Old 07-31-2013, 04:43 PM   #85
jamesm
No different then changing the plugs. You disconnect the exhaust and motor mounts (there are some other things as well) and raise the engine up to get the spark plug holes above the frame rails. It really isn't that bad.
there is no need to do any of that. i gapped mine down without disconnecting anything except the metal shield thing on the right side of the engine bay, and the ecu box on the left side. just need to wobbly extensions and a relatively thin wrench.
Old 07-31-2013, 06:37 PM   #86
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Can you post up the exact tools you used? I still might make an investment, but this allowed us to get it done with a simple standard 3/8" ratchet, a 3/8" spark plug socket, and a 9/16" deep socket.
Old 07-31-2013, 08:45 PM   #87
jamesm
Two craftsman 3/8" wobble extensions, a regular short (2" I believe?) extension, and a regular craftsman 3/8" ratchet. I used a regular 14mm socket as opposed to a spark plug type socket. The key is that you first attach the wobble extension to the socket and push it into the plug hole, then add another wobble extension and push in a bit further, then the regular extension, then insert the wrench into the end. That'll let you crack it loose then you can remove the wrech and take pieces off one at a time as you pull it back out. It's actually not difficult at all after the first time (once you learn to remove the ecu thing ��and shield lol).
86 Dyno results Anban AFRICA 18 01-14-2014 06:54 AM
Dyno Compilation - dyno testing results and recommendations Illusive Engine, Exhaust, Transmission 82 02-08-2013 07:00 PM
Compilation of Dyno results somewhere??? Scooby South Engine, Exhaust, Transmission 3 01-08-2013 06:51 PM
Pocket Dyno App Results CBR600RR Scion FR-S / Toyota 86 GT86 General Forum 14 09-12-2012 10:45 PM
My Fr-s Dyno Results!! Surprising if you ask me track_warrior Engine, Exhaust, Transmission 36 07-02-2012 10:15 PM
