Old 04-26-2013, 07:25 AM   #211
mad_sb
Drives: 2013 Asphalt FR-S
This car is equipped with a narrow band sensor.. Not wideband
The primary 02 sensor is a denso Planar Type Wide Range Air Fuel Sensor. It does not read as far on the rich side as a true wideband (10:1 to 20:1) but it is more than sufficient range for NA tuning (12.1 - 18).
Old 04-26-2013, 01:05 PM   #212
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
I would call the OEM sensor a narrow wide band sensor, haha. Any chance one of the BRZedit users could make a video of doing things in BRZedit? Like simply showing how you open a ROM change something in the fuel or igntion tables, save the ROM, and flash the ECU.
Old 04-26-2013, 01:25 PM   #213
arghx7
Drives: car
I agree that the OEM front O2 sensor, the limiting-current type Denso A/F sensor, does not have the same range as a Bosch LSU pump-cell type. For applications where you don't need to go super rich (basically, non-boosted) it will still read accurately. Now if the front o2 sensor output the same style signal as the rear o2 sensor (oscillating 0-1v), then you could easily call them both narrowbands.
Use the right tool for the job, that's all.
Old 04-26-2013, 04:54 PM   #214
ft_sjo
Drives: GT86
They're normally referred to as a 'lean burn' sensor, with much more resolution and range on the leaner side of stoich. Similar to the NTK L1H1 type stuff.
Old 05-19-2013, 04:28 AM   #215
Z0rr0
Drives: 2013 Raven 6MT FR-S
Updates?
Z0rr0 is offline   Reply With Quote
Old 05-26-2013, 07:14 PM   #216
Deepseadiver
Drives: 2013 BRZ DMG manual Limited
Originally Posted by Z0rr0 View Post
Updates?
Anything new?
Deepseadiver is offline   Reply With Quote
Old 07-03-2013, 02:04 PM   #217
Sing4LTS
Drives: 13' FR-S
Anything yet on map switching?
Sing4LTS is offline   Reply With Quote
Old 08-03-2013, 01:03 PM   #218
regal
Drives: Scion FR-S/Toyota Yaris
Anyone know if you can you upgrade from lite to personal at a later date for $300?
2013 FRS Argento Silver 6MT
Mods:
Clear fender side lights
Tactrix ZA1JB01C 2014 Calib
regal is offline   Reply With Quote
Old 08-03-2013, 06:46 PM   #219
Sithspawn
Drives: '14 Hot Lava FR-S w/Flappy Paddles
I would imagine so. I asked them if I would be able to upgrade from the personal edition to the pro edition later on for the difference in price and they said yes.
Sithspawn is offline   Reply With Quote
Old 09-13-2013, 04:23 PM   #220
Cross
It's the Mad Cow
Cross's Avatar
Originally Posted by seven View Post
Very interesting in seeing this.
Coming from the LSx land where you can pick up HPTuners suite and a cable for $450ish and tune yourself... ECUTek seems overpriced to me, costs almost $1000 by the time your done and all you can do then is load a tune, meh.
I can't wait to see how open source comes along for this.
You nailed it, EcuTek comes off as a "We are amazing no one can do this!" yet it is nothing more than another tuning option with someone controlling the tunes and not sharing with the community then charging around a 1000 for something that should cost around 450-600 depending on options.
HPTuners is open to Ford, GM and Dodge although mainly popular on GM Vehicles. Both the 450 and 600 kits come with 10 credits and credits cost 49.99 each. It takes 2 credits to tune so you get the ability to tune multiple platforms and cars as well as enough tunes out the door from the start to do 5 cars.
You can find information, base maps hell they have a tune repository so you can learn and the software is available for free so you can have a look before buying the cable and licensing it.
To come from that and see EcuTek it just makes me shake my head and wait for someone like this to come forward and provide a solution not centered on taking advantage of its users in such a manor. It may be great for these vehicles but raping your users over the coals and acting like your tunes are so amazing they are worth over 400-600 dollars?
With HP Tuners I can get a Dyno tune for a fully built vehicle be it N/A, Nitrous, Boosted you name it for 350-450 with the dyno price and that's with one of the best tuners in the country. What the hell makes these other tuners who are sending mail order tunes basically worth so much?! Its flat out just taking advantage of the situation.
Frankly the more I read the more I see this is the solution for those of us who want to tune our own vehicles and share. Because of that this will probably be the direction I choose to go for E85 should I continue to get no answers on the Unichip.
Old 09-17-2013, 01:08 AM   #221
brzEdit
Update: Pricing has been adjusted for Personal $249usd & $175usd for Lite Version. Personal Version now allows direct file sharing between peers.
brzEdit is offline   Reply With Quote
The Following 4 Users Say Thank You to brzEdit For This Useful Post:
illmatic (09-17-2013), jamesm (09-17-2013), King Tut (09-17-2013), Z0rr0 (09-17-2013)
Old 09-17-2013, 10:05 AM   #222
vgi
Drives: frs
are you going to update the web soon - http://brzedit.com/index.php/2013-01-22-04-55-54
vgi is offline   Reply With Quote
Old 09-17-2013, 12:53 PM   #223
Z0rr0
Yes: map axis are scalable in software
Yes: load axis can be scaled to higher levels
MAF senor scaling table is available to help with adding turbocharger or supercharger. MAP sensor scaling not available yet but is in progress.
Was the MAP sensor scaling ever put into place?
Old 09-17-2013, 01:07 PM   #224
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Come up with a cheaper cable than the Tactrix 2.0 and you will really have something to compete with the new kid on the block.
The Following 3 Users Say Thank You to King Tut For This Useful Post:
jamesm (09-17-2013), topazsparrow (09-17-2013), vgi (09-17-2013)
