Old 07-14-2013, 12:30 AM   #15
CK_Bladesmith
CK_Bladesmith's Avatar
Drives: Raven FR-S
Originally Posted by zooki View Post
If you get this done, don't forget to pick up one of these:
http://kalecoauto.com/index.php?main...&products_id=8
I'd say it was almost mandatory....
Hahahahahaha hell yes joe!
Raven FR-S mods: Unichip, Ground Control street coilovers with camber plates and strut tower brace, SPC Lca's, Drag DR-38 wheels with Dunlop Direzza DZ101s, Perrin CAI and silicone inlet tube, Perrin 3" resonated catback, Perrin high flow catted front pipe, Rev Works UEL header.
CK_Bladesmith is offline   Reply With Quote
Old 07-30-2013, 05:54 AM   #16
NYCsubaruBRZ
Drives: 2013 Subaru BRZ & 99' Ford Explorer
Originally Posted by roddy View Post
The price of the Cusco TB is crazy.
For less than 1/5 the cost of that, a person could have their stock TB (or a core from a wrecked car, etc) ported/bored, polished, 1/2 shafted, and knife edged. I'm surprised I haven't seen more discussion on this especially in the F.I. threads.
exactly....... 1800 or 1400 or what ever they want for that is crazzzzzzy.
and im sure the p&p tb will perform just as good. not to mention that cool ass sound of air being sucked into the intake. my explorer sounded sweet when u hit the throttle
NYCsubaruBRZ is offline   Reply With Quote
Old 07-30-2013, 08:01 AM   #17
wparsons
wparsons's Avatar
It's already been said in this thread, and other threads as well, but the stock TB is already very large for the size of the engine in these cars. Comparing gains on this car to an SUV from 10+ years ago is useless unfortunately.
I haven't measured mine, but other people are reporting the stock TB is 76mm. Most engines this size run 55-60mm TB's stock, and upgrade to 65mm.
I would bet that even with tune you're looking at 1hp if you're lucky by going to a bigger TB, and it'll be way twitchier at part throttle as well.
flickr
Old 07-31-2013, 12:23 PM   #18
slicktop
Drives: 2013 Raven FRS 2JZ-GTE/V160 swapped
Flat 4 cyl != V6
slicktop is offline   Reply With Quote
Old 08-09-2014, 02:05 PM   #19
Carlitoz3
Carlitoz3's Avatar
Drives: 2013 MT Asphalt FRS
Bump
http://www.proimporttuners.com/parts...JMYaAsEC8P8HAQ
90mm? +10hp??
Has anyone bought this?
Carlitoz3 is offline   Reply With Quote
Old 08-09-2014, 07:17 PM   #20
jdubious
Drives: 13 Scion FR-S
Originally Posted by Carlitoz3 View Post
Bump
90mm? +10hp??
I ordered one but ran into trouble hooking up my throttle cable.
jdubious is offline   Reply With Quote
Old 08-09-2014, 08:27 PM   #21
gramicci101
Off Topic
Bump
90mm? +10hp??
The OEM throttle body doesn't restrict airflow already; why fix something that isn't broken? Especially when that "fix" is a universal engine part. Why not get a set of universal camshafts so you can really affect how the engine breathes?
Old 08-09-2014, 11:03 PM   #22
Carlitoz3
Carlitoz3's Avatar
Waiting on the HKSs.
Anyone in particular you recommend?
Old 08-10-2014, 02:56 PM   #23
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
I'm still waiting on MAP Performance. They were going to rebore a stock TB to 68mm and taper it for $250 (core exchange.) http://www.ft86club.com/forums/showt...t=52970&page=4
The Cusco TB is crazy priced for no info and the Toda Racing one is also up there In cost vs info. IIRC they are 68mm with a 72mm tapered leading edge. There was also another I think by Revo-Tune that included a TB Spacer which was needed because of a 70mm large bore tapering. I think the general census with the TB space was it negativly effecting throttle response though... Can't go much bigger though as the coolant runs through the TB though it is simple to modify it to not.
Old 08-10-2014, 05:27 PM   #24
ChilOut
ChilOut's Avatar
Drives: 2014 Subaru BRZ Premium
I'd say it's safe to assume you'll throw a CEL if you modify your TB. These engines seem pretty sensitive to their air/fuel mixture. If you have a way to tune it, I'd say go for it man
"Only a fool walks into the future backwards"
ChilOut is offline   Reply With Quote
Old 08-10-2014, 06:40 PM   #25
ML
ML's Avatar
Drives: 13 White MT FR-S
It says you have to use their Intake manifold for the TB to work, but I don't see a intake manifold anywhere on their site for the 86.
Old 08-10-2014, 06:48 PM   #26
gramicci101
Off Topic
That's because it's a universal part. It also has testimonials by Evo owners.
Old 08-10-2014, 07:03 PM   #27
ML
ML's Avatar
"Will not work with factory intake manifold. Must purchase a Skunk2 Ultra Series Intake Manifold for this to fit."
Its not universal. Why would they even list it under the FRS section?
Old 08-10-2014, 07:51 PM   #28
Turdinator
Señor Member
Turdinator's Avatar
The one linked is universal and it is also cable operated so won't work without DBW setup. You would probably have to go with an aftermarket ECU to get it too work. The Cusco and Toda are modified stock units so are plug and play and won't change things enough to throw a CEL. On a stock car there probably isn't much power to be had from a larger TB. Your money is better spent on headers or a tune.
1974 TA22 Celica
2013 86 GT
Cusco Throttle Body? track_warrior Engine, Exhaust, Transmission 66 06-28-2016 06:28 PM
Dirty throttle body AVOturboworld Engine, Exhaust, Transmission 11 05-11-2016 10:58 AM
Heated throttle body? Turdinator Engine, Exhaust, Transmission 19 04-06-2014 11:21 AM
YR-Advance Throttle Body ANREX Engine, Exhaust, Transmission 9 10-30-2012 01:45 AM
