Old 08-02-2013, 05:24 AM   #1
JDM-dono
JDM-dono's Avatar
Drives: WRB BRZ '13
Unhappy Chatter upon engagement of gears 2,3,4
Problems:
1) Gearbox chatter as I shift from 1 -> 2 (as in the movement of gear knob from 1 to 2 clutch in, I get a chatter sound emanating from the gearbox)
2) Gearbox chatter as I engage gears 2, 3, 4 at approx 3000 - 4000 rpm.
- Problem occurs during upshift & downshift
Relevant info(?)
- 3400 km on odometer
- Jan delivery
- Took it to the Subaru Service Center. They say it's still bedding in and have filed a technical report about the issue.
Has anyone had this problem? If so, how was the problem fixed?
JDM-dono is offline   Reply With Quote
Old 08-02-2013, 06:02 AM   #2
Pscylo
Pscylo's Avatar
Drives: Raven FR-S
There is a TSB for gearbox chatter....i saw it in the TSB section
Pscylo is offline   Reply With Quote
Old 08-02-2013, 06:41 AM   #3
JDM-dono
JDM-dono's Avatar
Drives: WRB BRZ '13
Just checked the TSB/Recall Sticky, no mention of gearbox chatter.
Went to the List of Problems Sticky and found the Sychros thread which seems relevant. There isn't a TSB as such but a change in fluid as some guys here suggest. From what I have read, it's worked for some and not for others.....still a gremlin if you ask me.
This post says it's normal:
http://www.ft86club.com/forums/showp...2&postcount=25
This thread suggests that trans fluid needs to be changes:
http://www.ft86club.com/forums/showthread.php?t=16604
This post states that GL-4 oil can cause reliability issues due to additional additives compared to GL-3 oil:
http://www.ft86club.com/forums/showp...2&postcount=50
This post suggests that the problem goes away after 10k miles:
http://www.ft86club.com/forums/showp...&postcount=156
There is no single solution people agree upon.
The Following User Says Thank You to JDM-dono For This Useful Post:
buddy32 (08-02-2013)
Old 08-02-2013, 10:25 AM   #4
LavosTRD
Toyota Master Tech
Drives: Whiteout MT
The TSB you are looking for is a Toyota TSB
LavosTRD is offline   Reply With Quote
Old 08-02-2013, 11:43 AM   #5
buddy32
Drives: WRB Subaru BRZ Limited
Noticed chatter a lot especially when I'm slowing down to a stop. Usually in free right before I stop completely, and that's when it happens.
buddy32 is offline   Reply With Quote
Old 08-02-2013, 09:09 PM   #6
JDM-dono
JDM-dono's Avatar
Drives: WRB BRZ '13
Stupid question but is the Toyota TSB applicable to the BRZ? I noticed separate TSB for Subaru and Toyota regarding tail light condensation
clutch Engagement Issue? Bu-Tang Issues | Warranty | Recalls / TSB 68 02-19-2017 03:03 PM
Engagement Ring Hix Miscellaneous 7 03-07-2013 03:28 PM
Clutch Chatter & Traction Control? Fortney Issues | Warranty | Recalls / TSB 9 10-24-2012 12:43 AM
Engagement... so expensive. merlin2111 Off-Topic Lounge [WARNING: NO POLITICS] 43 08-02-2012 10:55 PM
Increased media chatter can only mean one thing... sieeegel BRZ First-Gen (2012+) — General Topics 138 03-16-2012 11:19 AM
