's all personal tastes of how you like the car to look aesthetically. People should respect everyone's personal preferences and simply offer advice if they feel they can offer something positive.
JordanWho is offline   Reply With Quote
Old 08-05-2013, 05:18 AM   #30
KONVERTER
KONVERTER's Avatar
I love the look to...
But unfortunately it seems on this sorry to say "cheap" car they cut corners somewhere. This may be why it comes with such gripless tires to keep this from happening
Sent from my Nexus 4 using Tapatalk 4
KONVERTER is offline   Reply With Quote
Old 08-05-2013, 05:47 AM   #31
tisb0b
Drives: Grey GT86 MT
It's not cutting corners, they just didn't design the components to withstand the car being dropped to 1" from the ground and driven hard.
tisb0b is offline   Reply With Quote
Old 08-05-2013, 05:49 AM   #32
KONVERTER
KONVERTER's Avatar
You are not extending the travel of the suspension. I doubt that is it.
Driving hard is the sad part... A sport car made for being parked haha
Old 08-05-2013, 06:59 AM   #33
JordanWho
JordanWho's Avatar
This.
Old 08-05-2013, 02:43 PM   #34
KONVERTER
KONVERTER's Avatar
I was thinking ... Are the drivetrain shop parts just upgraded axles or did they replace the ends that bolt up to the half shafts?
Old 08-05-2013, 04:44 PM   #35
Mach V Dan
FT86Club Official Vendor
Drives: 2013 BRZ, 2015 WRX, 2000 RSTi
That is a lot of wheel / tire weight. more than 10% more wheel weight, plus most likely tires that weight more than stock and even grippier... I wouldn't blame this on being lowered...
A couple of pounds of additional wheel/tire weight will not break your axles. The combination of hard use (drifting) and extreme axle angle might.
--Dan
Mach V
Mach V Dan is offline   Reply With Quote
Old 08-05-2013, 04:45 PM   #36
wparsons
wparsons's Avatar
Actually, it is extending the travel... the stock shocks only have about 2.5" of bump travel from stock resting height, all the coilovers that claim they can go super low have much shorter starting lengths and let the suspension travel way further upwards than it could ever possibly go with stock shocks.
flickr
Old 08-05-2013, 05:20 PM   #37
2superblus
2superblus's Avatar
Drives: 13 BRZ WRB
What is the ride height measure from the pinch weld jacking points to the ground?
2superblus is offline   Reply With Quote
Old 08-05-2013, 09:00 PM   #38
Lanbaldo3
Divine Wind - Dori
Lanbaldo3's Avatar
Drives: RWD
im pretty sure this car was meant to be driven hard, looking at the past predecessor and knowing that it'll be used for drifting also, is a big hint that these cars are meant for track and drifting. I mean 1990 cars today are still holding up to so much abuse, why shouldn't this?
I just wish all the 86 drifters come together and see how many axles they've replace after drifting or if they haven't at all. I'm not talking bout 1 little corner drifting in streets, i mean actual drifting holding a drift through a whole course and clutch kicking the shit out of it.
ill still drift my car and lower it some more (call me stupid i dont care. to each their own). i just wish this is just parts that failed due to assembly or something like a random failure or hitting something. iono.
1990 FC3S T2swapped! "Savannah"
1992 240sx Type X "Nadia"
2013 Scion FRS "Raven"
Drift Specials.....
Lanbaldo3 is offline   Reply With Quote
Old 08-06-2013, 07:44 PM   #39
JordanWho
JordanWho's Avatar
Will measure and get back to you.
Old 08-06-2013, 07:56 PM   #40
JordanWho
JordanWho's Avatar
Not really that impressed with my driveshaft shop axles at this point.
They're still leaking grease after raising the car 20mm to which both my tuner and I thought should fix the issue.
Must be an issue with these axles specifically. I'm not getting a lot of help from the DSS either.
Here's a few pics of them leaking grease just from driving home from work...
Old 08-06-2013, 11:16 PM   #41
Fallen51
Drives: 2013 Scion FRS
Ive destroyed both axles on my car after 6 months of drifting here and there.. Im lowered on stance coilovers pretty low... so add my 2 to the list of shit axles
Fallen51 is offline   Reply With Quote
Old 08-06-2013, 11:21 PM   #42
JordanWho
JordanWho's Avatar
What type of axles have you been replacing the broken axles with? Factory or upgraded?
HVT BRZ/FRS Non-raising Camber Plate Turn in Concepts Brakes, Suspension, Chassis 25 08-18-2013 03:57 PM
should i upgrade axles? Frs300 Engine, Exhaust, Transmission 16 07-01-2013 11:00 PM
Lowering/raising driver's seat? Dreamshot Scion FR-S / Toyota 86 GT86 General Forum 16 06-07-2013 04:59 AM
Anyone lowering their BRZ with coilovers and raising the BRZ for winter? ngabdala Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 08-29-2012 06:37 PM
