Old 07-29-2013, 12:39 PM   #771
celica73
Traction control, or launch control?
Old 07-29-2013, 12:51 PM   #772
Sccabrz192
Detroit Region, MI
Sccabrz192's Avatar
Drives: 13 BRZ, 13 Volt, 02 WRX
Fixed. Meant launch. Traction control is NOT awesome. My last run of the event was foiled by traction control after the car stalled as I was pulling up to stage and I forgot to turn it back off I was dead set that I had a 31.XXX in me but that dashed those hopes.
Detroit / NWOR SCCA Member
2005-06: #192 ES 91 MR2 N/A Hardtop
2007-08: #54 STX 05 WRX Sedan
2009-12: #92 BSP/ASP 07 Solstice GXP
2013-14 : #192 CS 13 Subaru BRZ
Sccabrz192 is offline   Reply With Quote
Old 07-29-2013, 07:26 PM   #773
Scooby South
Conedancer
Scooby South's Avatar
Drives: 2013 Subaru BRZ SWP
Just walked into the door.. I will provide my thoughts on the weekend here in a bit. But Tim pretty much hit it on the head.. The Car Is there.. Just got to tighten the nut behind the wheel.
More later after I decompress
Bill
Scooby South is offline   Reply With Quote
Old 07-30-2013, 12:59 PM   #774
Scooby South
Conedancer
First off.. It was a great 'learning' weekend. Thanks to Tim for taking time out of his busy busy schedule to come play in Toledo.
Lessons Learned:
-Never go to an event that you have no knowledge of the surface without some kind of plan. Not alot of time to adjust on the car. It pretty much needs to be perfect out of the box.
With that said, Make sure you make your notes. I have a Log book that I keep but havn't updated it in a couple of events. So that setup you had at a similar course back when might be close enough to the setup you need to at least get started.
We started the event on Dunlops. and noticed right away that we were tight in some of the more technical sections, which kinda cost us some time as we couldn't get back to the gas quick enough having to wait for the car to settle out. I am learning you just can't bolt a set of tires on and expect it to work with the previous settings. I also have a set of Hankooks mounted up, and Both tires requires a little bit different setup. What was looser on the Hankooks, might be tighter on the Dunlops.. so make sure you have your notes to refer to.
-I am used to "practice" meaning a small course is setup so you can dial your car in a bit. Well not at Pro's... :/ ... Practice at Pro's are the starts...your Reaction time and 60ft. Silly me thought you actually got to run a course to see how the car felt..
-Tim is right about how my car feels vs. how a stock one feels. Everything in my car feels very connected. steering/drivetrain/suspension etc. and is very sensitive on the feedback it provides. I am used to it.. so I look for those indicators, on how the car is behaving on track. Believe it when I say. 1 Click here or there, my car notices that. it has a very delicate balance point.. To far one way, it could totally reverse how the car feels.
As for the actual event.. The Car is there as it was only 3/10ths off the lead on one side and 5/10ths on the other side.. just have to 'tune' the driver and make sure he does the homework on his notes... and no RL or cones..
Thanks again Tim. Hope you had fun.
Bill
Old 07-31-2013, 10:23 AM   #775
ayau
Drives: Some rust bucket
Hey @Scooby South,
I see you signed up for a local MN event this Sunday. I'll be in the WRB BRZ. See you there!
The Following User Says Thank You to ayau For This Useful Post:
Scooby South (07-31-2013)
Old 07-31-2013, 04:19 PM   #776
Scooby South
Conedancer
Originally Posted by ayau View Post
Hey @Scooby South,
Yep.. looking forward to it.. and look forward to meeting you.
Bill
Old 07-31-2013, 04:44 PM   #777
OrbitalEllipses
Drives: Attitude
And everyone else too!
Old 08-01-2013, 07:21 AM   #778
Scooby South
Conedancer
Morning Runs at Toledo... Tight tight Battle.. would have ended up in 10th if no RL or cones.. oh well Fun time.
[ame]http://youtu.be/9cNLnpoDAY0[/ame]
Old 08-01-2013, 08:55 AM   #779
UncleFester
Besides Simmons, are any of the other top twin drivers on the forum?
Good vid, looks like a fast and fun course. Every time I hear Danny Kao's name I think about his all aluminum performance radiator and no fan shrouds.
UncleFester is offline   Reply With Quote
Old 08-01-2013, 10:50 AM   #780
Scooby South
Conedancer
Yes.. a couple of them, Palotta is apexaddict here. George is GTB/ZR-1 ...
The Following User Says Thank You to Scooby South For This Useful Post:
GTB/ZR-1 (08-01-2013)
Old 08-01-2013, 05:41 PM   #781
GTB/ZR-1
GTB/ZR-1's Avatar
Drives: '13 BRZ in WRB--let's mod!!!
Who, me?!?!
Gee, thx Bill!
* ‘23 Corolla GR—AutoX/DE toy
* '13 Toyobaru P&L Turbo WRB BRZ SCCA XS-A build starting. SOLD
* '22 Z51 Vette--sold.
* '09 Nissan GT-R--gone, but not forgotten... 10.63 @ 131+ on streeties.
* '90 ZR-1 11.0 @ 130.2 & 11.2 @ 132.4 sprayed 120 shot.
GTB/ZR-1 is offline   Reply With Quote
Old 08-01-2013, 07:01 PM   #782
Scooby South
Conedancer
My incar for Sunday at Toledo
[ame]http://youtu.be/l3wltVNMVUo[/ame]
Old 08-06-2013, 02:56 PM   #783
OrbitalEllipses
Drives: Attitude
Bill, did you end up using the Kartboy brackets and shaving down the knuckle as per Ken's install guide or are using Ken's brackets as well?
Old 08-06-2013, 05:05 PM   #784
Scooby South
Conedancer
I shaved down the knuckle and used Kens.. KB's Brackets would not work at all. his is for a 170mm rear Drum.. Kens is used for the 190mm Drum. that and KB didn't want to re-invent the wheel, and decided not to pursue making the brackets for the later model stuff.. :/ .. But Ken Came thru.. his fit very well and do the job.. They are a bit heavier than I would have liked as they are made from Steel. so not the lightest.. but again Effective bracket he has. End Result.. Rear 2 pots that match the front..has AWESOME stopping Power.
Bill
Subaru/Scion warranty and autocross Ribface Tracking / Autocross / HPDE / Drifting 55 06-17-2015 08:30 PM
Will you Autocross your 86? Ribface Tracking / Autocross / HPDE / Drifting 131 06-22-2012 05:48 PM
Which autocross class? jpdarty7 Tracking / Autocross / HPDE / Drifting 66 06-21-2012 05:53 PM
FR-S at a CA Autocross oneday Scion FR-S / Toyota 86 GT86 General Forum 57 03-26-2012 03:38 PM
