Old 07-31-2013, 07:58 PM   #1
l0aded
Addicted
l0aded's Avatar
Drives: 2013 Asphalt FR-S 6MT
BeSpoke Backup Camera on Relay
Hey can someone check my diagram for installing a 12V backup camera on a relay? Limited experience in circuits so I want to be safe.
Phantom Supercharger | Tsudo Cat-Back Exhaust | K&N Drop-in Filter | Winjet Headlights | Opti-coated | 35/20 Tint | Radar/Dashcam Hardwired | OFT tuned | OEM Audio+ Reference 400CF | Uber Sound Deadened | LED DRL strips | JPM Coachworks Kneepads
l0aded is offline   Reply With Quote
Old 07-31-2013, 08:10 PM   #2
gdrider77
gdrider77's Avatar
Drives: Subaru BRZ Limited
thats good. I would make sure you add in fuse on the 30 side where you tap your power.
gdrider77 is offline   Reply With Quote
Old 07-31-2013, 08:14 PM   #3
l0aded
Addicted
l0aded's Avatar
Sounds good, thanks. I'll probably just use a add-a-fuse instead of tapping a wire.
edit: Which fuse can I safely use an "add-a-fuse" to that is 12V? On the driver's side box I only see ECU ACC
Old 07-31-2013, 11:24 PM   #4
xjohnx
Grip>Slip
xjohnx's Avatar
You should be able to put it on the cigarette lighter or radio fuse.
Old 08-01-2013, 12:02 AM   #5
JimmyMac
JimmyMac's Avatar
Drives: 2013 FR-S, 2016 Miata Club
What's the relay for? To keep the camera from having constant voltage?
JimmyMac is offline   Reply With Quote
Old 08-01-2013, 01:05 AM   #6
l0aded
Addicted
l0aded's Avatar
Relay basically is a switch that tells the camera to turn on when the "trigger" tells it too. If you don't use a relay or another method the camera will constantly be powered on (even when the headunit isn't displaying the video) when the car is on instead of just when in reverse.
Old 08-01-2013, 02:18 AM   #7
JimmyMac
JimmyMac's Avatar
Ok, so basically like I was asking. Thanks for posting this. A few days ago I ordered a cheapo cam off EBay that another forum member used. I'm gonna be installing it hopefully this weekend. I like the relay idea, although I was thinking of installing it on a switch so that I could turn it on if I wanted to check to see who is following me or whatnot. Brake checks, stuff like that. hehe.
Old 08-01-2013, 02:27 PM   #8
l0aded
Addicted
l0aded's Avatar
Do you know if I tap the cigarette lighter wire that I already tapped for my LED DRL strips would it still supply enough voltage to power the backup camera? Or would it cause any other problems having too many things on this one line?
Old 08-01-2013, 02:28 PM   #9
l0aded
Addicted
l0aded's Avatar
Sounds like a cool idea. You should take it one step further and figure out a way to make it go on relay so it automatically turns on AND a manual override switch lol. That'd be pretty boss.
Old 08-01-2013, 02:42 PM   #10
xjohnx
Grip>Slip
xjohnx's Avatar
i can't imagine it would be a problem. the amount of power your backup camera draws is VERY low.
Old 08-01-2013, 03:27 PM   #11
JimmyMac
JimmyMac's Avatar
Yeah, I was actually wanting to install a front camera as well for parking close to curbs. As low as our fronts are, I'd hate to "tuck" it under one day because of those tire/parking curb things. That and other uses. I'll have to work on a circuit for that.
Old 08-01-2013, 03:58 PM   #12
#944_10_Series_FRS
#944_10_Series_FRS's Avatar
Drives: 2013 10 series FRS #944
Using your method is not going to work, unless you start the car and shift it into reverse immediately. The reason for that is when the HU is power up, it needs to detect if there is a camera installed. By using relay, the camera is not on until you shift it into reverse.
On the 16 pin harness, there is a power out. You should connect your camera to that power out. That power out is only on momentary when your HU is boot up, it trigger the camera and therefore telling HU that there is camera installed.
Here is the thread to talk more detail about this;
http://www.ft86club.com/forums/showthread.php?t=36323
Last edited by #944_10_Series_FRS; 08-01-2013 at 04:03 PM. Reason: Link to the DIY section on installing backup camera
#944_10_Series_FRS is offline   Reply With Quote
The Following User Says Thank You to #944_10_Series_FRS For This Useful Post:
nalc (08-02-2013)
Old 08-01-2013, 04:31 PM   #13
l0aded
Addicted
l0aded's Avatar
Sorry can you clarify about the 16 pin harness? Are you talking about the video wires (yellow and black) that go in the top right in the guide and bottom right in the guide (pin 8[V+] and 16[V-] in my diagram)?
The camera video wire will always have a direct connection to the 16pin. It just won't be powered on until I put it in reverse.
Old 08-01-2013, 04:55 PM   #14
#944_10_Series_FRS
No, the 6v power lead is the one next you your video+ pin. See the link for instruction on how to install this. This instruction comes from David Carter who supplies the 16 pins harness to members here;
http://ae64.com/Rear-camera-install-16p-BeSpoke.htm
http://ae64.com/Rear-camera-16p-operation.htm
Good luck!
DIY Backup camera for BeSpoke and 2014 Pioneer post_break DIY (Do-It-Yourself) Guides 48 06-01-2017 01:57 PM
Scion FRS Bespoke Backup Camera, What do I need? post_break Electronics | Audio | NAV | Infotainment 8 07-02-2016 10:55 PM
Help installing backup camera / setting up AV on BeSpoke? l0aded Electronics | Audio | NAV | Infotainment 11 07-18-2013 09:05 PM
Beat-Sonic Backup Camera & Adapter for FR-S (Bespoke) & BRZ Special Price Beat-Sonic Audio/Visual, Electronics, Infotainment, NAV 60 07-15-2013 04:58 PM
Backup Camera Help husker741 Electronics | Audio | NAV | Infotainment 2 02-13-2013 02:04 AM
