Old 08-04-2013, 01:26 AM   #1
WRBRZ
Drives: '92 30R Talon, '13 BRZ
Hesitation/Cutting out in 5th and 6th gear
Hey guys,
Today I noticed something new with my BRZ. I have a Visconti Stage 1 tune and an SRT headerback for power mods. I was part throttle in 6th, and felt the car hesitate as if it was retarding timing. Not sure why it did it. I was able to replicate it again in 5th at WOT and 6th at WOT at two different RPM points. It seems to happen at either 4 or 5k rpm. WTH! First the transmissions starts grinding, now this!
Could this be an early sign of an AVCS issue? The car did it in hot and cooler temps. It did it twice, at 4k and 6k in 6th gear, I hit it at around 3k in 6th and took it up as far as I could.
Any suggestions?
WR '13 BRZ Premium 6MT - Visconti Stage 1 Tune, SRT Headerback, FX350
'92 Talon - FP3052, 503awhp, Mustang dyno
WRBRZ is offline   Reply With Quote
Old 08-04-2013, 01:30 AM   #2
xjohnx
Grip>Slip
xjohnx's Avatar
Originally Posted by WRBRZ View Post
Hey guys,
Today I noticed something new with my BRZ. I have a Visconti Stage 1 tune and an SRT headerback for power mods. I was part throttle in 6th, and felt the car hesitate as if it was pulling timing. Not sure why it did it. I was able to replicate it again in 5th at WOT and 6th at WOT at two different RPM points. It seems to happen at either 4 or 5k rpm. WTH! First the transmissions starts grinding, now this!
Any suggestions?
Datalog, open ticket.
WRBRZ (08-04-2013)
Old 08-04-2013, 12:08 PM   #3
WRBRZ
Yeah, I'll have to do that today. Leaves me a bit unsettled. Car hasn't had this issue before. Did it after a little bit of spirited driving, but nothing out of the ordinary. Tank was over 3/4, and I wasn't going around any corners either.
Old 08-04-2013, 10:42 PM   #4
WRBRZ
Does anyone have any idea how I can post my logs? I can't seem to attach them using the attachment tool on the control panel.
Managed to replicate the issue while data logging.
Old 08-05-2013, 12:23 AM   #5
Apoc
Apoc's Avatar
Drives: Raven FR-S 6M
I don't think you can upload csv files here. You should be able to load into Zendesk (Visconti's support console). I have a similar issue with hesitation and have nearly the same mods (header back and stg 1 tune). I have not been able to replicate the issue while logging. I am curious what the cause could be.
“The World is Flat”
[||•]=(86)=[•||]
Apoc is offline   Reply With Quote
Old 08-05-2013, 01:21 AM   #6
WRBRZ
Well, after spending some time looking at the logs. Here's what I came up with. I could be completely wrong, but it's my best guess thus far.
6th gear pull. Looks like something's up with the VVT:
Zoomed in:
5th gear pull, same thing. Has to be a pattern. AVCS problems on the horizon? Who knows...
Thoughts?
Cutting open tail lights with a Solder iron! JollyJON DIY (Do-It-Yourself) Guides 68 11-18-2016 05:11 PM
Engine cutting power after hard cornering... CSG Mike Tracking / Autocross / HPDE / Drifting 19 07-04-2015 09:40 AM
HU/Amplifier cutting off low/mid frequencies? 6-Shift Electronics | Audio | NAV | Infotainment 13 03-17-2013 11:01 PM
Waterjet metal cutting? DarrenDriven Northwest 18 09-14-2012 11:13 PM
To those with the auto -any throttle lag or hesitation at low speed? ahausheer Engine, Exhaust, Transmission 22 07-25-2012 06:21 PM
