Old 04-04-2013, 11:24 PM   #85
chenshuo
chenshuo's Avatar
Drives: WRB BRZ
Originally Posted by Shinryu View Post
As stated in the post you quoted, you need the F-108 for either vehicle.
Originally Posted by Draco-REX View Post
Their list is out of date. You want the valve for late model Subarus, the F-108.
Get the F-108 for just the valve, or the F-108S for a valve with a removable plastic nipple to attach a hose.
I don't see on the Fumoto Valva Canada site that has the "S" model. How can they get the size so wrong... i mean F-105 and F-108 is quite a big difference.
chenshuo is offline   Reply With Quote
Old 04-05-2013, 09:04 AM   #86
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Check some of the other vendors for the S.
If you look at the list, it doesn't actually list the BRZ or FR-S. Instead those sizes are listed under Other Vehicles.
Old 04-05-2013, 09:49 AM   #87
chenshuo
chenshuo's Avatar
Drives: WRB BRZ
Ok thanks. One last question about the valve: Where is the cheapest place to order one? I went on the qwikvalve.com website and the total price + shipping to Canada is about $50.
Old 04-05-2013, 02:36 PM   #88
mjs
Drives: BRZ Limited Auto Black
Amazon is $26 USD right now with 13 left in stock
mjs is offline   Reply With Quote
Old 04-09-2013, 06:09 PM   #89
Mac1235
Mac1235's Avatar
Maybe this has been answered. But what oil are you using? What brand? Also if you go to a subbie dealership and ask for it you can get the OEM factory oil filter, the black one.
Mac1235 is offline   Reply With Quote
Old 04-11-2013, 04:00 PM   #90
RallySport Direct
RallySport Direct's Avatar
Drives: 2014 Widebody Cosworth FR-S
We are using conventional Penzoil right now, next oil change we will go with a high quality synthetic oil And good info on the filters, thanks!
Rick
RallySport Direct is offline   Reply With Quote
Old 04-12-2013, 11:49 AM   #91
xjohnx
Grip>Slip
xjohnx's Avatar
Rick
Conventional? what weight? I was under the impression that 0W20 was only available in synthetic?
Old 04-12-2013, 01:29 PM   #92
RallySport Direct
That is correct, we used a 5W20. Still trying to decide what route to go for the next oil change, but it will be a high quality oil for sure. We will keep everyone updated!
Thanks,
Rick
Old 08-02-2013, 06:34 PM   #93
lp87
Drives: 2013 swp brz
So is it necessary to change the oil every 3000 miles? I just bought the necessary amount of motul synthetic 0w20 and it was like 90 bucks for just the oil and filter. Also have any of you only put 5 liters in it? Just put the 5 liter jug in and its near the full mark on the dipstick. Weird because the manual says 5.8 liters.
I know this was discussed earlier but could it be a whole .8 liter discrepancy?
lp87 is offline   Reply With Quote
Old 08-02-2013, 07:02 PM   #94
RallySport Direct
That depends on how you drive the car, and also your personal preference. I personally like to change my synthetic oil between 3 and 5K, but some people will say it is a waste to change it that frequently. To really know what is okay and not okay, you would want to send your used oil in for analysis and they can let you know if you are changing it too early. I am no oil expert, so take this with a grain of salt lol.
In regards to the volume of oil, it is possible there was residual oil in the system which could make up the .8 liters. As long as you check your oil on a flat surface and it reads at the full mark on the dip stick, you should be fine
Thanks,
Rick
Old 08-02-2013, 07:04 PM   #95
chanomatik
Snow Don't Hurt!
chanomatik's Avatar
My car eats up the entire 6 liters of oil. I must drive hard.
Old 08-02-2013, 07:11 PM   #96
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Keep in mind the 5.8L spec includes the oil filter, assuming it is holding oil.
-alex
RallySport Direct (08-06-2013)
Old 08-28-2013, 01:28 PM   #97
Sevs753
Sevs753's Avatar
Drives: BRZ, Canyon
Not sure if this is the right place but I seem to have oil leaking from the drain plug after my first and second oil changes. The first change, I used a new crush washer and insured that the old washer was off the plug. The second time, I replaced the plug with a fumoto valve.
When tightening the valve/plug down, I didn't use my torque wrench but i tightened it to the point where I thought i would strip the drain if I continued. When I went to change my oil for the second time, I noticed oil on and around the drain plug before draining the oil. I checked the other day and I still appear to be leaking oil from around the fumoto valve.
Did I miss a step somewhere? Am i just not tightening the plug enough? Could it be something else?
Sevs753 is offline   Reply With Quote
Old 08-28-2013, 01:39 PM   #98
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
you didnt miss any step.
1. either washer is defective or worn.
2. you might striped thread of oil pan plug.
i used to use torque wrench on tightening the plug but not on oil pan bolt anymore. i just put enough torque with hands. they won't come off.
recheck washer and replace it again for next change. I would put old oil plug bolt back with washer then see if there is leak. if not, then might be fumoto valve thread is damaged or washer doesn't fit well with fumoto valve
Oil Change Questions #87 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 31 06-28-2012 11:06 PM
Color Change Dark_Angle Mid-Atlantic 10 05-30-2012 02:00 PM
Do you change your own oil? If so, why? SteelReign Other Vehicles & General Automotive Discussions 76 04-15-2012 04:44 AM
I was able to change my pre-order. nkrein22 BRZ First-Gen (2012+) — General Topics 23 04-10-2012 04:16 PM
Can SOA change my preorder? Zaneman BRZ First-Gen (2012+) — General Topics 8 04-08-2012 02:06 PM
