CANADA Canada
Old 08-02-2013, 12:51 AM   #533
Curtis
Curtis's Avatar
Drives: 2013 Subaru BRZ, 2005 Chevy Halfton
Originally Posted by Jlturner View Post
This is the first I've heard of this. I have over 16,000 Kim's on mine and haven't had an issue other than a rough idle which seems to have pretty much gone away. I'm paranoid now!
Me too! But i will speak to Subaru and get some more information soon!
2013 BRZ Sport tech, Saskatchewan
Curtis is offline   Reply With Quote
Old 08-02-2013, 08:27 AM   #534
frs baby
Drives: 2013 scion frs
thanx curtis
frs baby is offline   Reply With Quote
The Following User Says Thank You to frs baby For This Useful Post:
Curtis (08-02-2013)
Old 08-02-2013, 10:28 AM   #535
JPxM0Dz
F Z1LLA
JPxM0Dz's Avatar
Drives: Lexus IS-F Series 2
From what I've read, your MOSTLY at risk if you occasionally redline your car. I've never and don't plan too anytime soon, so I guess I'm ok...
Copied from the thread...
***This problem WILL manifest eventually in ANY car that even occasionally sees redline***
I dont know if you guys heard or not, but the mapping of the orignal ecu is incorrect and causing injectors to fail and run lean, causing major engine failure, apparently there is pre- detonation between switching gears. I am kinda scared to put km on mine to be honest i dont want to scratch my cylinder walls
Can't remember where I read it, but it seems to me that this issue was addressed in an updated tune which some of us are currently running, but does nothing for you guys that are running stock ROM I suppose
@SkAsphalt if you could chime in if you also remember reading anything on this ?
2URGSE
JPxM0Dz is offline   Reply With Quote
The Following 2 Users Say Thank You to JPxM0Dz For This Useful Post:
Curtis (08-02-2013), Jlturner (08-02-2013)
Old 08-02-2013, 12:29 PM   #536
Jlturner
Jlturner's Avatar
Drives: Scion fr-s
I've never redlined my car and I don't ever plan to. I've come close mind you but i've never hit the fuel cutoff. I rarely drive my car hard like that and when I do its for a short period of time. Hopefully we have no issues down the road when our warranty is expired.
For now, I'll keep driving my car and enjoy it hoping for the best!
Jlturner is offline   Reply With Quote
Old 08-02-2013, 12:33 PM   #537
Jlturner
Jlturner's Avatar
Drives: Scion fr-s
Originally Posted by frs baby View Post
so lets all meet on aug 23 in saskatoon
I'll be out all weekend with my car, I can meet up any time Friday evening. I usually hang out at Momentum on 8th street. Its a good central location to meet and hang out.
Old 08-02-2013, 03:38 PM   #538
R2
The cause of the issue really hasn't been confirmed yet and personally I'm not losing sleep over it and I don't think any of you should either.
A quick summary of the discussion is around detonation happening from rapid throttle tip in at engine speeds over 5200rpm. The stock tables don't have any ignition timing retard which may permit detonation during fast shifts or rapid throttle changes at high rpm, such as what you may see during autox. This detonation may be damaging the direct injector seals over time. Reving the engine to the redline or beyond to the fuel cut really isn't a big deal in my opinion.
As owners of these vehicles I think the best thing we can do is to use 94 octane (as is recommended anyways) to keep detonation to a minimum, and to keep our ears tuned to any popping events that are described in the above linked thread. Worst case scenario in the short term is you take it in and get it fixed under warrantee. I'm sure if failures start ramping up some sort of TSB will be issued. By the way, does anybody here know if any of the dealers in Sask. are aware of this issue?
R2 is offline   Reply With Quote
The Following 2 Users Say Thank You to R2 For This Useful Post:
Curtis (08-02-2013), SkAsphalt (08-04-2013)
Old 08-02-2013, 04:58 PM   #539
frs baby
hope to see alot of u on that fri
Old 08-02-2013, 10:54 PM   #540
Curtis
Curtis's Avatar
Talked to someone at subaru today,
apparently she has never heard of the idling issues, or the chirping and the fuel injector issues...
I told her many ppl are experiencing idling and chirping issues, but she told me there is no talk of a recall and she has never heard of such things.
So im not too sure how well the tech's at Saskatoon Subaru are informed, but there is definitely some issues that they are ignoring/unaware of.
She then said they can take a look at it and repair "it", probably not under warrantee.
Bla what the Hell!
Old 08-03-2013, 03:20 AM   #541
frs baby
i watched a video on replacing the injectors he said it was an 18hr job thats expensive
Old 08-03-2013, 04:05 PM   #542
empower-auto
Kouki-Monster
empower-auto's Avatar
Subaru of Saskatoon is ... ugh. Honestly you need to go elsewhere ... I hate to say.
Rich Anderson
EMPOWER AUTO
empower-auto is offline   Reply With Quote
The Following User Says Thank You to empower-auto For This Useful Post:
Curtis (08-14-2013)
Old 08-03-2013, 09:45 PM   #543
JPxM0Dz
F Z1LLA
JPxM0Dz's Avatar
Same can be said for Subaru Auto Gallery of Regina
Useless comes to mind...
2URGSE
Old 08-04-2013, 08:06 PM   #544
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
You are correct, there is a TSB out at dealers to update ECU programming for cars running stock tunes to solve the injector issue. Those of us with tunes have had this fix for a month+ now
The Following User Says Thank You to SkAsphalt For This Useful Post:
JPxM0Dz (08-05-2013)
Old 08-04-2013, 08:08 PM   #545
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
By the way, this claim "
***This problem WILL manifest eventually in ANY car that even occasionally sees redline***" is false
Old 08-05-2013, 01:53 AM   #546
JPxM0Dz
F Z1LLA
JPxM0Dz's Avatar
The quote was copied from the link Curtis left...
The guy that left the quote seemed to know his stuff, but I have no idea how accurate he is
Sent from my GT-I9500 using Tapatalk 2
2URGSE
EDM Thread!! Synack Off-Topic Lounge [WARNING: NO POLITICS] 194 12-13-2013 12:18 PM
Is there a thread for 'people doing stupid things in their brand new car' thread? Symbiont FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 36 02-18-2013 12:24 PM
Not another BRZ vs WRX thread... stayclam BRZ First-Gen (2012+) — General Topics 5 02-28-2012 02:58 PM
