Old 08-01-2013, 02:22 AM   #687
Anaxilus
Drives: They have four wheels
Originally Posted by DriftEm View Post
well, I'll be actually driving my car tomorrow with this kit with a proper tune, I'll let you now if there is a lag.
Works for me!! I hope not, I want one! If you can mash the throttle at a stop and spin/smoke those Primacy HP's I'll drop it and just be happy. Deal? :happy0180:
Anaxilus is offline   Reply With Quote
Old 08-01-2013, 02:24 AM   #688
DriftEm
DriftEm's Avatar
Deal BTW, I'm running Hankook RS3's
DriftEm is offline   Reply With Quote
Old 08-01-2013, 03:02 AM   #689
NickFRS
Drives: 2013 Asphalt FRS
My Perrin intake fits like a glove and is huge....
2013 Sion FRS
2014 Subaru WRX
2014 Subaru XV
NickFRS is offline   Reply With Quote
The Following User Says Thank You to NickFRS For This Useful Post:
sw20kosh (08-01-2013)
Old 08-01-2013, 03:04 AM   #690
NickFRS
Originally Posted by tech4pdx View Post
Dude.. I was sweatin' balls right before I called PRE yesterday to get the diagnosis. It was a big relief to hear it was all good. Was worried I tweaked the subframe.. Even though that wasn't likely.
Glad it's only a wheel man! When I showed up to PRE and saw the phone calls/texts and noticed your car was there with dirt all over the wheels I was like Ut o Evan went off the road!!! ahahaha! Glad you guys are okay. Everyone goes off some time.... just glad you guys are safe and the car is still happy.... are you coming out to the drags Friday night?
2013 Sion FRS
2014 Subaru WRX
2014 Subaru XV
tech4pdx (08-01-2013)
Old 08-01-2013, 03:10 AM   #691
Anaxilus
Originally Posted by sw20kosh View Post
While I am sure this is true, I don't see any other way to route the intake pipe to access cold air...
LOL Unless you want to bore a hole through the firewall/dash and have a cone filter in place of your radio.
Maybe you have other ideas?
Yes I know, it's problem which is why the throttle was moved to where it is. It really was the simplest and most obvious way to make the kit work, it makes sense. Ideal? Well, that's debatable. An alternative solution would have to involve some out the box thinking. Then the question is would it be cost and time efficient/beneficial to implement? I've had some thoughts and think it's possible but I don't think it would have a good business case at all for mass production and easy user installation.
The easiest, most obvious solution would be to rely on the Subie hoodscoop or aftermarket hood and make a ram air box and modify the blower and throttle to a top feed solution. That's all prohibitive and something of a PITA. My other solutions are more strange and convoluted requiring a lot more development time, so I'll keep those to myself unless I actually make them happen.
Old 08-01-2013, 05:05 AM   #692
Boil
Drives: CX500 Cafe Bobber
…obvious solution would be to rely on the Subie hoodscoop or aftermarket hood and make a ram air box and modify the blower and throttle to a top feed solution.
First thing I thought when reading the last couple of pages…
Get the air filter right up there by the throttle body, and build a box around it that mates up to the hood (when closed) with a NACA duct to pull air into said box…
Boil is offline   Reply With Quote
Old 08-01-2013, 05:18 AM   #693
ft_sjo
Drives: GT86
Are you guys assuming that air goes into the hood scoop on a scooby?
Old 08-01-2013, 05:47 AM   #694
tech4pdx
Make love
tech4pdx's Avatar
Drives: H8R.. Not really
I will be there!
tech4pdx is offline   Reply With Quote
Old 08-01-2013, 09:29 AM   #695
regal
Drives: Scion FR-S/Toyota Yaris
There is a vacuum port on the bypass actuator. There is an internal spring keeping the valve in the closed postion. My measurements have shown it is a 2-3 psi spring.
The bypass is cracked open with vacuum on this port. On mine it looks like it is about 15-20% open at idle. I have no idea what it looks like on my car at cruising but it is supposed to be cracked open then as well.
It shuts once there isn't enough vacuum (about 4-6 inHg) to overpower the internal spring of the bypass actuator (ie when you open the throttlebody butterfly enough and reduce the vacuum in the pre-supercharger plenum). Once it is shut, it cannot open until there is enough vacuum again (the valve itself is a butterfly type and thus the boost in the manifold cannot push against it to open it).
This helps keep cruising gas mileage in check.
Crusing 6th gear 2.5k to 3k rpm is the bypass open or closed?
2013 FRS Argento Silver 6MT
Mods:
Clear fender side lights
Tactrix ZA1JB01C 2014 Calib
regal is offline   Reply With Quote
Old 08-01-2013, 10:52 AM   #696
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
02-03 scoops vented air at highway speed, and the 04-05 WRX was iffy. The 04-05 STI did take in air at a speed, but they had to boost the scoop up into the airflow. The 06-07 redesign actually saw a windtunnel during development so it does work on both the WRX and STI.
Old 08-01-2013, 10:54 AM   #697
ft_sjo
Drives: GT86
That's some interesting information. I've only tested older versions but suspected similar results from later models. I know some special editions have larger scoops, perhaps that's the difference. I'm somewhat amazed the intercoolers really do anything at all, but they do seem to!
Old 08-01-2013, 10:57 AM   #698
mines13
mines13's Avatar
Drives: '13 FR-S '12 CBR1000RR
Send a message via AIM to mines13 Send a message via Yahoo to mines13
Me and Evan both have the same clutch + lightweight flywheel. (ACT stage 1 street lightweight kit) <- Prolight flywheel...
...Also remember the blower is attached to the pulley system so it's a little different then a turbo. Your actually adding more rotational weight for the boost. This gives a weird peddle feel at low RPMS (2-2500) Kinda jumpy but once your above 3k the car screams through the rev range.... My traction control lights up in first around 4500 in a straight line if i'm WOT...
If you are experiencing any sort of delay, lag or stumble sub 2500RPM your tune needs further refining and you should contact your tuner. This can and has been addressed, both by Delicious Tuning (completed) and Moto East has an updated tune that also corrects this which will be released shortly. Again, you should not feel a low end tip in stumble or lag if the tune is dialed in properly.
mines13 is offline   Reply With Quote
Old 08-01-2013, 11:02 AM   #699
xjohnx
Grip>Slip
xjohnx's Avatar
Originally Posted by mines13 View Post
This can and has been addressed, both by Delicious Tuning (completed) and Moto East has an updated version that also corrects this which will be released shortly. Again, you should not feel a low end tip in stumble or lag if the tune is dialed in properly.
Great news. @moto-mike - if the update is ready before tonight and you want to send the fixed version my way for the install tomorrow, feel free We had planned on doing dyno runs from 2K at the request of some posters in this thread.
Old 08-01-2013, 11:36 AM   #700
mines13
mines13's Avatar
Also, to be fair, other tuners may have addressed this as well, or have updated tunes pending, and I may just not be aware of it. In time, I am sure everyone who has a handle on the ECU whether they are using an open tuning solution or ECUTEK has or will have it figured out.
The Following User Says Thank You to mines13 For This Useful Post:
xjohnx (08-01-2013)
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
