Old 08-04-2013, 08:38 PM   #1037
GreenPants
Drives: Burnt Orange GT86
Yep, that's pretty much what I was going to say in a PM...
  • mkdir ~/system_img
  • sudo mount -t ext4 -o loop system.img system_img/
  • cd ~/system_img
  • <tweak the files as you see fit>
  • sudo umount ~/system_img
  • <copy/use modified system.img>
I prefer the use of sudo over su as it only raises you to root for the duration of the command, rather than for the duration of the shell.
You need to be root when you modify files (e.g. sudo cp ...), not just to have the right permissions, but also to make sure that the root user becomes the owner of the files. Not all files have this requirement, so there are some that you may need to chown. You also need to make sure that the attributes are set correctly for the type of file (chmod/chattr)
If you're only interested in examining the system.img file system, then you can use
ext2read on Windows.
If you want to modify the root file system (uramdisk.img), then I have found bootutil.exe to be an easy tool to use on Windows.
GreenPants is offline   Reply With Quote
Old 08-04-2013, 08:56 PM   #1038
GreenPants
Originally Posted by Zaphod-Beeblebrox View Post
Now, on to another issue that some of you may be up against and I'd like some thoughts on: LCD Density.
We installed Copilot on this unit (already purchased from previous devices) and it installed/ran fine, but when you need to sign in to your ALK Live account, the button for 'sign in' is too low .. you can't reach it. You can only create a new account.
I think lowering the density will cause the screen elements to shrink, and maybe that button will become visible. However, the build.prop doesn't have a density setting.
has anyone tried to set a density? what is the default? Anyone tried LCDDensity for Root from the market?
Haven't tried it. No complaints about this yet, you're the first to find an issue.
A quick google indicates that the default for density (ro.sf.lcd_density) is 96 dpi - however elsewhere it indicates that Android will assume mdpi (160) unless otherwise specified.
Old 08-04-2013, 09:16 PM   #1039
nzer
nzer's Avatar
Drives: 2012 Grey TRD GT86, 2015 VW Golf R
  • cd ~/system_img
LOL - are you guys speaking english???
nzer is offline   Reply With Quote
Old 08-04-2013, 09:49 PM   #1040
GreenPants
That's one of the reasons why I'll be splitting the firmware off into its own thread the next time I do a release.
I don't want to pollute this useful thread with geek or 1337-speak if I can help it.
Old 08-05-2013, 05:20 AM   #1041
Zaphod-Beeblebrox
Drives: Not an FRS - Sorry
We tried to use LCDDensity for Root and it appeared to be working (it reported a default density of 160), but after each reboot, we noticed that it actually wasn't working. Not sure why.
So, we resorted to doing it manually. Used ES Explorer to Mount /system as R/W and put ro.sf.lcd_density=160 in the build.prop and rebooted. We were then able to change the value for density manually to get the effects we wanted.
Interestingly, Co-Pilot reacted backwards to the density changes than expected. Lowering density values should have created smaller objects, thus more room on screen. Setting density to 120 did make the launcher and other items looks smaller, but it made co-pilot look bigger, and we lost even more screen real estate. Setting density to 220 made co-pilot show us the normal screen and we were able to sign in and get co-pilot working.
Technically the density should be 140 (that's what we set it at for now). I get there by dividing the pixels (800) by width (5.75 ") = 140. Vertically it's a little over 150 (480 / 3.125). We may end up changing it back to 160 if it proves problematic for any apps, etc.
Zaphod-Beeblebrox is offline   Reply With Quote
Old 08-05-2013, 06:50 AM   #1042
GreenPants
I played around with a tool from the play store as well - however the radio app no longer filled the screen correctly after a reboot, so didn't look much futher.
Old 08-05-2013, 06:59 AM   #1043
GreenPants
When I get some time I'll document how you can copy your downloaded APKs from the store onto your SD card. This makes reinstalling after firmware upgrade a lot quicker, as you don't need to set up Wi-Fi & Account to get everything back. (The maps, however, may still need to be downloaded)
Summary
APK files (applications) downloaded from the Play store go into /data/app. With root privs you can copy these files to somewhere that doesn't get deleted during a firmware upgrade - for example the MicroSD card. After the firmware upgrade, simply install each one again by clicking on it with ES File Manager
Step-by-step
  • Start ES File Manager
  • Press the 'Up arrow' (top left icon) to get to the top folder (screen doesn't change any more)
  • Press the 'Menu' button
  • Expand 'Tools'
  • Scroll down to Root Explorer
  • Allow SuperSU to grant root permissions to ES File Explorer, but don't actually use the window that pops up (press 'Back' to close)
  • Click on 'data' folder
  • Click on 'app' folder
  • Click on select button (top right)
  • Select apps you want to copy
  • Click on Copy (top right)
  • Click on Up arrow to root folder (display stops changing)
  • Click on the 'sdcard' folder
  • Click on 'extsd' (or 'udisk' if usb)
  • [Optional] create a folder and enter it
  • Click on 'Paste'
After an upgrade you can use ES File Manager to open this folder again and click on each file to install the app.
Old 08-07-2013, 09:53 PM   #1044
dsrttigr
"GOD ARM"
dsrttigr's Avatar
Drives: 2013 Toyota GT-86R E85 Tuned
How do I remove/cancel the radio from starting first by default?
dsrttigr is offline   Reply With Quote
Old 08-07-2013, 11:26 PM   #1045
GreenPants
Hold down the back button for 3 seconds to close the radio app. Thereafter the headunit will boot to the homescreen. (At least until you start the radio app again).
Old 08-08-2013, 12:10 AM   #1046
dsrttigr
"GOD ARM"
dsrttigr's Avatar
Thanks, I will try that tomorrow.
Old 08-09-2013, 08:10 AM   #1047
SpeedLab
Drives: White
Has anyone had any luck getting "Trackmaster" running on one of these head units? I just picked one up.
SpeedLab is offline   Reply With Quote
Old 08-09-2013, 01:49 PM   #1048
nzer
nzer's Avatar
Haven't tried it but with @GreenPants amended root files or the fix he posted RaceChrono works fine. Has lots of tracks around the world. Have a look and see if yours is on it.
Old 08-09-2013, 05:45 PM   #1049
SpeedLab
Drives: White
I'll give that a try. I paid for trackmaster but I'm sure chrono is only a few bucks.
Now this got me thinking... Anyone had success with the go pro app? Would be amazing to start and stop the camera with their remote app.
Sent from my iPad using Tapatalk HD
Because it didn't break does not mean it's track proven.
Old 08-11-2013, 05:19 PM   #1050
Trap63
Trap63's Avatar
Drives: Brz WRB - Europe LHD
Summary
Step-by-step
  • Expand 'Tools'
  • Click on 'Paste'
Hi GreenPants any news about a release with "phone" in "kit car" not blue?
Trap63 is offline   Reply With Quote
Samsung Galaxy Note SGH-I717 - 16GB - Carbon blue (Unlocked & Rooted) JPxM0Dz Canada Classifieds 2 01-19-2013 11:51 PM
chinese man sues wife for being ugly: wins wrxgoose Off-Topic Lounge [WARNING: NO POLITICS] 15 11-07-2012 10:58 AM
Counterfeit Chinese Airbags @Art_Mighty Other Vehicles & General Automotive Discussions 11 11-03-2012 03:20 AM
JDM Vs. KnockOff SIRvive Off-Topic Lounge [WARNING: NO POLITICS] 4 03-05-2012 05:32 PM
Gang of Chinese kick, yell, and drag a little caucasian boy Giccin Off-Topic Lounge [WARNING: NO POLITICS] 34 01-20-2012 10:47 PM
